3rd gear synchronizer problems. 07 FG2
I have about 1000miles on my 07 FG2. I've been noticing that went i go from 2nd to 3rd it grinds sometimes, its not my shifting though, and it also did it on the Si sedan I test drove. Anyone else notice this?
![]() Join Date: Mar 2007
search search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search searchsearch search search
#5 (permalink) | |
#13 (permalink) |
Ls1 JeRk
You'll also need one of these: http://www.pelicanparts.com/catalog/...wepco_pg15.htm
#14 (permalink) |
Scean
the synchro are bad go to the dealer and have them fix it and if it occurs again have them change the tranny. my 06 is at the dealer right now and their fixing 3rd and 4th for the same problem they tried to say it was normal but i know thats bull****. i told them if it happens again after they fix it i want a new tranny. take my advice and get it fixed or it will get worst. and changing the fluid wont help.
#16 (permalink) | |
Stephen "Vince" Carter
#17 (permalink) | |
#18 (permalink) |
Changing to Amsoil MTF significantly improved the 3rd gear notchiness I was experiencing in my '07 FA5. There's still a slightly exagerated resistance when shifting into 3rd gear on a cold morning (as compared to the other gears), but it's 10x better than it was before. Amsoil FTW!
#19 (permalink) |
Had only slight notchiness 1-2-3 but changed to Amsoil MTF thinking that would make it perfect. The improvement is there but a hint of notchiness remains. I'm fortunate I didn't have the bigger problems some have reported.
BTW, someone said somthing about over fill? I used 1.75 quarts on refill, maybe it would have been better to only put in a measured 1.6 quart like the manual calls for? Next time I'll try that amount and see if there is any improvement. |
| the 3rd gear issue | Slav | Mechanical Problems & Technical Chat | 13 | 04-08-2007 08:28 PM |
| 07 Problems | todsulli | Mechanical Problems & Technical Chat | 33 | 01-29-2007 11:38 AM |
| 3rd Gear... | nnorton | Civic SI | 21 | 01-13-2007 08:25 PM |
| 3rd and 6th gear problems.. | BATANG CITY JAIL | Mechanical Problems & Technical Chat | 4 | 09-15-2006 10:58 PM |
| Problem with 3rd Gear? | imtim25 | Mechanical Problems & Technical Chat | 57 | 08-23-2006 09:28 PM |
