I don't think so. Unless there's something horribly wrong with the electrical system of the car receiving the jump, there shouldn't be a problem. Just remember to keep the donor car's engine running at high idle when cranking up the receiving car.
Probably the only thing that might hurt your car is when the receiving car has a big engine. Our tiny batteries might not be able to supply the necessary cranking amps and your car's alternator will attempt to fill up the deficiency causing an overload. Sorry if it sounds too Star Trekky... but I do keep a spare Energon cube in the trunk for such an occasion. j/k |
Phong Nguyen
Its fine for you but its bad for them. IIRC, one of my instructors at school (UTI) said jumping a battery should be your last resort because it sends high voltage to the computers and it will fry up stuff.
#5 (permalink) | |
Im not intelligent whatsoever on electrical work, but how could jumping a battery with another battery that both produce the exact same amount of volts destroy the other car due to voltage spike? |
#7 (permalink) | |
Your instructor may have had that thought when he saw some arcing as the jumper cables were being connected. This happens because the receiving car obviously have a dead battery and connecting the cables caused a significant amount of current to flow from the donor car to the other, charging the weaker battery. This is normal and is usually safe as long as their are no electrical problems or shorted battery plates in the receiver's car. You can't fry the ECU by using booster cables if done correctly. The batteries on both cars acts like a giant capacitor, absorbing most of the surges (if there were any to begin with). Last edited by oj88; 04-23-2008 at 05:07 AM. |
#10 (permalink) |
In a word, no. But it helps when you bring your engine rpm's up to around 3000 or so as your alternator will be producing more current for the starter in the car you are boosting and causing less of a drain on your system. Even better if you leave it like that for a few minutes before the car needing a boost cranks over its engine.
#11 (permalink) | |
#12 (permalink) | |
Long time ago (decades), the "frying computers" was true. Jumping wasnt recommonded by any manufacturer. Now, it's in the manual to tell people how to do it. Last edited by asndragonboii; 04-26-2008 at 09:35 AM. |
#14 (permalink) | |
i always hate jumping people/getting jumped. i try to use one of those handheld jumper batteries whenever i can instead. |
#15 (permalink) | |
fine for me... Optima Redtop baby, 1000CA/800CCA here i go...!
and no, it will blow your main fuse first...trust me, my buddy did it on his car, $6.99 and a trip to autozone later, he was back on the road. Last edited by ArmyofOne; 04-28-2008 at 10:03 PM. |
#18 (permalink) | |
#20 (permalink) |
^^ lol
but anyway, another thing about UTI, a 20 something year old guy that graduated from there, started working at the dealer that i work at asked me a few months back how to put coolant in a car... HOW do you graduate from a technical school and not know that?? |
| DIY: jumping the battery (jump start) | BATANG CITY JAIL | Electrical | 18 | 03-03-2008 01:15 AM |
| Colourful Jumping Something!! | 2fast4u2 | Water Cooler | 8 | 12-08-2007 02:19 AM |
| How to remove the Battery Clip on the Battery | Slambo | Bolt-Ons And All-Motor | 4 | 09-11-2007 11:36 PM |
