Go Back   8th Generation Honda Civic Forum > Model Specific Civic Information > Civic Hybrid
Old 04-16-2008, 11:15 PM   #1 (permalink)
Mirror signal light bulb removal...anyone done this?
I'm trying to figure out how to remove the signal light bulb on the side mirrors on the hybrid. Has anyone have a clue on how to remove it? Thanks for your help.
aarong_hch
aarong_hch is offline
Old 04-17-2008, 09:27 AM   #2 (permalink)
spinner's Avatar
It should be a non-serviceable part, the whole assembly, since the lights are LED. I doubt there will be many people with experience.
spinner is offline
Old 04-17-2008, 09:38 AM   #3 (permalink)
bengteck's Avatar
bengteck
if you're driving HCH2, these are the steps but bewarn do it at your own risk
put on gloves to protect both hand and sensitive part prone to scratches
carefully push on the top edge of the mirror
there's two clip below edge of mirror, use cloth and taped flat screwdriver to pry open
there's four more side clips(center) once slowly disconnect the lower clips
release the two hooks(top) friom the actuator and disconnect the two defogger connector
remove the four inner cover screws
pull out the turn signal lamp assembly
disconnect the 2p connector
it never mention if there's bulb inside or replace the whole assembly
bengteck is offline
Old 04-17-2008, 10:47 AM   #4 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
as mentioned no bulbs inside you have to buy the whole lens.
Originally Posted by ImTheVoiceOfGod View Post
I know it is possible, I see many people do it, but it wont allow me to post quotes in my signature.
Can someone webbyhelp me please
NBPRudy is offline
Hybrid Mirror Turn Signal - Which Bulb??? BRSi Lighting, H.I.D.'s, & Neon 7 04-18-2008 11:09 PM
Turn Signal Bulb Swap SiConvert887 Lighting, H.I.D.'s, & Neon 6 10-25-2007 09:22 PM
looking for 07 foglights and bulb for taillight signal Fr3sHlykaFoB Lighting, H.I.D.'s, & Neon 4 08-08-2007 10:36 PM
Turn Signal Mirror Modification webby Exterior Style Mods 0 02-22-2006 09:24 PM
