#861 (permalink) |
The non SI civics ping for about .5 of a second at certain times when the load is high or if your in the wrong gear.
Using High octane fuel solves this, and im almost 100% sure it will have higher hp ratings then if using regular. The R18 is rated at 10.5:1 compression. BUT i use regular because its recommended by honda and gas is so expensive now. |
#862 (permalink) | |
Nope. No extra HP from high octane fuel. However IF its really hot and your running the car hard on cheap gas the engine might ping and the ECU correct the timing to adjust for the ping thus a loss of HP. Higher octane fuel would prevent the loss but not increase the HP. I only purchase high octane if its really hot or I am carrying a full load in my car. r18 owner. If I owned the Si I'd only run cheap gas during the colder winter months. Any warm weather would be high octane. Last edited by ryker; 07-06-2008 at 08:13 AM. |
#863 (permalink) | |
#864 (permalink) |
Ok so I attempted to to skim through this thread but between all the flaming and all the BS posts I don't have the patience to read anymore.
So I'm probably repeating a question thats been covered numerous times, but I have an 07 Si with a touch over 34k miles (yea I love to drive) Yokohama Avid W4s tires at ~36psi, Injen CAI. 70/30 City/Hwy and Im usually shifting in the 4-5k range. I don't mind getting on the car at any time and since I bought it (1/26/07) it has been taking Sunoco Premium fuel from the same station with the exception of a handful of times (but still always Sunoco). I average roughly 250-270miles to the tank. Are these normal-ish numbers? Ive really only noticed a drop in about 1 mpg with the intake and of course my mileage dips a little once the maintenance-minder hits about 30% Oil. |
#865 (permalink) | |
Exhaust gas recirculation - Wikipedia, the free encyclopedia For those of you that are wondering, it is the little black cylinder looking thing in the bottom right of the picture, below the spark plug: http://upload.wikimedia.org/wikipedi...18A_Engine.JPG Last edited by Agnt004; 07-06-2008 at 03:53 PM. |
#866 (permalink) | |
#867 (permalink) | |
In colder weather below 50 the cylinder head temps should be low enough to combat pinging. Last edited by ryker; 07-06-2008 at 04:33 PM. |
#868 (permalink) |
currently traded my 95 dx civic sedan for a 08 si sedan and i luv the car it's like a HUGE step up from the old dx model.
Now Im sure this has probably been answered but i dont feel like going through 44 pages of this, I know that the si require 91 octane, could i feel up one time 91 and one time 89? cuz here in MA it goes 87, 89, 91. So would can i mix the mid grade and the higher grade 89 and 91? Thx guys i love my si |
#869 (permalink) | |
WHOcaREs05050
#870 (permalink) | |
![]() Premium is REQUIRED and only costs a little bit more per gallon. If you can't find the extra buck or two to fill up your car, then drive slower and hypermile for half the tank to make up the difference. Read the thread, good info in here.... |
#873 (permalink) |
Ok.. Good merged thread and I'm learning..
Problem: I'd love to put 93 (the std premium around here) in my roll (08 Si Sedan).. NONE and I mean NO PREMIUM available here. Rumors of one station but it's in the next town. That's how bad it is today. Tomorrow may be different. Cops and fights are happening at the tanks.. Time to go out into the desert and build a thunderdome and process pig poop and put master blaster in charge to keep the peace. hehehe :) But anyway... Currently I'm on about 1/2 tank of 89 mid-grade that was available last week at the pump. This week.. Nuthin' but 87. Beginning to get concerned. Found this thread searching for "knock sensor" if that tells you. I'm babying it.. eeeeeasy on the throttle, hyper-ing in neutral as much as possible (as I always try to do and hopefully this is not harmful to other.. transmission etc).. Shifts no higher than 4500-5kish. NO heavy accelaration. I may end up wishing it was an EX after all. :) |
#874 (permalink) | |
#875 (permalink) | |
Maybe look into adding some octane booster to your tank? Should work temporarily, and I don't think it could hurt. |
#877 (permalink) | |
| Gas Spike Because of Hurricane Rita - $5.00 a Gallon | webby | Water Cooler | 21 | 12-31-2006 01:30 AM |
| Exxon Gas Boycott - urges towns to do the same | webby | Water Cooler | 25 | 08-01-2006 10:22 AM |
| what grade of gas? | fps67 | Civic SI | 8 | 07-28-2006 10:04 AM |
