![]() Join Date: Feb 2006
Map lights
I just swapped LED bulbs into my dome and map lights. the light is slightly dimmer than i would like and i want to make the map lights come on with the dome lights. I have an LX so it doesnt already do it.
I was thinking of running a wire from the door on power from the dome light to the map lights. The other thing i was debating was just getting the map light console from an ex, then i would have the controls for the lights and the accent lighting but im not sure about hooking that up, i doubt the wires are already there. Does anyone know if either of these ideas would or wouldnt work? |
#4 (permalink) | ||
#7 (permalink) | |
pull out both of the light fixtures
on the dome light it has two wires, one of them is pink, the other is blue or black, i cant remember which. use a unbent coat hanger or something similar, i found starting from the map light hole and going back to the dome light is easiest, attach a wire to the coat hanger and pull it back through, i ended up using 18 gauge stranded wire on the map light connector it has 3 pins but only one of them actually has a wire in it, its going to be on one of the sides depending on the orientation you are holding it in, take one end of the wire you just put in, strip it and bend the end in half. Shove it in the oposite side hole from the existing wire. secure the wire with tape. use your method of choice to splice into the pink wire on the dome light on the other end, i just pushed the stranded wire into the connector and taped it into place. partially reinstall the map lights and put in the screw that grounds the fixture and open a door and make sure that the lights turn on, if they work finish reinstalling everything and enjoy. |
#9 (permalink) | |
Took me awhile to complete it, but finally got it. The only gripe about this is you can't turn the map lights on/off when needed. Other than that, pretty happy with it. Thanks again!! |
#11 (permalink) | |
Where would you put the switch from the Odyssey in the Civic? |
#12 (permalink) |
i would try to make the switch fit down where the foglight swich would go but after looking at the diagram it might be a little more work just to make it fit than i thought cause it sits on an angle instead of straight in:
part number 1
#13 (permalink) |
Dave
Anyone having issues with turning on the map light causing the dome to light up? Seems like there needs to be a diode of some sort in line. I'd like to do the mod myself but wondered how it's working out for others.
| Dumb Laws | C2i0v0i1c | Water Cooler | 72 | 12-21-2011 07:45 PM |
| 2006 Fog Lights and Interior Accent lights | acoloreo | Garage | 8 | 07-04-2006 01:14 AM |
| HID/Xenon fog lights? Do they exist? | taejinah | Lighting, H.I.D.'s, & Neon | 1 | 04-01-2006 09:44 PM |
| 06 NEW OEM HONDA CIVIC COUPE FOG LIGHTS | Silver8th | CorSport | 1 | 11-22-2005 04:30 PM |
| 1 more month!!! | Ep3racer954 | Garage | 14 | 11-01-2005 10:53 PM |
