Old 01-28-2008, 10:19 PM   #1 (permalink)
06 SI, oil pan crack, broken motor mount ?
Just picked up 06 SI, oil pan is leaking, looks like crack on RH side next to sub frame. Was looking over everything and noticed the RH [pass side] upper motor mount is welded, I'm fairly sure it was a one piece casting from factory, dont get me wrong its a nice Tig weld, looks factory, but I'd say it was repaired. That may explain the motor dropping and pan hitting the sub frame, anyone here of this problem ?
Thanks
VinValintino is offline   Reply With Quote
Old 02-10-2008, 09:08 PM   #2 (permalink)
The engine is not the original, the donor vehicle was in a accident which caused the said damage.
Old 02-13-2008, 03:33 AM   #3 (permalink)
Fandi
that blows, but this is not the first time ive heard that happen, someone on h-t had pretty much the exact same problem and his insurance was giving him a hard time about it. unless youre the same guy....
fandirabbani08 is offline   Reply With Quote
K2 Motor Fog Lights.... have yours broken? Element63 Lighting, H.I.D.'s, & Neon 18 03-11-2008 11:09 AM
What motor mounts to use in lx motor swap.... Allmotor27 Civic Coupe And Sedan 0 11-19-2007 03:17 PM
3 STAGE I-VTEC, Electrocharger, Electric motor EVO (1520tq), Air Motor k20guy Forced Induction And Nitrous 17 06-03-2007 11:38 AM
Motor mount bolt shifted? speedys4 Mechanical Problems & Technical Chat 12 04-17-2007 01:43 PM
Bad Motor mount - rattle on right front side leonsphinx Mechanical Problems & Technical Chat 15 03-14-2007 04:33 PM
