Vibration during cold start - 8th Generation Honda Civic Forum
Old 11-14-2012, 11:36 AM   #1 (permalink)
Hi everyone -
I have an 07 coupe, MT. I've owned the car for a little over a year. As the temperature has dropped I've noticed my car vibrating when I start it up in the morning. The vibrations go away after the car warms, and there are no rpm spikes. I've just had a transmission service, cooling system flush, fuel system cleaning and oil change, all within the last few months, all at the Honda dealership. Since I've owned the car I've taken epic care of it.
So, is it just the weather? Bad motor mounts?
I'm not hugely auto saavy, and I'm flat broke. A little worried.
Thanks much for any advice/info.
Alysan
aenflex is offline
Old 11-14-2012, 10:18 PM   #2 (permalink)
Originally Posted by aenflex View Post
Hi everyone -
Alysan
I had the SAME problem with my '07 Civic. I brought it in for multiple issues as there was also a grinding/rubbing sound when I would back up. Turns out a wheel mount failed and the dealer replaced it under warranty. It fixed the vibrations during cold starts AND the grinding/rubbing sounds. ^__^ Hope that helps!
Lightrender3d is offline   Reply With Quote
Old 11-14-2012, 10:22 PM   #3 (permalink)
possible motor mount. get it checked asap
stone thrower is online now   Reply With Quote
Old 11-19-2012, 11:08 AM   #4 (permalink)
Thanks. Since I've no funds for this, asap is going to be a few months.
aenflex is offline   Reply With Quote
Old 11-19-2012, 11:54 AM   #5 (permalink)
ob3y5teeze's Avatar
R18 Crew Memember # 2010
ob3y5teeze is offline   Reply With Quote
Old 11-22-2012, 10:07 AM   #6 (permalink)
I had the same issue with my 08 coupe AT. When I would start my car in the morning, my car would shake. I put it in drive, the shaking and noise went away. I put it in reverse, the shaking and noise returned. Come to find out it was indeed a bad motor mount. I took my car to my local Honda dealership to have it replaced for about $480.
M1KEM4N is offline   Reply With Quote
Vibration/Rattle during cold start take off SiWizard Mechanical Problems & Technical Chat 26 11-18-2012 03:27 PM
Cold start rpm Wickedsickdood Hondata 4 05-05-2011 08:03 PM
Cold Start Vibration jwong Mechanical Problems & Technical Chat 1 06-04-2009 01:44 AM
Vibration at engine start up Vishesh Mechanical Problems & Technical Chat 6 12-27-2007 01:52 PM
Excessive Vibration When Engine is Cold civicboy Mechanical Problems & Technical Chat 1 01-09-2006 10:54 AM
