Snizzletoff's "I can't believe I'm doing this again" Build Thread - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Welcome > Introduction & Pictures > Car Builds
Old 08-14-2012, 07:21 PM   #1 (permalink)
ಠ_ಠ
snizzletoff's Avatar
snizzletoff
Welcome to my build thread!
The second post contains all of my old build information.
How the car looked recently!!
And some pics from various meets
Mods going on in the next month or so
Engine and stuffs:
Skunk2 alpha header
q300 exhaust
Vit tuned
Hardwired fuel pump
Corsport shift bushings
EM1 CMC
Stainless steel clutch line
Suspension/wheels:
HFP suspension
Energy suspension LCA bushings
Meyle platinum rotors
Stoptech pads
SS break lines
XXR 527 17x8.25 + 35
Dunlop *spec's 245/40/17
Muteki SR48 black lugs
all sold
Stock wheels w/hancook v12's 225/45
Other aesthetics:
HFP lips Front and rear
Hondata license plate frame
Interior LEDs
License plate LED's
red stitch shift boot
type-r replica knob
Wrinkle black Valve cover
Omni gun barrel oil cap
Replica fog lights
snizzletoff is offline
Old 08-14-2012, 07:21 PM   #2 (permalink)
ಠ_ಠ
snizzletoff
:shadyhat:
Old builds, The top one is my most recent turbo build
I plan on doing all my own work on this build! building up this car has taught me so very much about cars everyone really should just dive in and work especially with a site like this with so many DIY's and helpful people!
Engine:
Shortblock built by SRT
K20a2 block with a supertech block guard
Arias pistons - 9.0:1 compression 86.5mm bore
Pauter rods
Rsx type-s oil pump
Supertech Valves
Supetech dual springs
Supertech seals
Prayoonto stage 3 cams
Toda timing tensioner
Cometic head gasket
Arp head studs
ACL main bearings
ARP rod cap bolts
Innovative 75a mounts
Fuel system:
SRT fuel rail
SRT dual pump fuel cage
- 8an feed, 6an return
SRT fuel rail
Dual walbro 255lph pumps
AEM fuel pressure regulator
Turbo/ go fast parts
Jotech turbo kit
pt 62/26 turbo
2.5inch charge piping w/intercooler rated for 650hp
Tial 44mm wastegate 4.3 psi spring
Open dump ( want to get this recirculated in the future!)
Tial blow off valve
Mac 4port solenoid for BBG
3in down pipe
Hondata flashpro
Hondata 4 bar map sensor
Go-power 1000cc injectors
3in dump pimp
q300 exhuast
Hondata Traction control
Transmission:
Getting every single piece inside the transmission cryogenically treated
OEM syncros
4.3 final drive from club rsx (also cryno treated)
Clutch masters fx350
Em1 CMC w/SS line
Misc:
Apexi Turbo timer
XLR8 dual gauge pod
Glowshift wide-band digital series A/f gauge
Glowshift digital series boost gauge
Glowshift oil pressure gauge
9 LED license plate lights
12 LED interior lights
Suspension/wheels:
HFP suspension
Stoptech pads
SS break lines
Muteki SR48 black lugs.
The block has arived!
Also received my rear hasport 70a mount, 4.3psi wastegate spring, arp headstuds!
Fuel cage (needs cleaned!)
Camshafts are in! Prayoonto stage 3's along with the titanium retainers and valve seals
Toda tensioner also arrived!
Starting the tear down today!
Got some pics of the car before it goes under!
Got a lot of hoses, wires and lots of other things out of the way now!
Got the engine out today!
Had a lazy day today but still got some accomplished. Took the transmission off the engine, and started breaking it down. I got the case split but didn't start pressing anything apart yet. I also got the intake manifold off and a few other things.
Broke down my old block today, got the head off. Also got the transmission totally apart
Rocker arms nicely wrapped in rubber bands
All the gears laid out, Should be shipping them tomorrow!
Found that missing valve spring retainer and made a little progress so far today!
