crusing speed rpm?
so im driving down the highway and i notice im crusing at 70 mph but im hovering around 3000 rpm. Is that normal?
if it is, then does that mean if we get the urge to go 80 down an empty highway our mpg goes to hell because we're at 4000 rpm constant? |
Mitch Wall
Same here. There are sections of road on my semi-monthly 270 mile round trip commute where the speed limit is a constant 60 or 55 mph for extended stretches. I get phenominal fuel economy on those stretches. 3000rpm is just a little too high to spin the engine for optimal fuel economy.
#12 (permalink) |
Small engines need to rev higher on the highway because they lack the torque needed to run slower, also the Si revs higher than the R18 because it was designed for higher performance, so the gear ratios are shorter and closer togeather.
With bigger engines you can have taller gears, I had a 3.8 Sable that would turn about 2200 rpm's at 65 - 70. Last edited by volvo9; 06-10-2008 at 03:53 PM. |
#15 (permalink) | |
![]() Join Date: Apr 2008
Michael
#16 (permalink) |
You think the Si is bad, I used to have a 6 speed Wrangler.. Talk about crazy gear ratios.. I could start in 4th with no problem..
Anyway being close to i95 where cruising speed is generally 70+ your MPG does go to hell.. I just can't stand ALL those cars passing me when I'm in the slow lane.. |
| Speed vs RPM Chart for Reference | Gonzo | Civic SI | 17 | 12-29-2007 04:26 AM |
| Dyno top speed video - electronically limited and 9700 rpm | NiD4SPD | Civic SI | 90 | 10-18-2007 12:06 PM |
| Descent at freeway speed: higher RPM engine braking? | sammy1024 | Civic Coupe And Sedan | 5 | 07-08-2007 01:49 PM |
| Engine RPM at highway speed | Dan O | Mechanical Problems & Technical Chat | 3 | 11-14-2006 10:45 PM |
| Hwy crusing, car sounds like prop jet | bung_goo | Civic SI | 25 | 10-12-2006 09:21 AM |
