Confused with oils
I have been using Castrol GTX 5w-30 and now realized it isn't syntehtic like I thought it was. I searched for what was the best syntehtic oil and what viscosity to run but am dumbfounded. I was thinking Redline or Amsoil and sticking with 5w-30??
Thura
Check out this forum and ask these guys, I'm sure they can get you a good recommendation:
"What oil should I use? What is the BEST oil?" - Bob Is The Oil Guy |
#11 (permalink) |
Jason
The oils I list are all in the same class and are a class above any Mobil 1 or castrol. The Honda oil is the only one you can buy reliably at a local dealer, plus with it being made for our cars, it should be a no brainer.
#14 (permalink) |
stabn with a purple knife
![]() Join Date: Apr 2009
Brandon
if you want the best you can buy off the shelf. buy castrol 0w30 german synthetic. other wise any 530 synthetic will be perfectly fine. just buy what ever your local auto store has on special for 5qts and a filter.
#15 (permalink) |
i did my last oil change with m1 synthetic but Im thinking i might go back to dino. I havent checked my dipstick to see how the consumption compared to the regular oil yet though, that might be a deciding factor because my car does burn a bit of oil between changes.
#16 (permalink) |
Dustin
If you have the money to spend I would recommend Amsoil or Schaeffer's. Most off the shelf synthetic oils are good, such as Mobil 1, but are considered "factory fill" emission oils. This is because they have been stripped of zddp (zinc) and phosphores because they negatively effect emissions. These two oil additives are crucial to bearing wear and protection. I personally run Amsoil Signature Series 5w30 with a genuine Honda oil filter.
If you aren't looking to spend a lot of money you will be just fine running any other synthetic or non-synthetic oil. Just make sure you change your oil religiously like others have already stated. I would recommend a 3,000 mile interval instead of a 5,000 mile interval if doing so. |
#18 (permalink) |
Whatever "synthetic" is on sale... Then every 20k get it analyzed.
Blackstone Labs Last edited by Chris/Si/4dr; 03-25-2012 at 03:57 PM. |
#19 (permalink) | |
#20 (permalink) | |
| Good oils | RedCivic | Mechanical Problems & Technical Chat | 1 | 09-25-2006 12:19 PM |
