hybrid wheel weight? - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Model Specific Civic Information > Civic Hybrid
Old 11-27-2008, 03:53 AM   #1 (permalink)
hello,~ i picked up my hybrid last week and damn.. the wheel is hella ugly that i want to get a rid of it asap..
anyhow my question is.. what's the weight on the stock wheel? also the weight with the tires.
i am thinking putting 17" or 18" enkei rpf1 which it weights 15lb and 17lb.. however the weight on the tire would be a little lighter cuz it's less fattin than 195/65... i think..
09hybrid is offline
Old 11-27-2008, 11:14 AM   #2 (permalink)
You will still loose power and mpg if you get a larger wheel (even if it is lighter). The sheer size of the wheel also needs to be put into consideration. Think of gears on a bicycle. The larger gears require more effort then the smaller ones
Blk_07_SI_Sedan is offline   Reply With Quote
Old 11-27-2008, 11:22 AM   #3 (permalink)
Chase's Avatar
Chase
Now that depends on a lot more than that alone, The larger wheel also effectively makes your gearing taller, so cruising at the same speed (65mph or x speed, whatever) would net you a lower engine RPM theoretically burning less fuel on a level surface.
Chase is offline   Reply With Quote
Old 11-27-2008, 11:27 AM   #4 (permalink)
Tod
Not if you keep the same OD (which is what you should do) For example Civics come with 15's (Hybrid & DX-G) 16's (LX & EX) & 17's (Si) but they all have the same outside diameter so that the speedo remains the same. (in fact the 16's are a hair taller than the 17's)
Solo2EG is offline   Reply With Quote
Old 11-27-2008, 11:29 AM   #5 (permalink)
Chase's Avatar
Chase
I believe going from a 17" wheel on the Si to my 18" wheel with 225/40's changed my Speedo to read .5mph fast which is acceptable. It seems on modern cars they should allow you to "set" your wheel and tire size so that your ECU can compensate and calibrate your ECU's. Oh well..
Old 11-27-2008, 11:58 AM   #6 (permalink)
Tod
Actually your speedo is now off by 1.8% (when speedo reads 60 you're actually doing 61.1). There is a great calculator to use here:
Wheel / tire size calculator / comparer - WHEELSMASTER
Old 11-27-2008, 12:00 PM   #7 (permalink)
so going back to the subject.. what's the weight on stock wheel?
09hybrid is offline   Reply With Quote
Old 11-27-2008, 12:10 PM   #8 (permalink)
Tod
Sorry about that, I'm not sure but I'll try to look it up, I know it's very light I have a set in my Garage (my brother's summer tires).
Don't forget the light weight isn't the only reason Honda put these on the hybrid, the flat face is also very good to reduce wind resistance so if you were to put on a wheel like the RPF-1 you will lose some of that benefit (but I will admit, you will be getting a much better looking wheel...)
Old 11-28-2008, 02:51 AM   #9 (permalink)
Chase's Avatar
Chase
I have verified my incorrect speedo by GPS and local Military police. it is consistently .5mph fast.
Old 12-09-2008, 08:45 PM   #10 (permalink)
You wont find any tires that are even close to the light weight that the hybrid wheels come with. Those tires are 18lbs.
Getting any other tire will up the weight big time.
most 17 inch tires are 25lbs in our sizes.
and in 15 inch, ur looking at around 22lbs
pks17 is offline   Reply With Quote
Old 03-19-2009, 09:35 AM   #11 (permalink)
... minor update... found a couple of 17" 5-zigens that are 15.5 lbs!
FN01R-C Hot Version: 17" x 7" 5/114.3 ET42 Lbs: 15.5
That's a total wheel/rim weight saving of 10lbs. They are soooo gonna replace my pancakes. The pancakes will downgrade to winter tires
Mind you that the new 17" tires (not wheels or rims) will differ in weight compared to the 15" (195/65/R15) too,
but at least you oughta get close to the 'standard' weight.
Here's the difference in circumference (delta) of 17" compared to those 15" standard pancake with two types of tires:
215/45/R17 = -1,45% delta compared to standard (70mph = 68,99mph)
Difference in circumference = 1964,44 (standard = 1993.34)
215/50/R17 = 1,94 % delta compared to standard (70mph = 71.36 mph)
Difference in circumference = 2031,98 (standard = 1993.34)
The choice between 45 or 50 is a matter of more comfort/more total weight (wheel + tire)
versus looks/less weight.
Just my 2 cents...
