CEL:Code P0135 - Heat Circuit Malfunction - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Model Specific Civic Information > Civic Hybrid
Old 03-14-2008, 02:05 AM   #1 (permalink)
Has anyone had the CEL come on? I just checked and a P0135 came up. I have an 08 hch, has anyone gotten this taken care of at the dealership?
aarong_hch is offline
Old 03-14-2008, 10:00 AM   #2 (permalink)
volvo9's Avatar
Andrew
Sounds like a dead heater element in an oxygen sensor. Should have no issues whatsoever getting it warranty'd.
Old 03-18-2008, 06:03 PM   #3 (permalink)
The dealership says that if i have aftermarket amps/speakers it can through a code and loose voltage to the 02 sensor.
aarong_hch is offline   Reply With Quote
Old 03-20-2008, 03:56 PM   #4 (permalink)
volvo9's Avatar
Andrew
What a load of sh*t...
They are making it up to avoid covering it unless the hybrid has a very veak electrical system, which I doubt.
Old 03-20-2008, 08:51 PM   #5 (permalink)
duk
duk's Avatar
Location: The part of your brain you know is right and can't ignore
amp and sub haven't affected me
duk is offline   Reply With Quote
Old 03-20-2008, 08:54 PM   #6 (permalink)
my wife just had that code...different type of car buy i believe the codes are all supposed to mean the same thing..
i believe it was - bank 1, sensor 1 (o2 sensor)
whtdvl is offline   Reply With Quote
Old 04-02-2008, 01:34 AM   #7 (permalink)
SuperJay's Avatar
Resident ICE Wizard
I have a 2500 watt system in my 06hch with just over 50k on it. I haven't even had a light dim on auto stop with the volume at 70 of 80. This is one of the most robust electrical systems i've ever seen, and I've been in car audio over 17 years. If the dealer tries to tell you that you SPEAKERS are to blame, call Honda America and tell the customer service center about your ordeal. Most likely they'll send you a coupon for a free oil change, at the very least.
SuperJay is offline   Reply With Quote
Brake options Moose Suspension and Brakes 1068 01-12-2012 04:38 PM
Heat wrap and underhood temp control ryker Civic Coupe And Sedan 8 09-15-2007 04:49 PM
Code P0135 - Heat Circuit Malfunction BlackSi10 Mechanical Problems & Technical Chat 11 03-12-2007 11:50 AM
Heat exchanger info for the guys running the Comp supercharger kits sheek360 Supercharging 1 12-01-2006 11:26 PM
