Anti-Theft code - 8th Generation Honda Civic Forum
Old 09-22-2006, 02:50 PM   #1 (permalink)
SacrificeTheory's Avatar
Chris
Anti-Theft code
I have my code from the dealership, but I have no clue how to put it into the radio. The manual doesn't really explain at all how to type it in. Every time I try and change the text, it just writes "code." Anyone care to explain?
SacrificeTheory is offline
Old 09-22-2006, 03:15 PM   #2 (permalink)
Scrodums
The anti-theft code is only there to let you activate the CD player after your ECU (I think!) gets reset i.e. battery gets disconnected. It isn't necessary to have it on a day to day basis.
What will happen is when you press the power button, it'll tell you to input the code. If you enter the first digit correct, "C" comes on. Second digit will make "O," third "D," fourth "E," and finally, when you input the 5th correct digit, it will open up the FM function. If all you're seeing is "CODE," then perhaps you're not inputting the fifth digit?
I hope I answered your question correctly. If not, just let me know.
Old 09-22-2006, 03:17 PM   #3 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
I've never had to enter the code, but that sure looks like a good explanation to me!
Old 09-22-2006, 03:21 PM   #4 (permalink)
Chris
The thing is, it won't let me put in any codes at all. I get no option at all.
SacrificeTheory is offline   Reply With Quote
Old 09-22-2006, 03:38 PM   #5 (permalink)
Kakashi's Avatar
Avan
i dont have my maunal by my side, or was it a card,
you just use the same keys as you would to change radio stations.
either way, u fail too many times and itll perma lock, need to bring it in to havem reset it.
Old 09-22-2006, 03:42 PM   #6 (permalink)
whitecivicsi's Avatar
Mike C.
Ok try this.
Disconnect your battery. Plug the battery back in.
Now go in the car and start it up. Try to turn on your radio. Once you start it up press the code into the radio. Even though it does not ask for it. Once you put in all the codes...Your radio should turn on.
whitecivicsi is offline   Reply With Quote
Old 09-22-2006, 05:36 PM   #7 (permalink)
CivicWithNav's Avatar
is pressing buttons with numbers on it a challenge for you guys?
JUST PRESS THE BUTTONS!!!
America's Most Stolen Vehicles For 2004 webby Garage 4 11-12-2007 01:19 PM
Factory Radio Code - SI non Nav Shark Tek I.C.E., Electrical, Security, & Navigation 15 08-07-2006 01:29 PM
Heads-up...ALERT!!!! Protect your radio code MyFirstCivic@35 I.C.E., Electrical, Security, & Navigation 6 04-16-2006 12:48 AM
What is the '06 engine code? Phun Siz Civic Coupe And Sedan 2 11-11-2005 12:41 PM
Chassis Code !KAMELEON! Dealership Experience 1 10-06-2005 06:39 PM
