Cvt
hello,
first of all sorry for my english but i need to ask something. if i drive with my car and i see a light jumping on orange then i switch from D to S so my car will slow down more and then i don't have to brake hard. but i wonder if this is ok with the cvt, because i don't wanna break it. |
The S and the L are there to be used. You are going to get less regen when you use that, and if you're having to jam on the brakes maybe you should re-evaluate your driving style. I do not know if the laws there are different about stopping for orange lights, but I know here, if you're close enough that you'd have to stop short, you have enough time to go through it instead. If you see it from a ways back, you can use the brake pedal just enough to get the charge bar filled up without having the friction pads used, and you'll roll slowly getting some distance even during idle-stop.
The S is useful to force battery regen when you first start the car. The car saves gas while coasting but the normal functions don't work until its warmed up. Forcing the regen helps build heat and improves your gas savings.
As for break wear its a hybrid. You brake anyhow during regen. Its always going on so forcing a regen with S is no different that using regen while coasting except you can use S while the engine is still cold just after starting. |
#7 (permalink) | |
Helps build heat: yes better mileage: NO. If it did, then honda would just set the car to rev higher when first warming up. |
#8 (permalink) | |
Were talking 1 if even mpg increases here but to some people every bit counts. |
| Rice thread, can you beat it? | Civic Pride | Garage | 8625 | 08-07-2008 01:45 PM |
| Mugen Civic RR...Tsukuba in 1'06" | jeff2417 | Civic SI | 83 | 12-19-2007 02:47 AM |
| Accord vs. Altima vs. Camry - Full Article / Comparrisson | cbondhonda | Honda Industry News | 0 | 06-28-2007 10:49 PM |
| why no CVT for the civic? | leonsphinx | Do It Yourself Articles | 5 | 11-13-2006 09:40 PM |
| CIVIC EX WITH NAV BLACK | VICHONDAEX | Introduction & Pictures | 14 | 07-19-2006 08:34 PM |
