Old 09-03-2006, 05:28 PM   #1 (permalink)
Yo Nadz's Avatar
Exclamation Grindin gears like WHOA!!!!!!
So...I drive the piss out of my SI. I drive it hard, and I ****** love it. I do seem to have a slight problem grinding gears sometimes at WOT. Not sure if it's the anxiety, or something wrong with the car. It doesn't happen all the time, but more than in any other manual car I have ever driven. Is there anything I can do about this?? Would the Comptech short throw make it harder to grind gears?? Figured I would seek some advice before I **** something up. Thanks for the input.
Yo Nadz is offline   Reply With Quote
Old 09-03-2006, 05:40 PM   #2 (permalink)
crazyj's Avatar
When I first bought my Si I ground the gears some getting into 2nd. The comptech didn't seem to make it easier to shift. But a heavy knob did make a difference. I think it a timing issue. I have gotten better at it and now after a few months of owing my Si I can shift like a pro.
crazyj is offline   Reply With Quote
Old 09-03-2006, 06:24 PM   #3 (permalink)
Doraemon!
marc-o-lishuz's Avatar
Marc
when driving hard, i only grind 3rd... either up/down-shifting. i think this is a common prob with the K20/6spd tranny combo.
marc-o-lishuz is offline   Reply With Quote
Old 09-04-2006, 01:38 PM   #4 (permalink)
Hey I always grind 3rd when driving really hard
6ft5inAllMan is offline   Reply With Quote
Old 09-04-2006, 01:46 PM   #5 (permalink)
duy2006si's Avatar
Shit I grind 3rd just driving regularly :rolleyes:
duy2006si is offline   Reply With Quote
Old 09-04-2006, 01:49 PM   #6 (permalink)
Ep3racer954's Avatar
FG*SQUAD #87
2nd is my biggest problem... it happens to me every once in while, i feel so imbaressed when it happens
Ep3racer954 is offline   Reply With Quote
Old 09-04-2006, 02:07 PM   #7 (permalink)
Doraemon!
Marc
for some reason, 3rd just doesn't engage as smoothly as the other gears... sucks. 3rd is such a fun gear too.
Old 09-04-2006, 11:03 PM   #8 (permalink)
negativezeroz's Avatar
The problem gear for me is 1st. Sometimes it will literally slip out when I give it gas so it just grinds. So annoying. It's like I have to really shove it to get it to not grind but it does that like mainly after a long time of driving (well probably cuz I get tired like it happend today after my 3+hrs of driving..lol)
negativezeroz is offline   Reply With Quote
Old 09-04-2006, 11:04 PM   #9 (permalink)
brooklynscat69's Avatar
exactly I got the same exact problem. 3rd gear seems to buck while yiou try to put it into 3rd
brooklynscat69 is offline   Reply With Quote
Old 09-05-2006, 09:05 AM   #10 (permalink)
I guess this is a noob question new to manual tranny but is bucking the same as grinding?
ShaggySi is offline   Reply With Quote
Old 09-05-2006, 09:19 AM   #11 (permalink)
No not the car bucking I mean like it seems as 3rd gear doesnt want to go into gear as easy as the other gears. And yes this is my first manual but when I switch gears the clutch is ALL the way down.
Old 09-05-2006, 03:56 PM   #12 (permalink)
Zesti1's Avatar
Joseph
+1
Zesti1 is offline   Reply With Quote
Old 09-05-2006, 04:02 PM   #13 (permalink)
LunchBoxed's Avatar
John
+1+1. Stoopid gear making me look dumb.
LunchBoxed is offline   Reply With Quote
Old 09-05-2006, 04:33 PM   #14 (permalink)
TheCrazy1's Avatar
I grind 2nd gear the most while driving hard and sometimes while downshifting. 3rd is just a PITA for heel toe downshifting for me! But then again, it could also be because I've only been driving manual for 3 1/2 months now... ;;
TheCrazy1 is offline   Reply With Quote
Old 09-05-2006, 04:50 PM   #15 (permalink)
rdss's Avatar
C.K.
I have the same problem, 3rd is the only gear I grind and it is when I just drive normal, I think it is more of a complasent/lazy shift problem!
rdss is offline   Reply With Quote
Old 09-05-2006, 04:50 PM   #16 (permalink)
RRSI's Avatar
Wade
+3
RRSI is offline   Reply With Quote
Old 09-05-2006, 04:54 PM   #17 (permalink)
aki
aki's Avatar
Resident Si Sedan Hater
I posted a new thread in the mech forum, but is this TSB from Honda or from the NHTSA? Was thinking of taking my car in but wanted to have some backup.
Make : HONDA Model : CIVIC Year : 2006
Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.)
Service Bulletin Num : 1205
Date of Bulletin: DEC 16, 2005
NHTSA Item Number: 10018868
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary:
TRANSMISSION GRINDS AT SHIFTS, SKIP SHIFTING.
aki is offline   Reply With Quote
Old 09-06-2006, 10:21 AM   #18 (permalink)
RedSIinPA's Avatar
Question
Summary:
is there more detail available for this?
RedSIinPA is offline   Reply With Quote
Old 09-09-2006, 03:16 AM   #19 (permalink)
Morvix's Avatar
Yeah because I can grind it every time in 2nd gear. The reflash helps a bit but it is easy. Run it all the way to the limiter, around 8300 or so and then shift right before the limiter, I bet you will grind 2nd gear from first. Now go and shift right as you see the needle pass 8k and I bet you will not grind.. It is kind of weird but yes I have the same problem. I brought it in and my former work buddy is the forman at the shop, drove him in it, they took apart the gearbox and put some honda lube on the gears and it solved it for awhile but it is back with a vengence now... And I am on my way to the dragon meet in 2 hours lol =)
Jeff T.
Morvix is offline   Reply With Quote
Old 09-09-2006, 04:04 PM   #20 (permalink)
slimfit's Avatar
I used to grind second all the time, but after 5000 miles it seems to have gone away. Maybe the tranny is just breaking in?
slimfit is online now   Reply With Quote
Whoa. Crazy Card trick atruhondagrl Water Cooler 4 09-03-2006 12:55 AM
Shifting Gears tim711 Civic SI 12 08-23-2006 09:56 PM
SPOON CAM GEARS!!!!!!!!!!!!!! dannyboy's06Si Forced Induction And Nitrous 8 08-17-2006 03:28 AM
Gears dont go in! vicSi Mechanical Problems & Technical Chat 9 05-08-2006 05:37 PM
*Vid* whoa..... Prototype Water Cooler 5 08-16-2005 06:51 PM
