#21 (permalink) |
yes, they were definitely HPS. these exact ones
Hawk HPS Brake Pads (Subaru STi) - Modern Automotive Performance |
#22 (permalink) | |
Esteban
That being said, I'm looking into getting new pads soon for my almost 5 year car. Would like a bit more stopping power but without a major expense. I don't track my car so the OEM rotor and caliper setup is fine. Pads can make quite a bit of difference. I will probaby be going with Hawk pads as long as I can be certain they don't 'dust' any more than OEM pads. |
#24 (permalink) |
I have hawks, but dont really notice the difference.
I thought my pads were getting weak around 35k miles as i had to push the pedal harder and harder to stop. Shop told me i had 80% up front still @ 35k miles! Honda oem ftw |
#25 (permalink) | |
#26 (permalink) |
Same way you break any pad/rotor combo in. The goal is to not have hot pads sit on hot, new rotors. That causes the pad to glaze the rotor, not warp it. When your brakes shake that is glazing, not warping, unless you race your car very, very hard.
Either brake very gradually and when you come to a stop put the E brake on while removing foot from brake, or do the method of quickly bedding them in by going 60 mph, braking hard without stopping, over and over. I just drive gently and pull the e brake when I come to a stop and my brakes always last for years before I need new pads. When you do this you are taking the hot pad off the rotor so that it doesn't bake the glaze onto the rotor. If they ever start vibrating, just take the rotor off and sand it with 220 sand paper. Good as new without removing metal and making the problem worse. I also never downshift unless I'm raising hell. The key is to stop gradually and the pads will last for years. I leave the car in gear until 1000-1500 rpms without downshifting. |
#29 (permalink) |
Kevyn
Is it just me cause im starting to change my brake this weekend. The car had 63k miles now. I'm still wondering how did my rear brake last to 55k and my front 63k? I never downshift braking, I always neutral and use the brake to stop at the light.
#30 (permalink) | |
Regards Chris Sent from iPhone no tapatalk cuz I'm to broke to buy that crap o.O |
#31 (permalink) |
Ken
i changed to hawks hps at 65k on my si and i still had plenty of pads left on my OEM but i said screw it and changed all 4 to hawks hps, did not resurface by rotors because they were fine.
now i am at 108k and they still stop like a champ. I do notice the Hawks had more break dusts than OEM. Def would recommend and get them again. |
#32 (permalink) |
Kevyn
ran my OEM brake up to 63k miles before the switch. the shop had to resurface the front rotor twice cause it was vibrating. then installed the Hawks HPS, so far so good. can't really say anything about the stopping comparison vs OEM cause i haven't really put it to the test yet. but i hope that it's better.
#38 (permalink) |
![]() Join Date: Nov 2007
Darwin
Centric Blanks are pretty much Powerslot rotors that are not slotted and drilled. I'm running EBC red on stock rotors and it's been over a year since.
![]() "Gods, aliens, other dimensions. I'm just a man in a can." - Tony Stark "Would you choose water over wine? Hold the wheel and drive." - Incubus
#39 (permalink) |
Alexander
I have EBC Green Stuff pads and stock rotors and they are perfect! They are crisp, have less fade, and less dust. Plus they have a "break-in surface" and it makes breaking them in extremely easy!
#40 (permalink) |
Re: Hawk brake pads or OEM?
Would it be cheaper to resurface rotors or buy new ones? Im torn between StopTech Street Performance and Hawk HPS. Both are cheaper compared to OEM pads.
Sent from my SGH-T769 using Tapatalk 2 |
| Hawk Brake Pads | CorSport | CorSport | 59 | 05-18-2012 01:30 PM |
| Hawk HPS vs. Hawk HP Plus Brake Pads. | keefer | Suspension and Brakes | 21 | 07-29-2011 10:50 PM |
| Hawk Brake Pads - HPS or PC or HP Plus? | urflix | Suspension and Brakes | 11 | 04-10-2010 03:45 PM |
| FG2 Hawk HPS Brake Pads | hunginator | CorSport | 1 | 05-18-2009 12:13 PM |
