Rear drum brakes?
So I kinda just figured out that the rear brakes are drum style and not disc style. While I was getting my X5 at the BMW dealership serviced (oil change), I was talking to the service guy about the difference between disc and drums brakes. Basically, he said your X5 comes with Disc brakes because they are much superior to drum brakes.
So, I don't know a lot about car modifications, but can I get a shop to change out the brakes on my Hybrid to disc rear brakes? Would this affect the charging of the IMA battery? The brakes aren't bad, they are good, but they are definitely not like my X5's. Thanks in advance! |
I'm me
I'd research on how the car regains energy via braking. Friction from braking in turn turns the electric motor and enables it to charge the battery. Not sure if it's drawn from front or rear. No idea if changing out the brakes will affect the system either. Couldn't find an answer on wiki either.
CleanMPG, An authoritative source on fuel economy and hypermiling I'd head over there ask pose the question in general forums. Pretty knowledgeable folk. |
In my opinion you wouldn't see enough benifit from the disc brakes to be worth the cost/time/effort.
Disc brakes offer several advantages over drum. Then are simpler (less moving parts), offer much better heat dissapation, and far less fading when they do heat up. Drum brakes are generally cheaper, they can offer the same stopping force with much less effort, and with a much smaller cylinder. Disc brakes are the obvious choice in high performance situations where you will be using the brakes a lot, or very hard and want minimum heat buildup and fade. On larger vehicles where cargo/towing comes into play they can also be useful for when you have to stop a load and heat can build up fast. On your car you aren't likely to push the brakes to their limit very often. When trying to get good fuel mileage it is best to push the brakes as little as possible. This cost/benifit likely why Honda put drum brakes on the Hybrid to begin with. The amount of benifit you would get from upgrading would likely be minimal if any. Probably not worth the trouble. However, if you want to do it for looks, brake feel, or just because then go for it. The only thing that really matters is if it's worth it to you. Last edited by BigT; 08-07-2008 at 09:35 AM. |
Stephen
Not one person mentioned you'd also destroy your front/rear braking bias that the car has when stock. The ABS can only compensate so much before it doesn't know what to do in an emergency braking situation.
The best thing to do is upgrade the pads in the drum brake and front brake. You'll get increased performance from this. |
#6 (permalink) | |
#7 (permalink) | |
I'm me
Now that I think of it I have no idea even how the regen braking works, wether part of the mechanical brakes or friction applied somewhere else. Wiki or Honda websites are of no help. |
#8 (permalink) | |
Resident ICE Wizard
3.2 VTACKK YO!
![]() Join Date: Apr 2008
Andrew
Yeah good luck. LX owners have contemplated a drum to disc swap only to come to find it would cost around $1000 and would require an ass load of work.
Until someone comes out with a conversion kit there is no practical way to do a drum to disc swap.
![]() Former: 2006 NHBP Honda Civic LX 2DR 5MT Current: 2006 WDP Acura TL 6MT |
#11 (permalink) |
3.2 VTACKK YO!
Andrew
I suppose you could just yank the whole rear suspension and have every thing you need and more. IDK how much that would cost though.
I don't know if I would want to replace the perfectly good stock parts on my car with ones I found in a salvage yard though. Especially something as important as the brakes.
#13 (permalink) |
3.2 VTACKK YO!
Andrew
I think EBD controls the proportioning, and I think the EX and LX master cylinders have the same part number.
#16 (permalink) |
bengteck
There’s few consideration to ponder upon if you wish to touch such modification, namely if it’s for aesthetic or performance. Both have its good reason for the conversion.
Just like a normal civic, they upgraded their disk with a bigger size rotor to achieve their specific requirement. So via upgrading from drum to disk just another form of upgrade most will do for their ride if you can just forget about you driving a hybrid. For aesthetic reason, it’s due to rim change to alloy and it’s fully visible. For performance, it will definitely improve on handling when you require tackling the corners at high speed as back end tends to slip at that speed. For me it’s due to both reasons I opted to change them but no luck yet for a used set as I’ve set a budget on the upgrade. The only costly items will the new knuckle replacement as it must change to accept the brake assembly as the current ones do not support them. As for those still wondering on the Assist/Regenerative Control at deceleration work, here’s how. During deceleration the IMA motor driven by the wheels function as a generator. It charges the battery module by generating electrical energy. This is done by converting the kinetic energy of the vehicle during braking from the front wheels into electric energy that is stored in the IMA battery. When the battery module is full, regenerative stops to prevent overcharge of the battery. |
#17 (permalink) | |
Resident ICE Wizard
Also, I think I can weld a mount onto the existing arm without changin the entire rear linkage. do you know anything about this? is it possible? |
#18 (permalink) | |
3.2 VTACKK YO!
Andrew
As far as I know you would have to replace the knuckle and possibly other suspension parts for a swap. You would also need the hubs, lines and obviously the calipers, pads and rotors from an EX. I wouldn't recommend welding on suspension parts. Even if you are an expert welder, welding still sets up the possibility of corrosion. Failure of suspension parts will cause a serious accident, so I don't think it's a good idea. I think the best bet is just to go to a salvage yard and pull the entire (undamaged) rear suspension from a wrecked EX. That way you should have everything you need.
| I painted my drum brakes! | asndragonboii | Introduction & Pictures | 44 | 05-25-2011 10:33 PM |
| Why disc brakes have replaced drum brakes? | johnwaynes | Suspension and Brakes | 16 | 06-26-2008 12:46 AM |
| 07 lx drum brakes | fox | Bolt-Ons And All-Motor | 1 | 01-11-2008 12:49 PM |
| Converting a rear drum brakes to calipers? | deestylez | Suspension and Brakes | 6 | 10-19-2007 10:41 AM |
| LX coupe drum to EX/SI disc brakes? | cdphillips60 | Suspension and Brakes | 5 | 09-24-2006 01:57 PM |
