caliper paint ? - 8th Generation Honda Civic Forum
Old 07-01-2009, 04:45 PM   #1 (permalink)
BJFoster's Avatar
Brian Foster
caliper paint ?
i already painted my calipers red using the diy on this site, however i did a terrible job.(i used the brush kit). i want to re-do it, actually take the calipers off and spray them so its even.
do i need to strip the old paint? how do i go about doing this?
BJFoster is offline
Old 07-01-2009, 04:48 PM   #2 (permalink)
Chubs's Avatar
Token G35 Guy
goodluck. that shiz is hard to get off of even your hands...
Chubs is offline   Reply With Quote
Old 07-01-2009, 06:50 PM   #3 (permalink)
jeffs06si's Avatar
Jeff
sandblast maybe??
jeffs06si is offline   Reply With Quote
Old 07-01-2009, 06:59 PM   #4 (permalink)
BJFoster's Avatar
Brian Foster
ok well do you think i can just spray over it and it will come out even? its going to be the same color.
BJFoster is offline   Reply With Quote
Old 07-01-2009, 10:17 PM   #5 (permalink)
Falchon1's Avatar
Cody
I also painted my calipers, and even though I did a pretty good job, they got tore up from driving around in the winter up here. So I'm in the same situation as you, and the idea that I had was to throw a thin layer of primer on top of the previous paint, smooth it out, and then just use a better paint and more coats right on top. Anyone ever tried this, and if so what were your results?
Falchon1 is offline   Reply With Quote
Old 07-02-2009, 07:49 PM   #6 (permalink)
You dont really have to do all that, just paint using proper caliper paint and a foam brush - taking the wheels off gives you enough access to the areas that are visible. That's how I did mine.
vikram is offline   Reply With Quote
Old 07-02-2009, 11:25 PM   #7 (permalink)
jeffs06si's Avatar
Jeff
you have to take the wheels off...
Old 07-02-2009, 11:27 PM   #8 (permalink)
P1ng's Avatar
Ping
u would have to bleed your breaks if u took ur calipers off.. i wouldnt waste my time
P1ng is offline   Reply With Quote
Old 07-02-2009, 11:41 PM   #9 (permalink)
holtzy08si's Avatar
Eric
sand blasting would be the best bet....or you could use a wire brush attachment on a drill to get off all of the loose paint... then d-etch the area you want to paint with denatured alchahol... then repaint and let dry
holtzy08si is offline   Reply With Quote
Old 07-02-2009, 11:42 PM   #10 (permalink)
holtzy08si's Avatar
Eric
i cant spell for sh*t
Old 07-03-2009, 12:00 AM   #11 (permalink)
phoenixdrago12's Avatar
Paint Stripper!!!!
phoenixdrago12 is offline   Reply With Quote
Old 07-03-2009, 12:37 AM   #12 (permalink)
beast14's Avatar
Regis
lol i ma just spray paint my calipers ..
beast14 is offline   Reply With Quote
Old 07-03-2009, 12:49 AM   #13 (permalink)
camaroto07si's Avatar
Tommy
i got a litle overspray on mine so i used some paint thinner... make sure you dont get it on any plastic though cuz it will eat it.... heres mine...
camaroto07si is offline   Reply With Quote
Old 07-03-2009, 01:33 PM   #14 (permalink)
jeffs06si's Avatar
Jeff
I like the green^^^
Old 07-03-2009, 04:20 PM   #15 (permalink)
BJFoster's Avatar
Brian Foster
that green is dirty! well like i said i already did part of mine, sould i just spray over the old stuff? or will it mix terrible cause of the old 3 coats?
Old 07-04-2009, 12:39 AM   #16 (permalink)
CivicEX's Avatar
How did you mess it up with the brush? Did you lay the coat to heavily? I've never had a problem using the G2 kit (brush) If you take them off maybe some kind of acid bath or something to peel that paint.
CivicEX is offline   Reply With Quote
Old 07-04-2009, 03:32 AM   #17 (permalink)
badassdawg's Avatar
How did you get the Honda logo on?
badassdawg is offline   Reply With Quote
Old 07-04-2009, 03:39 AM   #18 (permalink)
no_torque's Avatar
Travis
They're from GrafiXpressions - Express yourself in vinyl form!.... Good quality vinyl decals.
no_torque is offline   Reply With Quote
Old 07-04-2009, 01:30 PM   #19 (permalink)
Tommy
yep he guess right...
Old 07-04-2009, 02:10 PM   #20 (permalink)
BJFoster's Avatar
Brian Foster
i didnt do the whole caliper. i got lazy and just did what was visible. i want to go back and do the whole caliper now.
Need help, which caliper paint to buy? 2xSi Inside and Out 9 06-09-2009 03:06 PM
Caliper paint ArmyofOne Inside and Out 15 04-15-2008 03:11 AM
Best Caliper Paint 27IVTEC Suspension and Brakes 21 01-06-2008 12:59 AM
Caliper Paint Cornflake79 Inside and Out 5 05-03-2006 10:13 PM
