#22 (permalink) |
Tom Stodola
My '06 Civic Hybrid has 113,000 miles on it. Still gets 40+ mpg. If you start messing with the exhaust in intake to get more speed you will violate CA smog laws and probably mess up the computer control. If that happens you might as well chuck it in the scrap yard because there is no upper limit on costs to bring it back to OEM.
I have no problem with getting the car up to speed, but I don't try to exceed 72 mph even in the carpool lane (it is not a "faster than the speed limit lane"). your car (and mine) are the first year of the 2nd generation model Civic Hybrid. I am guessing you have replaced your tires and unless you used low rolling resistance tires (like the OEM) you will notice a slightly more sluggish response across all speeds. Don't be to quick to think the Prius is the holy grail of hybrids - they have their issues as well (and not just the quirky brake transition when going from gas to electric mode). I personally cannot see going back to a car that gets 20 mpg after having one that consistenly gets 40, carpool lane sticker or not. |
#23 (permalink) |
Dan
i see what your saying thats why i only recommended a drop in k&n filter and a stock si catback exhaust. neither of these 2 item should do anything bad to the vehicle or irreversible. nor are they a violation of any emissions laws.
#25 (permalink) |
I got the latest software updates installed and the car holds the CVT RPM much higher. The car is much more responsive and as a side effect the brake feel is markedly better. Perhaps the reflash and recalibration of the ECU, CVT, and hybrid battery will be all that this car needs.
If you guys haven't already, I highly recommend the 09-058 TSB update. |
#26 (permalink) | |
My mom has a second-generation Prius. I've driven it for maybe 30,000 miles. Comparing the two cars back to back, I think the Prius has a much more robust hybrid system than the one on my current Civic. I know exactly what you are talking about with the traction control/VSC cutting braking and also power. That said, our Prius has 97,000 miles on it and it's still driving like new. It doesn't feel underpowered compared to my my Civic Hybrid which is still quite a bit slower.
#29 (permalink) |
Wow! The TSB update has increased low-end torque and also improved my mileage by about 2.5 miles per gallon. Also, it has made my brakes stop better. It seems like the threshold of engaging the friction brakes is now higher. The electric brakes seem to be doing more of the work resulting in more regeneration and less pedal effort.
If you haven't gotten the latest updates from Honda, go and get them. It drives a lot better. The transmission clunks from switching into S mode when cold are gone, too. Last edited by smmmurf; 02-16-2010 at 03:19 AM. |
#30 (permalink) | |
#31 (permalink) | |
Read this thread to find out all you need to know: Tsb 09-058 - GreenHybrid - Hybrid Cars |
#33 (permalink) | |
![]() ![]() it's like ur giving him hopes and taking them away at the same time... Last edited by nayilsi; 04-18-2010 at 09:40 AM. |
#34 (permalink) | |
| Fastest all motor R18? Fastest power adder R18? | Matauz | Autocross & Sanctioned Drag Racing | 70 | 03-24-2011 02:14 PM |
| Reliable Horse Power??? | Socal_SI | Bolt-Ons And All-Motor | 7 | 08-24-2009 12:59 PM |
| Slow_Si’s Major Power-Adder. | Slow_si | Forced Induction And Nitrous | 22 | 09-11-2007 12:09 AM |
| Honda Civic most reliable compact | moxom | Garage | 8 | 08-11-2006 03:00 PM |
