LinkBack (2) | Thread Tools | Display Modes |
#42 (permalink) | |
It's in the oil pan. We've had this discussion before. The Si only loses 4hp to the balance shaft. |
#45 (permalink) | |
#46 (permalink) | |
And that's really cute how somebody changed the title of this thread, but can we change it back please? This information is about the K20Z3. Not the K20. The K20 is a very broad designation. I didn't put all of this shit together for nothing. Thanks a bunch. Last edited by skittleslegend; 01-13-2007 at 08:23 PM. |
#48 (permalink) |
Um...ok. I don't think you really caught what I was saying. You're looking at a fairly significant loss in top-end power swapping those intake manifolds. The K20Z3 was designed specifically for the RBC manifold. The torque gain you're looking at is neglible. It's a high-revving 2.0L Honda block...you're not going to see any significant change in torque output anyway. People dump the TSX manifold for the RBC during K-swaps.
But I suppose if you're really set on using the TSX IM, then go for it. It'll fit. You should still be able to use the Si's throttle body, but from what John at Hytech has said, the TSX TB will swap over too. |
#50 (permalink) | |
I am merely curious to know if the IM would fit. I am not set on doing any type of swap, but would like to see what a dyno would show for an si with the RBB IM versus an si with the stock RBC. |
#51 (permalink) |
What makes up your Si?
"The head is 100% TSX the block is a tsx 2.0L version with dual oil balance shafts and oil jets with a type s oil pan. oil jets, and the little oil pump cover signifies the dual shafts.. The oil pan is not from the K20a2 though. It uses a different casting so that the rear motor mount can attach to it. The type s style single pump has a longer cover. Stock k20a2 clutch. As far as the cams, they have different part numbers so we are not going to know till we test them '06 Si Cams Intake 14110-RRB-A00 Exhaust 14120-PRB-A01 '05 Type S Cams Intake 14110-PRC-030 Exhaust 14120-PRC-030" All of this is actually pretty surprising since the engine designation is K20z3 and the 06 RSX-S engine designation is K20z1. Although the Si shares some similarities, it seems to actually be closer to that of a TSX, including the Drive-By-Wire throttle. Another example, is the transmission. The Si tranny uses 1st-5th gears from the RSX, but the 6th gear is from a TSX. The LSD is from a JDM DC5R. The syncros on gears 4-5 are carbon, not brass like the 02-04 RSXs. This should reduce the problems that tranny had with gear grinding. The Si uses the RBC Intake Manifold from the JDM Accord Euro R. The TSX uses an RBB Intake Manifold. The difference between the two is the RBC uses shorter fatter runners optimized for high rpm breathing and the RBB uses a long narrow runner which is good for torque. This is part of the reason the Si loves to rev, because it was given the intake manifold do so. It's trade-off is torque. We all know the Si's torque is low compared to it's competitors. Theoretically, you could swap the RBB Manifold onto the Si and pick up better torque, at the slight sacrifice of top-end. How much sacrifice and how much gain is unclear. The RBB Manifold is also used on the 2.4L 160hp Accord. The Si uses raised dome pistons.The balance shaft smooths out the engine, reducing vibration, which is why there's a difference in horsepower rating between the RSX-S and the Si. These are the reason for the 4 horsepower difference after the new SAE ratings.Notice the MAF sensor on top of the Air Filter. For those that don't know the MAF (Mass Airflow) sensor converts the amount of air drawn into the engine into a voltage signal. The ECM needs intake volume to calculate engine load. This is necessary to determine how much fuel to inject and when to ignite the cylinder.Honda advertises the Si as having a cold air intake. The snorkel runs under the battery tray to another box and from that box another snorkel runs to the fender. With it's length and all the bends it probably does drawn in cooler air but at the expense of throttle response. I bolded a couple things so the differances would be easy to spot out. ShayneD. Last edited by Dessa_8837; 03-15-2007 at 06:11 PM. |
#55 (permalink) |
Seems Honda and Porsche share the same philosophy. Take all the best parts from previous cars and put them into their premiere car. Porsche takes all the best parts from previous 911's and puts them into the latest 911 turbo. Check out the Best Motoring video on the 996 911 turbo it shows actual part #'s and castings and such.
LinkBack to this Thread: http://www.8thcivic.com/forums/civic-si/23594-inside-k20-cam-gear-cam-shaft-retainers-valves-springs-rocker-arm-merged.html
| Civic SI - 8th Generation Honda Civic Forum | This thread | Refback | 02-06-2008 04:41 PM | |
| Difference between k20z1 and z3 - Page 2 - Club RSX Message Board | This thread | Refback | 12-05-2007 08:46 PM | |
