Official Honda Reflash Information - Page 22 - 8th Generation Honda Civic Forum
LinkBack (7) Thread Tools Display Modes
Old 06-20-2008, 12:06 PM   #421 (permalink)
Steve
Originally Posted by Sargeant_002 View Post
Anyone know if this is effecting any Si's as new as 08' - I have a sedan that doesn't drop like I think it should. Any video or a before and after comparison, or a after FOR comparison? My VIN ends in 84708600 - so I'm way out of range I'd say...but this sounds a lot like the behavior my car has. Hmmm...
Brian-
Honda says that the 2008 models are fixed.....I call BS on this. Shifting around town I have to shift at or below 3500rpm for it to be smooth, if I go higher than that the rpms hang and shifting is a PITA. Also, when it's cold first thing in the AM, the car does buck a little here and there. I say this wasn't fixed, but honda doesn't want to admit in 3 model years, they just haven't gotten it right yet.
Crusin_w00kie is offline   Reply With Quote
Old 06-20-2008, 05:21 PM   #422 (permalink)
TaI
TaI's Avatar
Same with my 08 SI, highing RPMS still exist in 08's...sigh
TaI is offline   Reply With Quote
Old 06-20-2008, 06:09 PM   #423 (permalink)
David
While the DBW characteristics are really subject to each of our tastes I realized last weekend that I like the way it works now that I'm used to it. I drove my old 2000 Accord last weekend which is, of course, a cable actuated throttle and it's hard as heck to blip the throttle and rev match compared to the Si. Just the tiniest tap and the RPMs go soaring on the Accord as opposed to my Si which is less sensitive at the beginning of the stroke due to the way Honda has programmed it.
I noticed the DBW hang when I first bought the car but now I've completely become used to it and find it better than the cable linkage systems I've driven previously.
I will knock it for the bucking when the engine is cold (stops around 110-115F coolant temp) but even on cold mornings it would climb past this in the 1/4 mile it takes to get out of my neighborhood and on the main street.
OrdnanceMarine is offline   Reply With Quote
Old 07-03-2008, 02:44 PM   #424 (permalink)
shiftyMc.shifterton's Avatar
nick
im a 2hgfg2 and have some mad rev hang that I am noticing not as much of a surge but that rev hang sucks in my oponion
shiftyMc.shifterton is offline   Reply With Quote
Old 07-03-2008, 02:54 PM   #425 (permalink)
nick
Originally Posted by TheDarkKnight View Post
If you want to start a petition, I'm in! I've called numerous Honda dealerships and they all give me the same answer.
im down for a petition
Old 08-04-2008, 05:25 PM   #426 (permalink)
UnlimitedSi's Avatar
yes, yes, yes.... it's a dagnagging design feature.
UnlimitedSi is offline   Reply With Quote
Old 08-09-2008, 02:16 PM   #427 (permalink)
Fernando
Question from an outsider...
Hi guys, does anyone know if there is a reflash for the brasil assembly 08 civic SI.
I ve got it for 20 days and I realised that my SI rev hang a lot..
Thanks for your help!!
nandito_SI is offline   Reply With Quote
Old 08-09-2008, 11:04 PM   #428 (permalink)
jamesfa5R's Avatar
JAMES CAPPS
what about cali?
jamesfa5R is offline   Reply With Quote
Old 08-26-2008, 01:40 PM   #429 (permalink)
Brian Lynch
I have a 08 and the rpm won't drop between shifts either. I hate it :Mad:. I took it to the dealer to fix it and they said there was nothing they could do to fix it. It drives me crazy. I called Honda and registered a complaint and got a case # . Anyone else with an 08 that has this problem should do the same so maybee they will look into it. At this time there is no fix for the 08.
