R18: Fuel Filter "2008" - 8th Generation Honda Civic Forum
Old 02-11-2011, 12:17 PM   #1 (permalink)
john4o8's Avatar
John D.
i own a coupe r18, im going to change the fuel filter.
anyone know where its located?? please let me know thanx!
john4o8 is offline
Old 02-11-2011, 12:33 PM   #2 (permalink)
SRT4H8R's Avatar
R18 Crew Member #140
It's inside the tank man. I asked about it a couple weeks ago.
Our filter isn't as accessible as like an EK is.
SRT4H8R is offline   Reply With Quote
Old 02-11-2011, 12:46 PM   #3 (permalink)
Generally infollow the rule, "if it isn't broken don't fix it."
Would you say in this case to go ahead and replace the fuel pump so that yOu don't have to drop the fuel again in the future?
Leung is offline   Reply With Quote
Old 02-11-2011, 01:59 PM   #4 (permalink)
john4o8's Avatar
John D.
deng so its hard to change it.. well i was lookin forward to chage it cuz aftr 30,000-40,000 miles they recamend to replace it.. but thanx for answering my thread man
john4o8 is offline   Reply With Quote
Old 02-11-2011, 02:28 PM   #5 (permalink)
SRT4H8R's Avatar
Well if u really want, u can change it. U don't have to drop the tank. Just remove the rear seat and u can access it from there.
Old 02-11-2011, 06:05 PM   #6 (permalink)
R18 Crew Member#580
If you do go a head and do it, I would recommend burning off as much gas as you safely can with out running outa gas. This way you have less chance of splashing gas around the inside of the car, this saving you smelling gas inside the car. A friend installed a bigger fuel pump for some reason and did it with a full tank, it splashed all over the place and smelt like gas in there for a good 6 months.
wpattie is offline   Reply With Quote
Old 02-11-2011, 07:04 PM   #7 (permalink)
av911's Avatar
Who's "they"?
Old 02-12-2011, 12:36 PM   #8 (permalink)
I have the HELM manual for the car and there is nothing in it to even suggest bothering with the fuel filter unless you have a damn good reason to mess with it. If you filled up the tank with apple juice and charcoal starter you might want to change it. Or maybe if you buy gas from a guy who sells it out of milk jugs, then it might be worth changing. I don't think it's worth fussing with unless you have a real reason to bother.
nhopper is offline   Reply With Quote
Old 02-12-2011, 07:34 PM   #9 (permalink)
Maybe at 150k if you buy cheap gas, otherwise I wouldn't bother replacing at 40k unless you got nothing better to do.
Clutchcargo is offline   Reply With Quote
Old 02-13-2011, 03:58 AM   #10 (permalink)
kokoybrowny's Avatar
Puttin you on blast since 1988
I lold so hard when I read the intro
kokoybrowny is offline   Reply With Quote
Old 11-25-2012, 06:21 PM   #11 (permalink)
alex
Ok so I'm confused.. if we never have to replace the fuel filter, then in my case what would be the cause of horrible gas mileage? i use 93 octane on my 08 r18. I dont rev hard all the time, tires are properly aired, i maintain it well every 3k miles it gets oil changed, i dont keep my car heavily weighed down the inside is regularly clean. I dont understand why I get maybe 170 miles out of a tank. and i fill up when my gas light comes on. any ideas guys? only thing i can come up with is its some of the mods i've done, but i thought better flowing engine would increase mpg not dramatically decrease it.
alexmn2 is offline   Reply With Quote
Old 11-25-2012, 07:04 PM   #12 (permalink)
untuned its all WORSE mpg
R18_King is offline   Reply With Quote
Old 11-26-2012, 11:47 PM   #13 (permalink)
Xx1SailorScoutxX's Avatar
Elton (R18 crew member #395)
The R18 is tuned for 87 octane from the factory, not 93. That's Si territory.
Sent from my VS920 4G using AutoGuide.Com Free App
Xx1SailorScoutxX is offline   Reply With Quote
Old 12-03-2012, 06:49 PM   #14 (permalink)
alex
Ok but wouldnt using higher octane increase horse power regardless?
Old 12-03-2012, 07:04 PM   #15 (permalink)
JDM498's Avatar
No,^
Using higher octane gas on a r18 will burn your spark plugs up faster and cause a hazing over them.Also no need to change fuel pump unless its not priming.
JDM498 is offline   Reply With Quote
Old 12-04-2012, 12:22 PM   #16 (permalink)
Russell764's Avatar
R18 Crew Member #905
Check ur battery amperage might be the reason, or spark plugs
Sent from my iPhone using AutoGuide.com Free App
Russell764 is online now   Reply With Quote
Old 12-08-2012, 02:44 PM   #17 (permalink)
alex
Originally Posted by JDM498 View Post
No,^
ok thats good to know. So if i go from 93 oct to 87 oct on the next fill up would that clog something? or should i gradually go down in octane?
Old 12-09-2012, 10:41 AM   #18 (permalink)
No,^
False. Near zero effect on the plugs.
ryker is offline   Reply With Quote
Old 12-09-2012, 10:43 AM   #19 (permalink)
1- 3k mile oil changes are not needed. Read your owners manual.
2- check air filter
3- if higher mileage maybe timing or valves need to be adjusted. Perhaps a tank of high quality fuel system cleaner.
Old 12-09-2012, 10:53 AM   #20 (permalink)
JDM498's Avatar
true/\
I would be glad to show you proof of this ryker .
And also additives are not recommended read your oem honda manual .
Fuel gage stuck on "Full".....any experience/;thoughts? wink05 Mechanical Problems & Technical Chat 10 12-07-2012 11:09 AM
searched but no find "upgrading fuel and fuel pressure" jsb03f Bolt-Ons And All-Motor 0 08-21-2009 06:23 PM
"Cold Start" Issue Fuel injectors Spray Pattern? Pir8pete Forced Induction And Nitrous 62 06-07-2009 10:49 AM