HCHybrid is offline   Reply With Quote
Old 03-19-2009, 11:08 AM   #12 (permalink)
Arrow
I used to believe the popular theory about wind drag being one reason for the wheel design, but now I think the pie plate wheels are just a marketing gimmick to hybridize the look of the standard Civic. The reason for my doubt? If you go the UK Honda website, you'll see their standard and upgraded Civic Hybrids... NEITHER car uses the pie plate wheels. They use ordinary-looking spoke wheels for the base model (15") and the upgraded model (16"). Not a pie plate wheel anywhere. It'd be interesting to find the weight of the UK versions' wheels.
stevenvillatoro is offline   Reply With Quote
Old 03-19-2009, 11:19 AM   #13 (permalink)
Arrow
Originally Posted by HCHybrid View Post
The choice between 45 or 50 is a matter of more comfort/more total weight (wheel + tire) versus looks/less weight.
I'd stay away from 17" on the Civic Hybrid. If you've never experienced the great loss of comfort by going to such a low-profile tire, you're in for a big surprise. There simply isn't enough rubber sidewall height to cushion the ride for most people's tastes. It would be even more pronounced in the Civic Hybrid if you are used to higher tire pressure inflation to enhance fuel economy. Another drawback is that every rattle and interior noise is magnified when using low-profile tires. Finally, low-profile tires are also more susceptible to damage by potholes and road defects, and much easier to scratch when parking. A 16" rim/tire combo would be the largest I would ever consider, based on personal experience only.
Old 03-19-2009, 12:00 PM   #14 (permalink)
GoHuskies's Avatar
I'm me
Um... It might vary but all of the European/Asian members I've seen had the same pie plate wheels stock. They use the same pie style wheels on the base Fit & Civic in Canada too to help increase MPG slightly.
GoHuskies is offline   Reply With Quote
Old 03-19-2009, 12:10 PM   #15 (permalink)
Arrow
Here's the link to the UK Honda Civic Hybrid site.
Old 03-19-2009, 12:18 PM   #16 (permalink)
IMHO I dare to differ an extreme high loss in comfort with a 215/50/R17 setup. Next to that I don't consider a height of 50 'low-profile'. Plenty of
cushion left on that height.
I've spoken to a few Hybrid drivers with this setup and they don't have any complains about them what so ever. But don't get me wrong...
it never hurts to drop a 'heads-up' over here... better warned ahead then sorry afterwards. I've also test driven this 17" inch setup myself and I can't find any problem you mentioned above at all.
I do agree that people need to make a well made choice on this subject.
One thing's for sure though... 17" looks WAY better than the 2008 15" pancakes.
Old 03-19-2009, 12:26 PM   #17 (permalink)
GoHuskies's Avatar
I'm me
To Steven:
Are you sure that the UK model pictured isn't wearing the optional 16" alloy wheel? It's listed as an option for the civic trims.
Old 03-19-2009, 12:52 PM   #18 (permalink)
Arrow
Originally Posted by GoHuskies View Post
To Steven:
As sure as I can be. If you check out the site, you'll see pics of both the 15" and 16" rims. There is not a pie plate rim on the entire site. Look at the nice chrome door handles while you're there... they have body-colored inserts. Or, how about that rear center armrest!
Old 03-19-2009, 04:03 PM   #19 (permalink)
GoHuskies's Avatar
I'm me
All I can add is I looked for around and at least according to hypermilers over at cleanmpg.com and places the test cycle used over that side isn't as demanding as our own EPA testing. Which is why even when you convert over to US mpg Euro models of the same car have higher ratings than the US trims.
I know in the UK they've begun using tolls and taxes to punish people for what comes out the tail pipe. Perhaps the average UK hybrid buyer is more concerned about emissions so a more attractive car is given?
Old 03-19-2009, 07:27 PM   #20 (permalink)
Stock Hybrid wheels: 17lbs Stock tires: 18lbs
I just bought new Yokohama tires(4) that weight 19lbs ea and i lost 2-3mpg.
I'm going to buy Rota Slipstreams($500 or less) in the 15in that weight 11.9 to 13lbs to bring back the higher mpg i lost.
aarong_hch is offline   Reply With Quote
Tire weight vs Wheel weight torreypinesguy Wheel And Tire Upgrades 9 05-25-2008 02:15 AM
Wheel weight... Primetime619 Wheel And Tire Upgrades 6 07-03-2007 05:57 PM
Wheel Weight Daemones6 Wheel And Tire Upgrades 1 09-08-2006 04:50 PM
Weight of '06 Civic Hybrid alloy wheels? SamIV Garage 6 01-18-2006 01:30 PM
