#261 (permalink) | |
Ray
#263 (permalink) |
Alex Nguyen
Hey this is really great info. My car does fall in that range but I went to a dealer in early may or late april during my maitenence check and they siad they dont know what Im talking about. Also will they reflash my ecu if i've modified my engine and voided the warranty (i have a nitrous kit installed)
#265 (permalink) | |
Tom Smith
So it isn't a big deal. |
#267 (permalink) |
Walter
I bought my Si last year in February and noticed this problem a while back. I'm in Germany now and will be back in three weeks to have this done, and I'll repost as to what the service department had to say about this issue and if there was any hassle. Where can I find a pdf version of the service bulletin?
#273 (permalink) |
Lance
Why they engineered "Rev Hang"
It allowed the car to stay in the "vtec power band" for all subsequent shifts. Now a Hondata reflash would solve this, lowering the vtec point, but as stock I believe it is an engineered performance enhancement to keep you fat in the power band. Any comments? Any takers?? I haven't read anything on this subject to this effect, but that is my observation, and unless I do a Hondata reflash, I kinda like the rev hang less being abnormal to typical manual shifting cars. Now don't get me wrong. I do not believe that the engine designers at HMC knew this would happen, but after coupling such a light flywheel and seeing that at 8K this light spinning mass had no inertia to then slow it back down (ie: this is the real reason the revs hang-Honda Fits and I'm told some RX8s suffer from this as well), Honda engineers took advantage of it in the ECU programming to make it hang electronically longer that it actually does mechanically. That is why they can't completely eliminate it, becauser the mechanic side of this coin is a fixed variable, but rather they just improve it, by simply removing the code in the ECU that was designed to "let it hang-fat" for the next shift. That's what I think, and why I like rev hang. This would be a very good test. Any of you that have had the rev hang reflashed should race one of you that hasn't. My bet would be on the stock rev hanger, who would probably get 1/10s from 0-60, and maybe 2-3/10s in the quarter. Someone please confirm or deny this theory, or anyone in N. CA whose dealer reflashed their car care to race to check this out? Preferrably some one with an Injen SRI, and no other mods like myself. That would be apples to apples. |
#274 (permalink) |
Lance
I am 709XXX and I have the symptoms too. I think the published range is too small, or maybe just the first set of more ranges to come. I think more of us out here have the hang than applies to the range of VINs that is published. Why is that? Is it documented that HMC, internationally and nation-wide, used a different ECU program for our vehicles (with numbers larger than the last) and if so, why are we still experiencing the same symptoms?
#275 (permalink) | |
Lance
#276 (permalink) |
Walter
Happy with Reflash
I know some people have been stating the reflash didn't do much for them. My regards. I was fortunate enough, though, to have experienced a positive change as a result of having it reflashed. I'm sure it's true that it takes 20-30 min, but on the day I came in, they were busy, so I ended up waiting 90 minutes.
No more bucking or hesitation from the throttle in first gear when the engine is cold. The RPMs appear to drop faster, but not instantly, as soon as you let off the gas in 1st and 2nd. However, they do drop fast enough now that I have to change my driving still a little by giving it more gas when I shift from 1st to 2nd. The higher RPMs drop faster generally, and all around when the engine is warm. Flawless. The throttle feels more responsive, due probably to the RPMs, and not as "laggy" as it was before. Of course, there isn't much of a big change at the high end, but the lower end with all the bucking was driving me crazy. Now I don't look like a retard trying to learn a manual transmission.
#279 (permalink) |
Weezy B.
gonna check here in chicago, Illinois...will find out by tomorrow afternoon and post.
**btw quik question to anyone willing to answer.. Is this ONLY a problem for the 06 si? or does the 07 si also fall into that vin catagory http://www.8thcivic.com/forums/image...s/sadwavey.gif
LinkBack to this Thread: http://www.8thcivic.com/forums/civic-si/12391-official-honda-reflash-information.html
| Mobile01 K20Z3 電子節氣門 issue... | This thread | Refback | 02-20-2008 03:12 AM | |
| Official Honda Reflash Information - Page 16 - 8th Generation Honda Civic Forum | This thread | Refback | 01-18-2008 09:13 PM | |
| Mobile01 K20Z3 電子節氣門 issue... | This thread | Refback | 01-16-2008 06:16 AM | |
| Official Honda Reflash Information - Page 19 - 8th Generation Honda Civic Forum | This thread | Refback | 01-10-2008 07:06 PM | |
| Official Honda Reflash Information - Page 32 - 8th Generation Honda Civic Forum | This thread | Refback | 12-20-2007 11:03 AM | |
| Drive by wire = LAG! - 8th Generation Honda Civic Forum | This thread | Refback | 12-10-2007 05:06 PM | |
| Mobile01 K20Z3 電子節氣門 issue... | This thread | Refback | 12-10-2007 12:44 AM | |
| Official 1.8L 1/4 TIMES!!! | Tikolx333 | Civic Coupe And Sedan | 100 | 12-18-2010 11:45 PM |
| Kind of interesting - Honda Chronology 1946-2005 | webby | Water Cooler | 7 | 05-27-2010 12:45 AM |
| Why the rarity? | honda93 | Garage | 41 | 03-17-2008 06:08 PM |
| US Si Prices Released | jasonandre | Civic SI | 88 | 12-14-2005 11:50 PM |
| 2006 honda world news | webby | Garage | 0 | 07-25-2005 10:31 AM |
