Go Back   8th Generation Honda Civic Forum > Model Specific Civic Information > Civic Hybrid
Old 04-07-2008, 04:17 PM   #1 (permalink)
Stock radio antenna on roof
Has anyone tried fishing a wire to run next to the existing antenna wire on a 2006 Civic Hybrid? I am wanting to install a small antenna on the car but the problem I have been running into is that when I run the antenna through seal between the trunk lid and the car it creates a gap that allows rain to drip into the trunk.
I do not want to install a bilge pump just because I have an antenna on the trunk.
Any suggestions?
2006_Civic is offline
Old 04-07-2008, 06:42 PM   #2 (permalink)
Resident ICE Wizard
if you're going to run a wire past any grommet, you'll need to seal it again. It is only designed to seal against whatever is in there fromteh factory. If you really need another antenna put a glassmount antenna on teh windshield above teh mirror
SuperJay is offline
Old 04-08-2008, 12:31 PM   #3 (permalink)
I thought about a glass mount antenna but thie antenna I want to put on the caris for amateur radio so it will be a somewhat larger amtenna. It will be about 1.5 to 2 feet tall and the glass mount antennas just don't do well for ham radio.
I was curious if anyone has actually run a wire / antenna out the same hole on the roof where the car's radio antenna is located. How much disassembly is involved in getting to that antenna? If there is too much involved I might just consider some other less appealing options.
Thanks for your reply! If you have ever done any work like what I am asking about I would appreciate some insight as to what is involved.
Thanks!
Old 04-08-2008, 06:01 PM   #4 (permalink)
Resident ICE Wizard
I wouldn't recommend doing that. you'd have to remove the headliner completely.
I've done this before; run your antenna next to the rear bumper, under the cover but over the bumper itself. This will give you added range over putting it inside the car. You can also add about 6dB of gain to the antenna with a small linear amplifier.
SuperJay is offline
Old 04-12-2008, 06:24 PM   #5 (permalink)
CaptainMess's Avatar
Anyone know where I can get a replacement of the fin or the cover on the roof? Truly I just want the look of it and not waste 500+ on XM.
CaptainMess is offline
Old 04-24-2008, 01:19 AM   #6 (permalink)
St. John Smythe
what is this antenna? i dont see it on any of the other models.
playaction is offline
Old 04-24-2008, 08:24 AM   #7 (permalink)
spinner's Avatar
The Civic Hybrid's radio antenna is mounted on the roof. The rest of the Civics have the antenna integrated in the rear window.
spinner is offline
Old 05-14-2008, 09:59 AM   #8 (permalink)
legendx's Avatar
They probably had to have the antenna on the roof because of the battery interference with the radio signal.
legendx is offline
FM radio antenna location isleepinadrawer Mechanical Problems & Technical Chat 6 09-20-2007 05:15 PM
Radio Antenna The1SloR/T Mechanical Problems & Technical Chat 7 03-10-2007 01:31 PM
The XM Antenna on the Roof.... Lucky13 I.C.E., Electrical, Security, & Navigation 7 01-20-2007 08:33 PM
XM Radio Antenna Location waross I.C.E., Electrical, Security, & Navigation 11 05-10-2006 12:34 AM
