Old 06-12-2008, 08:17 PM   #1 (permalink)
99 civic SI suspension help
I have a 99 civic. it is currently lowered on tokico blues struts and H&R race springs. I want to bring it back to stock height. My friend helped me lower it a few years ago. He actually did most of the work.
Everything seems pretty straight forward. There is only one question I have. I know when you remove the whole strut assembly(strut ad spring combo) you're suppose to make sure the new shock assembly has the same orientation and position as the one i removed(so the top holes match up to the top tower as well as the lower part of the shock matches up to the fork(front) and lower control arm(rear). I did some searches, people were saying to make a mark on the top mount with the shock. I am unsure how i am going to do this as I am going to replace the old shocks with new ones.
I want to know waht is the best way to assure I can assemble the new shock/spring in the same orientation and position as the one i am removing.
bmcivic is offline   Reply With Quote
Old 06-12-2008, 10:52 PM   #2 (permalink)
Gimenez's Avatar
Luis Gimenez
Umm wrong forum buddy... I mean, wrong forum overall.
Gimenez is offline   Reply With Quote
Old 06-12-2008, 11:45 PM   #3 (permalink)
mikes-si's Avatar
Mark the top of the strut assembly with a straight like that is parallel with the bottom of the assembly that hooks up with your hub.. Should be extremely easy, from exerience of not marking it.. Do you have an aftermarket strut assembly or just springs up front? The back should be pretty easy, just put the bottom bolt in the shock first, then compress it with your hands and line it up and your home free!
mikes-si is offline   Reply With Quote
Old 06-13-2008, 12:28 AM   #4 (permalink)
i bought new struts and will be putting the stock springs back in
Old 06-13-2008, 12:38 AM   #5 (permalink)
mikes-si's Avatar
Ok, well i hope you have a decent shock compressor (ex: the strut tamer or something simlilar). it really cuts the time in half, and dont hold the top of the strut assembly by the 3 bolt heads, when its taken apart, as your bearing might fall and scatter.. causing a nasty noise when you turn
suspension help with 99 civic bmcivic Mechanical Problems & Technical Chat 0 06-12-2008 08:15 PM
'99 Civic Si Photoshoot! Slammed with new weeelz hoanger Introduction & Pictures 48 04-29-2008 08:24 PM
99 Mustang GT vs Civic Si SIg Autocross & Sanctioned Drag Racing 97 02-11-2008 12:53 PM
