shawn-o is half right, its there for a reason but people have raised it, I've heard of 9 even 10, but then you're just being foolish. A glance at a dyno will show you power starts to drop off up there anyway, no use it going that far, if you want more power, go fi.
-Spargo |
#7 (permalink) | |
I know that if the rev limiter fails than it may result in engine damage. But our rev limiters are set to a lower rpm than the car can actually handle. Our rev limiters are 8,300. As blu said the car can most likely handle 9,000 rpm's salfely. And the hondata reflash raises the rev limit. Last edited by dannyboy's06Si; 08-28-2006 at 01:33 PM. |
#8 (permalink) | |
The peak power curve is around 7800rpm so taking it much higher than that would be futile. Besides the fuel cut off hits around 8300 rpm... |
#14 (permalink) |
Valve float is:
http://en.wikipedia.org/wiki/Valve_float |
#15 (permalink) |
Even though 8300 to 8600 is not that big of a jump, Hondata probably raised it so we can shift where our rev limiter is right now without it occasionally cutting the fuel off if we don't shift in time.
I know I have hit the limiter a couple of times racing, Now if the limiter was 300rpm higher, I coulf still shift at 8300 without worrying about the fuel cutoff. That's not necessarily why they raised it, but that's how I would use it. |
#17 (permalink) |
There is an rpm span when the warning light comes on and blinks, and if you continue to increase the rpm, the limiter will kick in. I believe the warning light comes on at about 7800 rpms, then the limiter kicks in about 8300 rpm. I ask for your best advise here....when I feel like pushing my Si on an empty stretch of road just to feel it's capacity for power, I start in first gear and reach the warning light before I shift to second, and do the same going to third, fourth etc. Is this the best way to get the max power from the Si engine??
#18 (permalink) |
Getting the best power delivery out of an engine isn't about getting it as close to peak rpm as possible, it's also about where your revs drop to in the next gear. If you are dropping too far down in the powerband at each shift then you are not maximizing your power output.
If you don't wait until redline to shift in a stock SI then you are in danger of falling out of vtec, which is BAD BAD BAD for power output.. The k20 is a dog out of vtec. Of course with a reflash you can lower the engagement point but still if you shift before ~8200 you are slowing yourself down between shifts. Stock redline in the k20z3 is the perfect spot to shift to make maximum power, the problem is you are in danger of bouncing off the limiter which is even worse than shifting early because of the fuel cut. Hondata moves the redline up but that doesn't mean you should run it higher, ~8300 is a good shift point to put you right back into the sweetspot in the powerband. Of course modifications can change the powerband dramatically.. A little bit of headwork, titanium retainers/stoppers will allow your engine to rev much higher to make use of an even larger powerband. In stock form I imagine 9k would be destructive for the k20 but with some headwork it could be made to rev higher then 10,000rpm. Whether you have the other mods to make use of that wider powerband is a different story... |
| *INSTALLED* High flow Cat on 06 Si | dannyboy's06Si | Bolt-Ons And All-Motor | 7 | 03-15-2007 06:53 PM |
| Just Installed Hondata (new rev 8/1) flashed Ecu and injen CAI | my06si | Bolt-Ons And All-Motor | 8 | 08-05-2006 12:51 AM |
| High Beam/9005 Question | monkey323i | Lighting, H.I.D.'s, & Neon | 7 | 07-25-2006 05:36 PM |
| Rev Matching? | Silver8th | Garage | 39 | 06-09-2006 12:01 PM |
| Foglight & High Beams wiring | kicker_jace | Lighting, H.I.D.'s, & Neon | 6 | 06-07-2006 11:52 PM |
