Auto Door Lock (06 Civic) - Page 2 - 8th Generation Honda Civic Forum
Old 04-05-2006, 11:24 PM   1 links from elsewhere to this Post. Click to view. #21 (permalink)
Originally Posted by Tate
my co-worker has a 06 EX sedan. He tried to program the auto door luck/unlock and it didn't work. He called the dealer and the dealer can't program it either. Then the dealer called Honda Canada and they confirmed that the auto door lock/unlock does not work on the EX civics. It is an error on the documentation. There is no such feature. You can call Honda to confirm it
My CSX has this feature though
Funny, I have an 06 EX Sedan and I got mine to work.
EX4MKM is offline   Reply With Quote
Old 04-06-2006, 02:07 AM   #22 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
Did you follow the instructions exactly as they are written?
Old 04-06-2006, 05:41 AM   #23 (permalink)
Yes I did. One thing I noticed, once you hit the buttons in the right combo, you have to shut everything off fast. I had to do it twice, I didn't turn the key off fast enough the first time. Timing's everything!
Old 04-06-2006, 08:30 AM   #24 (permalink)
06 EX Sedan 5mt
It works on my car. I set it up. Used it for a week. Then turned it off.
Seems like a good feature. Just got on my nerves when hypermiling.
psyshack is offline   Reply With Quote
Old 04-06-2006, 01:14 PM   #25 (permalink)
The auto locking/unlocking works perfectly on my Canadian 06 EX Sedan 5MT.
I programmed it just like the manuel said. No problems. That was 4 months ago. I do wish the passenger door would unlock when you turn the engine off, not just the driver side door.
coreLlama is offline   Reply With Quote
Old 04-07-2006, 12:37 AM   #26 (permalink)
MyFirstCivic@35's Avatar
Yeah it sucks especially when I go to get my three year old out of the back seat and the door is still locked. Or at least it did until the boy figured out how to unlock the door himself.
MyFirstCivic@35 is offline   Reply With Quote
Old 04-08-2006, 04:38 PM   #27 (permalink)
Webby's Minion
8thgenuser's Avatar
Okay...I got it to work. The trick is to turn the key back to position 0 as fast as you can. The instructions should have said "within 2 seconds" instead of "withing 5 seconds". I got every lock/unlock feature to work.
Old 04-08-2006, 07:33 PM   #28 (permalink)
HardBoiler's Avatar
EX Coupe and it works fine. I followed the instructions, right down to having the parking brakes up.
HardBoiler is offline   Reply With Quote
Old 04-09-2006, 10:53 AM   #29 (permalink)
I have an 06 Si. I just followed the directions in the quick ref and it worked. You have to seperately set the lock feature and the unlock. As far as I know the unlock does both doors. It took me one or two tries to get it but it can be done. Just spend a few minutes with it.
hondacurafan is offline   Reply With Quote
Old 04-09-2006, 01:04 PM   #30 (permalink)
CivicCilla's Avatar
I have an EX coupe, both features have been working as indicated in the manual (both lock, driver's unlocks), but I've tried again and again using the original instructions and trying things of my own. No such luck with the passenger side. Are you sure its unlocking?? I'd be quite jealous if it really is.
CivicCilla is offline   Reply With Quote
Old 04-09-2006, 02:19 PM   #31 (permalink)
Has anyone figured out how to get the sedans to unlock all doors when shifted to into park? It is a minor irritation but coming from a BMW that only automatically locked I am used to manually unlocking the doors. The one thing that really bothers me is there is no 'panic' unlocking built into the door handles. On a BMW you pull twice on the handle and the door unlocks. thanks...
gravityboy is offline   Reply With Quote
Old 05-17-2006, 10:06 PM   #32 (permalink)
Tonny's Avatar
I have a Civic EX Coupe and it happens me the same thing.
Is there solution to the problem of the locks/Unlock of the doors?
Tonny is offline   Reply With Quote
Old 06-03-2006, 07:35 PM   #33 (permalink)
Tate, just curious if your co-worker got it working since quite a few others got it working. If so, did you guys call Honda Canada tell them what kind bull**** answer were they giving you guys.
dhl105 is offline   Reply With Quote
Old 08-28-2006, 08:14 PM   #34 (permalink)
i got my civic to auto lock.. but i didnt know there was an auto unlock feature.. cuz its a PITA once you park the car to have to unlock the car every time..
errm.. where do i find this.. *goes to read manual*
SwiftPig is offline   Reply With Quote
Old 08-28-2006, 08:25 PM   #35 (permalink)
Webby's Minion
8thgenuser's Avatar
Okay everyone. There are no published instructions on how unlock all the doors by using the shift lever. Honda has only published instructions on how to unlock only the driver's door by using the shift lever.
Only a very few people (one for sure, maybe two) have reported that they are able to open all doors without the use of aftermarket products, but haven't given a reason as how they are able to do so. What they say may be true, but they might have some wiring fluke that allows them to do so.
If you want all your doors to automatically unlock, the only way is to get an aftermarket system (alarm or otherwise) that allows you to do so.
Please, do not ask how to automatically unlock all passenger doors by using the shift lever because there are no published instructions for it.
Old 06-24-2010, 07:47 PM   #36 (permalink)
unlock all doors doesnt work on 06 models. i believe 07 and above has this feature
jonahmt21 is offline   Reply With Quote
Old 06-24-2010, 08:16 PM   #37 (permalink)
Drew.
Doesn't work on my 09 EX a/t either.
Followed the directions exactly the first week of ownership and never tried it since.
aac0036 is offline   Reply With Quote
Old 06-27-2010, 07:35 AM   #38 (permalink)
DrFeelGood's Avatar
D.M.
06 Ex Coupe here and all doors locks,D/S unlocks.. pissing me off that the P/S door does not unlock. but oh well...
DrFeelGood is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/civic-coupe-sedan/1304-auto-door-lock-06-civic.html
Auto Door Lock (06 Civic) - 8th Generation Honda Civic Forum This thread Refback 01-04-2008 04:53 PM
2006 Civic Chassis Codes 2fast4u2 Dealership Experience 45 04-12-2011 02:32 AM
On The Track - 2006 Honda Civic - 8th Generation Civic 2006 Honda webby Honda Industry News 6 08-27-2009 05:35 PM
2006 honda civic lineup pricing released webby Honda Industry News 11 07-04-2006 07:12 AM
2006 Civic Summary from Temple of VTEC shoptb Dealership Experience 4 01-11-2006 03:40 AM
2006 Geneva Civic Release webby Garage 0 06-23-2005 12:10 AM
