#441 (permalink) | |
Eric
Also, when I push the clutch down, the rev hangs for about .7s - 1.2s, somewhere in that range... should I be getting my **** flashed too? lol it IS an 08.. so, I don't know if it is needed or not. |
#442 (permalink) | |
I wonder if these transmission problems are common. Like with the RSX typeS. |
#443 (permalink) | |
I can avoid the buckling feeling leaving for work without a full warm up, but it's impossible when going home. The reason is because there are alot of bumps in the parking lot of my job and it shifts my foot when i go over them, causing the car to buck even in third gear. |
#446 (permalink) |
Jimmy
My car takes over 5 minutes to warm up when I get off work and it's 34 degrees outside... It only buckles when it's cold... so I just warm up the engine. Even trying to to be gentle on the gas doesn't make the buckling go away... so you just have to be patient with it. It's not good to drive on a cold engine anyways..
![]() As for rev hang problems... or the 3rd gear problem... i've yet to experience it. An 08 Fa5, driven for over a year now. |
#447 (permalink) | |
1. Notchy / Hard shifting 2. Popping noise off my front suspension during maneuvers 3. Rev hang that needs reflash i really love my FG2, but im frustrated about this issues. |
#448 (permalink) |
Same behavior in my 08 SI too but I can live with it and it does make low rpm downshifts somewhat smoother. Hondata apparently knows how to fix this (ECU reflash). Why can't Honda get it right? Too bad Hondata won't do a low cost reflash that just corrects this issue.
#450 (permalink) |
Ken
anyone else have a 08 fa5? i do notice the bucking in the early cold morning but i think its because the car is not warmed up first...and as for the rev hang i do notice it on mine, but not experienced enough to really tell if it is a rev hang or not.
i would be in 3rd about 3500k and i press the clutch all the way down while leaving the gear in place (not neutral) and it is suppose to drop? |
#451 (permalink) | |
Jimmy
#452 (permalink) |
David
Mine stops the bucking when the coolant temp reads ~110-120F on my ScanGaugeII. I'm very gentle on my car until it's at least up to 150 and still pretty gentle on it until I see upper 180's for a little while.
To be fair to the Si, my 2005 CR-V has DBW and you can notice some bucking under the same circumstances even through the automatic transmission's torque converter which is VERY spongy compared to our directly connected manual transmission. This seems to be a problem with other K series DBW Hondas and not just our Si. As far as rev hang goes, I noticed it a little bit when I first bought the car but I can't seem to see it anymore. My bet is that I've just gotten used to the way it works. One thing I do love about the throttle setup is that blipping the throttle for a double clutch downshift is so easy in this car compared to others I've driven. |
#453 (permalink) | |
As for the tranny, no issues if the car has had a chance to really warm up... This goes for both my 06 & 08. My 06 failed to give me gears more often than the 08 but I always attributed this to cold temps, bad clutching or poor seating position... |
#454 (permalink) |
sorrie guys, but what do you all mean by buckling?
![]() well anywayz i know it is okay under 3k rpm, but it gets kinda slower upto 4k rpm...and then the nasty rev hang around 4.5k-5.5k rpm.... i showed this to my brother and he was like wtf???? you dont have reflash to fix this??? lol oh btw he owns a ITR and his is AWESOME Last edited by TW_FA5_SI; 01-11-2009 at 05:00 AM. |
#456 (permalink) |
David
It's a little like that but does it at all RPMs. It kind of feels like the throttle is opening/closing over and over again even though your foot is steady on the gas pedal. I have no idea if it does it above 3000 RPM or so since I don't take it that high when the engine is so cold and the throttle so touchy.
#457 (permalink) |
as weird as it sounds, i installed a K&N drop in air filter lastnight (19200 miles on stock paper filter) and it seemed to dramatically help the bucking when cold this morning. it was 26F this morning on my way to work. i will try it through the rest of the week and update you guys. supposed to be a high of 6F on friday.
#459 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/civic-si/12391-official-honda-reflash-information.html
| Mobile01 K20Z3 電子節氣門 issue... | This thread | Refback | 02-20-2008 03:12 AM | |
| Official Honda Reflash Information - Page 16 - 8th Generation Honda Civic Forum | This thread | Refback | 01-18-2008 09:13 PM | |
| Mobile01 K20Z3 電子節氣門 issue... | This thread | Refback | 01-16-2008 06:16 AM | |
| Official Honda Reflash Information - Page 19 - 8th Generation Honda Civic Forum | This thread | Refback | 01-10-2008 07:06 PM | |
| Official Honda Reflash Information - Page 32 - 8th Generation Honda Civic Forum | This thread | Refback | 12-20-2007 11:03 AM | |
| Drive by wire = LAG! - 8th Generation Honda Civic Forum | This thread | Refback | 12-10-2007 05:06 PM | |
| Mobile01 K20Z3 電子節氣門 issue... | This thread | Refback | 12-10-2007 12:44 AM | |
| Official 1.8L 1/4 TIMES!!! | Tikolx333 | Civic Coupe And Sedan | 100 | 12-18-2010 11:45 PM |
| Kind of interesting - Honda Chronology 1946-2005 | webby | Water Cooler | 7 | 05-27-2010 12:45 AM |
| Why the rarity? | honda93 | Garage | 41 | 03-17-2008 06:08 PM |
| US Si Prices Released | jasonandre | Civic SI | 88 | 12-14-2005 11:50 PM |
| 2006 honda world news | webby | Garage | 0 | 07-25-2005 10:31 AM |