Honda Cust. Serv. 1-800-999-1009
SI08 is offline   Reply With Quote
Old 09-07-2008, 11:30 AM   #430 (permalink)
jdmfg208's Avatar
Hector Lavalle
does mine fall in 708525 my bad im a noob so i can really use some help on dis thanks
jdmfg208 is offline   Reply With Quote
Old 09-07-2008, 03:56 PM   #431 (permalink)
jdmfg208's Avatar
Hector Lavalle
and what the hell is rev hang sry dis is my first actual mine manual car so im not familair wit da terms
Old 09-09-2008, 05:21 PM   #432 (permalink)
Ichiban's Avatar
I hope they come out with a TSB soon. It is really annoying. I don't know how bad it was before but this is rediculous. I can't drive it like I want without it being jerky. I used to own a 03 EM2 MT and I still like the feel of a cable throttle better, I may just be old fashioned. My friend's 06 RSX-S is a lot eaiser to drive smoothly.
Ichiban is offline   Reply With Quote
Old 09-09-2008, 05:43 PM   #433 (permalink)
David
It's either operator error or you have problems with the DBW system on that particular car because I have absolutely no problems with DBW on mine and actually like it a lot. Is there a chance that you're going back and fourth between a DBW and cable system? I will admit they are different but after just a little bit of time you get used to either.
Old 10-11-2008, 02:28 PM   #434 (permalink)
civic si 888's Avatar
Romel
I have an '09 Si sedan and it does the same thing. It really doesn't bother me but if they can do something about, then i'll have it fix (if it's free of charge!)
civic si 888 is offline   Reply With Quote
Old 10-12-2008, 10:05 PM   #435 (permalink)
iiVTEC's Avatar
Eric
I have an 06 si but my VIN doesnt fall into the category but i have the same problem:/
Im going to call my dealership to see what they will do.
Has anyone else tried this whos vin didnt fall into the category? did they fix it?
iiVTEC is offline   Reply With Quote
Old 10-27-2008, 11:37 AM   #436 (permalink)
OneEyeMan's Avatar
Lenny
Does this affect the 09 Si's, or did they take care of the software prior to releasing the 09's?
Thanks.
OneEyeMan
OneEyeMan is offline   Reply With Quote
Old 10-27-2008, 02:44 PM   #437 (permalink)
jaxson's Avatar
Thanks.
OneEyeMan
You'll still experience a slight rev hang and jerkiness when the car is not warmed up, but it is greatly improved from 06 models. I have an 08 and the car's behavior in the cold is my greatest complaint, and shifting into 2nd gear grinds if you do it too fast.
jaxson is offline   Reply With Quote
Old 10-27-2008, 05:59 PM   #438 (permalink)
OneEyeMan's Avatar
Lenny
Thanks
Old 11-03-2008, 02:14 AM   #439 (permalink)
IceMurder's Avatar
Chris
i have the hang as well, takes at least 2 seconds for the rpms to fall when i push the clutch in
IceMurder is offline   Reply With Quote
Old 11-04-2008, 01:30 AM   #440 (permalink)
Has anyone ever tried going to the dealerships with their 08 Si's and asking for a reflash? My 08 sedan still has annoying rev hang and surging/bucking in first gear.
woohooSi is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/civic-si/12391-official-honda-reflash-information.html
Mobile01 K20Z3 電子節氣門 issue... This thread Refback 02-20-2008 03:12 AM
Official Honda Reflash Information - Page 16 - 8th Generation Honda Civic Forum This thread Refback 01-18-2008 09:13 PM
Mobile01 K20Z3 電子節氣門 issue... This thread Refback 01-16-2008 06:16 AM
Official Honda Reflash Information - Page 19 - 8th Generation Honda Civic Forum This thread Refback 01-10-2008 07:06 PM
Official Honda Reflash Information - Page 32 - 8th Generation Honda Civic Forum This thread Refback 12-20-2007 11:03 AM
Drive by wire = LAG! - 8th Generation Honda Civic Forum This thread Refback 12-10-2007 05:06 PM
Mobile01 K20Z3 電子節氣門 issue... This thread Refback 12-10-2007 12:44 AM
Official 1.8L 1/4 TIMES!!! Tikolx333 Civic Coupe And Sedan 100 12-18-2010 11:45 PM
Kind of interesting - Honda Chronology 1946-2005 webby Water Cooler 7 05-27-2010 12:45 AM
Why the rarity? honda93 Garage 41 03-17-2008 06:08 PM
US Si Prices Released jasonandre Civic SI 88 12-14-2005 11:50 PM
2006 honda world news webby Garage 0 07-25-2005 10:31 AM
