Go Back   8th Generation Honda Civic Forum > Model Specific Civic Information > Civic Hybrid
Old 02-16-2007, 10:36 AM   #1 (permalink)
Hybrid Suspension Upgrade from Si
Hi All... my first post here as I just got a 2007 Civic Hybrid on Sunday. So far it's been great, just slow. It's been kinda tough finding hybrid specific posts too!
I've got an order put in for an '07 Civic Si's front and rear sways, and now I've seen how cheap it is to get a used Civic Si's suspension. From what I've read nearly every suspension component is interchangeable between any 8th gen civic. However, given the Hybrid's added weight and different weight distribution with the batteries, is there anything I should be aware of before ordering some struts and springs? The Civic Si coupe's suspension should drop right into the Hybrid sedan right?
I'll probably be leaving the tires and wheels alone for cost reasons (even though they probably are the weakest link in the handling department).
Thanks for the advice!
Bun707 is offline
Old 02-16-2007, 09:10 PM   #2 (permalink)
Tim
non-Cilantrist
Tim's Avatar
Were I you, I'd use the Si sedan suspension.
You'd be the first to attempt such a swap as far as we know. So far, people have swapped Hybrid parts *onto* their non-Hybrids (the coveted LED mirrors), and they've wanted to swap other parts (the automatic climate control), but I'm not aware of anyone having done the reverse.
Welcome to the 8th, by the way!
Tim is offline
Old 02-16-2007, 11:57 PM   #3 (permalink)
honda93's Avatar
Slow helps you average 45+ mpg.
Get whatever is available. More people will offer their Si Coupe suspensions for sale simply because more of them have been produced thusfar. But yes, any 8th Gen Civic setup will work.
The tires are a large part of why the car handles like shit, but they are a large part of why the car averages 45+ mpg. You are ultimately going to have to decide if you want the handling or mileage, because a simple tire change will not allow both. Lopping 20% of the cars mileage puts you slightly above the regular gas Civic LX/EX models and I doubt you'd want that.
Anthony "Mario" Crea
honda93 is online now
Old 02-20-2007, 10:02 AM   #4 (permalink)
Thanks for the advice... I'm not sure if I'm going to do the suspension upgrade right now. But it's nice to know it's an option. If I do it, I'll be sure to post about my experience and throw some pictures up.
As for the tires, on my wife's Prius I switched out the Goodyear Integrities for Goodyear TripleTreds and noticed a descent jump in handling, but mileage dropped from about 52mpg overall to 47mpg. I know many of the Prius owners had good luck with the Hydroedges. Definitely if a new set of rims and tires wouldn't set me back a grand I'd do it.
Bun707 is offline
Old 04-22-2007, 11:40 AM   #5 (permalink)
Robert
Thumbs up Si vs. non SI suspension upgrade on your HCH
Hi - I've been working on this decision for some time for my 06 HCH- even calling companies like H&R and Honda Racing R&D to get thier opinion.
Most say "give it a try, and let us know if it works" - lol
Most knowledgable advisors have said to go for the Civic, but not the SI choice though. I have plans for a full coilover system, because most importantly, you need to be able to adjust the camber after you are done - unless you leave it at the stock ride height. I plan to lower about 1 1/2" to improve the cornering. At least, you need to add in a camber adjustment kit front and back to make sure that you have the maximum tire patch on the road when you corner - that is the actual goal of any suspension upgrade.
You will be wasting your money to have a nice stiff suspension - with your tires running on their edges !!!!!!
The good news: I tested my stock suspension last week with both the stock wheel/tire combo, and then with a racing wheel'tire combo at Portland International Raceway. The HCH impressed everyone with its ability to take a set while cornering - even with the STOCK suspension. The front would take a dive on entry, but then would balance and sit on a nice steady set for the corners.
Even without any suspension work - the HCH is an awsome, well balanced handling setup.
The bad news: I got blown away on the straights as the best I could muster was 90 mph on the front and back straights. Other problem was that the stock wheels held in a lot of heat in the front brakes -- get some ultra lite 17" racing wheels/tires if you ever plan to really drive your car hard.
Overall, my times were about 5 seconds slower per/lap on the 2 mile roadcourse track than other cars that I have driven there, but I did put on quite a show in the corners, and 5 seconds isn't too bad considering the horsepower.
I'll be happy to keep in touch with you about your suspension adventure, and will let you how I decide to approach my decision as well.
Robert
Robert J is offline
Old 06-12-2007, 09:16 AM   #6 (permalink)
I just ordered Eibach Pro kit springs for my '07 HCH. $207 shipped from Tirerack.com
I'll post pics of the install and before and after shots once I'm done.
I'm just looking to get rid of the huge tire/fender gap and maybe improve the handling a bit. I don't think it'll affect mpg. I plan on keeping the stock rims and tires (for now).
87turbolook911 is offline
Old 06-13-2007, 09:45 PM   #7 (permalink)
Jim
I have the complete SI suspension on MY06 Hybrid. You can read my post here...
Suspension swap
The only thing which is not plug and play is the front and rear swaybar bushings and chassis brackets. End links are ok.
The front struts and rear shocks N springs are a easy switch... you love the handling I do !
Yes the coupe suspension fits the sedan... as in my case.
wrxsti03 is offline
My Official Suspension Upgrade Info and Pics Thread Cookstar Suspension and Brakes 69 09-27-2007 10:38 PM
2006 Honda Civic Hybrid Wins 'World Car of the Year Award' for Greenest Car webby Honda Industry News 3 08-12-2007 10:13 PM
2006 Honda Civic Hybrid Pricing Released webby Honda Industry News 0 11-30-2005 10:08 AM
2006 Honda Civic Hybrid Pricing Released webby Civic Hybrid 0 11-30-2005 10:08 AM
August '05: Record-breaking Hybrid sales for Honda and Toyota shoptb Civic Hybrid 13 09-05-2005 07:46 PM
