Hidy ho neighbor
VSA Light During V-tec?
I've noticed that my VSA light comes when I'm cranking into V-tec. This happens every time. I see it blink on then go away, then come back again as I'm reving, shifting, reving, etc. This happens even while I'm driving in a straight line. I have to guess that the VSA is sensing instability, and is reacting accordingly. So it appears that I will need to remember to disengage the VSA before I begin any spirited driving. Hmmm.
Has anyone else with an '07 Si noticed this?
It's just how the system works. If there is any abnormal movements in any axis - it'll just flicker, meaning engine will likely turn down and brakes will be engaged independantly. It really depends on how Honda calibrated the sensitivity of the sensors.
#5 (permalink) | |
I can get to the top of 1st and the top of 2nd (sometimes) and it breaks the tires loose with the OEM all seasons. My motor feels very strong, it was broken in very properly. :) |
Hidy ho neighbor
From Honda: VSA
This sophisticated safety device aids the driver in retaining control of the vehicle if wheel slippage is detected. When the driver is cornering or must make a sudden maneuver, the system can sense oversteer and understeer and can brake individual wheels and/or reduce power to restore the driver's intended course.
#10 (permalink) |
Robert
When you turn off the VSA the car should act the same as the 06's right? So i can turn off the VSA and the car will act as if VSA is not even in the car correct? Sorry thats the best i can word my question. I am planning on buying an 07 in about 6 monthes and this is kind of worrying me.
#11 (permalink) |
Hidy ho neighbor
You're right, I can deactivate the VSA (push the button). I just wonder why there would be a stability system that is needed to control the car while I'm under heavy acceleration. I mean it's not like this is a 1000 HP supercar.
#15 (permalink) | |
Robert
#16 (permalink) |
I accelerate pretty smoothly with my 07 Si....with the VSA ON....and the indicator light never really went on when I have done so...maybe like you said, the sensitivity level is slightly higher or something, or your tires were slipping.
I can chipr 2nd gear with vsa off...i cant do it with it on seems like lol...but nice to have for daily driving and still be able to turn off when racing |
#17 (permalink) | |
#20 (permalink) | |
Hidy ho neighbor
| Installed my 10,000K HID Conversion Kit!! Pics will come soon! | FatHoMedDigNitY | Lighting, H.I.D.'s, & Neon | 68 | 08-28-2008 01:51 PM |
| Need Help!!!!! 3rd Brake Light!!! | cornerstrike | Inside and Out | 12 | 11-13-2007 01:15 AM |
| HID Retrofit Progress | Tim | Lighting, H.I.D.'s, & Neon | 106 | 08-02-2007 01:04 PM |
| Save the Light | fiji06si13 | Water Cooler | 4 | 10-12-2006 09:18 PM |
| want to own luke's light saber? | webby | Water Cooler | 6 | 07-11-2005 08:07 PM |
