Old 07-08-2008, 04:56 PM   #41 (permalink)
WHOcaREs05050
Whocares05050's Avatar
If you plan on staying all motor, stick with the AEM.
Originally Posted by KingMarineM16a4 View Post
I'm the homosexual guy that got my sister pregnant.
Whocares05050 is offline   Reply With Quote
Old 07-08-2008, 05:39 PM   #42 (permalink)
1.8L FG KiDd's Avatar
FrAnCiS
hmmm...hondata reflash + F/IC ...sounds tasty
1.8L FG KiDd is offline   Reply With Quote
Old 07-08-2008, 05:47 PM   #43 (permalink)
soxfan143's Avatar
I am really considering switching to the AEM F/IC. Hey Mike, How does the Emanage Ultimate control timing? Do you know how it alters the timing? Is it the same way as the F/IC? I would think it would have to be pretty similar. How else would you change timing? Does the Emanage actually control the ignition firing? Or does it just delay the cam and crank signals?
soxfan143 is offline   Reply With Quote
Old 07-08-2008, 09:41 PM   #44 (permalink)
WHOcaREs05050
The E-Manage " alters " the signal to the coil packs. If you want a Emanage VS AEM FIC read, this is a great one by a guy who works with them every day!
http://www.dezod.com/files/FICvsEMAN.pdf
Old 07-08-2008, 10:24 PM   #45 (permalink)
soxfan143's Avatar
Pretty interesting. That just makes me want to get it even more and ditch the Ultimate. but he is comparing the Emanage Blue to the F/IC not the Ultimate. Isn't the ultimate alot more advanced? Does the ultimate function is basically the same way by altering the signal to the coil packs? Also there is an O2 sensor computer that has to be wired in for the Ultimate to do something. I'm not sure what that is yet but I hope to find out. I tried doing a search on this subject but I came up with a bunch of threads from this sitre and a few from the other sites. None really explained much about the ultimate and how it functions.
Old 07-09-2008, 09:36 AM   #46 (permalink)
WHOcaREs05050
Try reading over the ultimate in the first page again. I edited my post, and it may help find what your looking for. If not, ill get the info for you.
Old 07-09-2008, 01:57 PM   #47 (permalink)
soxfan143's Avatar
So basically, the only difference between the AEM and the ultimate is the fact that the AEM has a built in MAP sensor. It controls timing the exact same way. Altering cam and crank signals. If you add the GReddy pressure sensor you basically have the same control as the F/IC. If I am wrong please correct me. But if the info you added is correct then this is just as good, if not better than the F/IC. I'm just going to order up the pressure sensor next week and have my tuner do it that way. It will be way better than using Throttle position.
Old 07-09-2008, 02:32 PM   #48 (permalink)
WHOcaREs05050
Yeah, pressure sensor for sure. A few tuners ive talked to say that the AEM allows them to " fine tune " a little better than the e-manage, and that it dosnt " change " its tune / be inconsistant.
Whatever YOUR tuner recomends, and is more comfortable tuning with, than go with that. But that pressure sensor is worth every penny.
Old 07-09-2008, 05:51 PM   #49 (permalink)
y dosent someone do this...
TypeSi47 is offline   Reply With Quote
Old 07-09-2008, 08:57 PM   #50 (permalink)
WHOcaREs05050
Why dont you?
Old 07-09-2008, 09:40 PM   #51 (permalink)
soxfan143's Avatar
I'm going this route. I really hope my tuner will do it this way. I don't see why not. He said he was going to tune both ways. With the Throttle position and with the factory MAP sensor. So what would be the difference if he uses the GReddy sensor or the stock sensor? He's doing the same thing just with a more accurate sensor. So I should be fine with this. Hey Mike. Can I install the GReddy sensor but not activate it. If I install it and plug it in but not activate the port in the front panel option under the perameters will that be OK? I want to get the sensor next week and install it but not turn it on because it will obviously mess up my Emanage if i don't have it tuned right away. Correct?
ECM Technical Information and Tuning Capabilities blueroadster Forced Induction And Nitrous 77 08-28-2008 07:57 AM
Comptech Stage 2&3 Upgrades Excelerate Forced Induction And Nitrous 25 02-01-2007 10:17 AM
SEMA PICTURES & INFORMATION.... Type X Introduction & Pictures 68 11-13-2006 01:39 AM
Upgrades tomasro Civic Coupe And Sedan 4 03-20-2006 10:46 PM
