Aux input question - 8th Generation Honda Civic Forum
Old 11-27-2012, 03:12 PM   #1 (permalink)
KrusT 954's Avatar
Chris
Aux input question
Hey guys i have a 07 Si and my aux input (in the console) needs to be replaced and i was wondering if anyone knew if a DIY for the Si Aux exists and where it is, or which one i can use in order to access the area i need to. I already have the part. Thanks guys
KrusT 954 is offline
Old 11-27-2012, 04:23 PM   #2 (permalink)
ismashface's Avatar
Kelly A.
its not hard but i do not have the diy tech info but if you know haow to remove the radio . thats all it takes
ismashface is online now   Reply With Quote
Old 11-27-2012, 11:40 PM   #3 (permalink)
Craig
U don't have to take out the radio. Look at the new part very closely as to where the release clips are. I took off the center console out the part around the shifter and dropped the lower drivers side dash and removed a screw to lower the middle dash, It's kinda hidden and in a tight spot but a good magnetic screwdriver got it done for me. Then got my gf to pry one side as I PRy the other and out it popped Enough for me to rip it out with some pliers. Took about 20 min. Just to figure it out.
Puckhead is offline   Reply With Quote
Old 11-28-2012, 03:40 AM   #4 (permalink)
KrusT 954's Avatar
Chris
It was a NIGHTMARE, but not really. We basically did the stereo removal only to find that part to be covered by another panel that would require removing a panel covered by the passenger side dash, so basically i used a pair of vice grips to attempt to rip out the old aux input box, and that worked. We more or less destroyed the old one so it would come out without having to release the clamps. Barbaric, but desperate times. Biggest challenge was hooking up the cable to the back of the new input. So glad its over. But it is interesting to know that it only takes 3 screws in total to remove our stereo.
KrusT 954 is offline   Reply With Quote
Aux Input and USB memory question josh_ww I.C.E., Electrical, Security, & Navigation 2 11-07-2012 11:52 AM
Question regarding the aux input jack regor I.C.E., Electrical, Security, & Navigation 2 12-03-2011 05:21 PM
Quick Question!? Input please DynoBlue4Door Mechanical Problems & Technical Chat 2 04-03-2011 11:00 PM
Hi level amp input question greg rocks I.C.E., Electrical, Security, & Navigation 2 04-29-2009 12:18 AM
Audio Input Question zippob09 I.C.E., Electrical, Security, & Navigation 2 08-12-2007 06:25 PM
