#21 (permalink)
JerrfyLube: i wasn't debating the fact that synthetics last longer, i know that.
also i just wanted to state that my car is stock (airbox/filter, exhaust, etc.) and i use Synthetic oil in my car and i almost got to 5000 miles. i know with regular oil i'll be lucky to get to 3000. |
#22 (permalink) |
Voltaire Ilagan
well i know this was brought up alot but im still confused because i just changed my oil once it hit 20% and of course knowing that it would go back to 100% it didn't, it stayed at 20 and now that i've been driving for 4 days now it went down to 15%...
so ... help me out guys, wuts up with that?!?! is it possible that the oil life wasn't reset... is there a button that im not pressing?! last tym when i changed the oil for the first time on my si it resets back to 100% |
#23 (permalink) | |
#24 (permalink) | |
yeah use paragraphs, you give an aspirin a headache just follow what your car says, when it hits less the 15% go get your oil changed, or DIY. |
#25 (permalink) |
Oil consumption and this engine breaking in sound typical to me. Everything is fine, the consumption should cease ONCE its finally settled in...mine started to stabilize somewhere between 6-8000 miles. Now it has ZERO consumption. Oils also shear pretty fast in this engine. Fuel dilution can also cause thinning but I doubt that's an issue on a new Si. If worried get some UOA's done.
#30 (permalink) |
jose
i rarely crack V and my car killed 2quarts of oil and the light never came on saying it needed oil
then when i did add the oil it said it was low on oil should i take my car 2 the dealer (and i know its not leaking cuz theres no signs of oil leaks on the motor or under the car |
#31 (permalink) |
I don't see why people ebitch about cars burning oil. It is a fact of life on all engines that it will burn oil to a certain degree.
The PCV valve will suck out oil vapors causing your engine to consume oil. If you go into VTEC alot, guess what, you are pressurizing the head and it puke out oil into your intake tract. It is advisable to check your oil atleast once a week if you boost or VTEC alot. Otherwise every time you fill up will suffice. I do it and my cars always last longer than 10 years. |
#32 (permalink) |
Arbitor of Discord
The oil consumption issue with the Si was discussed A LOT during the first year or so after the car came to market (Dec '05). Numerous owners here, at ToV, FGCoupe, etc. reported oil consumption issues prior to their first oil change. With feedback and history from the RSX groups, this was put down to 'normal for this car', more so with higher, extended use of hi-RPMs.
As to "real-world' oil life, the only method that gives a 'for certain' answer is a UOA with TBN. As many owners are put off by the cost and inconvenience of actually doing so, all the net speculation continues... That is too bad as that little bit of cost and effort can show you more than your oil life, it can actually be used to detect certain internal engine issues well before they would normally become apparent through normal driving. And if you are a stats nerd, it helps control the OCD
#33 (permalink) | |
![]() Join Date: Oct 2007
Chris
I also do them on my CR-V... it does help with the OCD, though I strictly follow the MM and change at 15% with OEM fluids and a Mobil1 Filter. |
#34 (permalink) | |
Jeff
LinkBack to this Thread: http://www.8thcivic.com/forums/civic-si/11203-oil-life.html
| Oil change DIY? - 8th Generation Honda Civic Forum | This thread | Refback | 01-19-2008 08:01 PM | |
| oil leak - Page 2 - 8th Generation Honda Civic Forum | This thread | Refback | 12-31-2007 01:59 AM | |
| Oil Life - 8th Generation Honda Civic Forum | This thread | Refback | 12-09-2007 01:00 AM | |
| 5W-20??? Dealer insists? | BLU BY U | Civic SI | 66 | 05-04-2007 01:46 AM |
| Oil life ? | Randyg75 | Garage | 16 | 04-13-2007 05:26 AM |
| How does the oil life monitor work...... | LsedanX | Garage | 8 | 04-13-2007 03:54 AM |
| oil life reset? | Jetmech | Mechanical Problems & Technical Chat | 1 | 07-03-2006 08:30 AM |
| Oil life indicator and automatic doors locking | toms2080 | Mechanical Problems & Technical Chat | 17 | 06-12-2006 01:51 PM |
