#1 (permalink)
Installed Injen HAI, with dyno results!
Basically the new injen MR intake is a pile of ass. i ordered the CAI and recived the short one instead, i decided to give it a try because i really didnt like how the CAI version had a 90 degree bend right before the TB. Plus the MR version looks so much nicer and from what research ive done on CAI vs Regular was that they had similar dyno results. Well even with all my current mods , DCRH, Hondata reflash, 3" exhaust, hondata IMG This new Injen intake only made a whopping 4whp and 3wtq over the stock airbox
.It looks nice but the rubber elbow doesnt fit right, and its doesnt make any power. Its sucks ass dont buy it
your dissapointed? you should be happy you gained that. you wont see a huge gain on a CAI either. Everyone seems to think intakes add 15hp, nope. Go spend more money on a CAI for an extra 1-2 HP....then you'll be really happy.
As for the elbow.......you need to fandangle it a little. Ive done 2 injen SRI installs.......both went perfectly. |
Jon
4hp ontop of DCRH, reflash and exhaust? That's pretty good my friend. Advertised gains are off Stock setups. You have to remember when you add mods together you can't just start adding up the advertised whp gains and think your going to get magiaclly 30whp.
Look for things such as, does the car drive better in certain RPM ranges. Does it climb RPM's faster. 4 whp may not be much, but Intakes aren't meant for huge gains unless the factory set up is ridiculously restrictive. Remember that the Si tuned from the factory is pretty f'n good. The mods you have done have essentially moved your power band down and get your RPM's moving quicker. Now adding a intake to your set up is probably not gonna be something you'll notice. Simply because a) 4whp your not gonna notice and b) you already have the reflash which essentially plays that into the mix. Now you have a I/H/E reflash. Outside of other N/A mods, that's the best its gonna get. (TB, IM, Heads, etc...) This just goes to show how well the car was tuned from the factory and the engineering that goes into the car. IF you bought just an intake over stock, you would notice small, but subtle gains in driving and drivability. I don't have one complaint over mine. The install is a bit of a PITA, but its doable. In the end if your really unhappy with it, sell it and go back stock. However, your air flow is certainly traveling a much shorter route to the engine and isn't any hotter than stock. The whole point of the SRI. |
#7 (permalink) | |
50 LOW
The point of SRI is to add higher air flow (MORE) so that it'll preform better.
![]() Join Date: Jan 2006
Marvie
LOL....
anyone missed that he went from AEM CAI to injen SRI and make more power? i'd be happy. that being said....injen cai will give u even more gains.
#10 (permalink) | |
#11 (permalink) |
Marvie
the first dyno was with an AEM CAI, DCRH, E, IMG, REFLASH(look at his curve)....
the dyno with the HAI(hot air intake)=SRI was him removing the AEM CAI for the SRI(he ordered an injen cai and received the wrong part)...he still gained from the SRI which is very rare...goes to show how gained all throught the rpm range for that matter!!! 4hp up top...but it looks like 6 @ about 7200rpm....gains all through....i would imagine that the injen CAI would give even more through the whole range and probably up top.
#13 (permalink) | |
why is my 205whp bad????? |
#15 (permalink) | |
#17 (permalink) |
Marvie
^^^ that is right. "could" just be that.
hondata doesn't use a hub dyno....dynapack dyno = yes.
#18 (permalink) | |
Jon
#20 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/civic-si/11123-installed-injen-hai-dyno-results.html
| Installed Injen HAI, with dyno results! - Page 2 - 8th Generation Honda Civic Forum | This thread | Refback | 02-03-2008 01:52 AM | |
| Dyno Results for 06 Civic EX Auto with K&N Filter | fesersoft | Civic Coupe And Sedan | 23 | 07-25-2006 07:07 PM |
| injen sri installed... questions help plz | 2evolved | Intake & Spacer Discussion | 26 | 07-20-2006 11:54 PM |
| For those who had Injen CAi installed on the SI | type-si | Intake & Spacer Discussion | 1 | 07-20-2006 07:41 AM |
| Dyno results from new exhaust system | 06redsi | Civic SI | 26 | 04-05-2006 08:13 PM |
| Hasport dyno results... | pigman | Civic SI | 9 | 11-11-2005 10:03 AM |