Got the full supertech vavle train installed
Sexy head stud pic
Head on and torqued, cam towers on and torqued
Valve cover just set on too see how it looks! Thanks Bulliedog!!!
Some final pictures of the build:
Installing the 4.3psi wastegate spring
A very nicely angled oil drain:
Removed the subframe (last time for awhile i hope!)
The final trans pictures before re-sealing the case
Want to thank Danny (Wannavtec) for taking a few photos of my car at Dyno day and the red robin meetup after!
Old builds:
I apologize in advanced, i don't take many pictures of my car, i will take more this time around!
The day i bought the car in march 2011:
I'm the skinny dude in the pictures
When i got this car the only thing i wanted was to get the HFP lip and fog lights
I thought this car was plenty fast when i got it!
I finally caught the modding bug and bought the Corsport short shifter and cable bushings and a new knob and red stitch shift boot
Sorry for the bad picture
This is where the modding took off
Bought at CNT catted race header, injen intake, and flashpro
Next was a HFP suspension
And I cleared my headlights
Wasn't long before i was bored and wanted more power...
I sold my second car 2004 eclipse gs, i kept it because it was hit while parked, i got screwed on insurance and decided to fix it myself...in the mean time i bought a new car.
Used it to buy a JRSC setup!
JRSC - bought from another member
CNT header
Injen CAI
Hondata flashpro
Em1 CMC
Merc racing aftercooler
3in pulley
Hondata 4bar map sensor
RC650 cc injectors
Full race exhuast
Tuned by Evans tuning
Also installed Em1 CMC and had a horrible time bleeding it!
And had to get an exhaust! thought id get the "quietest one"
Full race beside stock pipe
Merc racing remote fill
Kit installed:
Guages:
OH yeah! I finally got fog lights! But still no lip like I originally wanted
I never got that setup dyno'ed
I only had it for 3 months before a deal presented itself!
Straight trade for my JRSC, aftercooler, header, and exhuast to get a jo-tech turbo kit
Full turbo build specs:
Jo-tech turbo kit
Pt 62/62 turbo with a .68 ar
2.5in charge piping w/intercooler rated at 650
Go power 1k injectors
Hondata flashpro
4bar map sensor
DW300lph fuel pump
Tial wastegate
Tial BOV
Em1 cmc
Competition state 4 clutch
3in downpipe
Q300 exhaust
HFP suspension w/ sportline springs
Buddy club camber arms
Ingualls front camber bushings
Dyno:
Some pics of the kit!
10an Oilpan bung welded on!
Turbo mounted for the first time
Oil drain on
Because I had to trade my full race exhaust, I had a crappy skunk 2 for a month!
Only took one month to replace this ridiculous piece of garbage!
Got a q300!!!
Unfortunately my turbo’s oil seal blew, I had to take the whole sub frame down again and replace it
O well I rebuilt the turbo myself! I like to learn new things
FMIC:
Everthing was going great until my tires started to spin while tuning! So I bought hancook v12s
The day I installed them I went for a nice ride, and slipped my clutch because the tires gripped better! I knew it was a matter of time on the stock clutch!
Dropped the subframe sorry for the bad picture!:
Transmission off, to the left is the stock clutch!
Engine without the tranny and a good turbo shot!
I ended up installing a Competition stage 4 clutch!
I finally did some cosmetics to my car, got springs, projectors, and the HFP lip
I also installed a pioneer navi!
How my car looked
On the dyno:
Didn’t have this set up before I got bored again and decided I wanted to part with the car and start something new!!!
I posted everything for sale!
WHELP! After talking with some people around me and on 8thcivic I decided against it, unfortunately I sold a lot of parts…but I still had most of them!
I will reserve the next post for my next big power build!
snizzletoff is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 07:42 PM   #3 (permalink)
Guest
give details on the new build
46074 is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 07:44 PM   #4 (permalink)
ಠ_ಠ
snizzletoff
I updated the second post with a good few details
Old 08-14-2012, 08:04 PM   #5 (permalink)
k20fg's Avatar
Why would you not use the SRT Dual pump hanger? Any major downfalls you don't like about it or will you just be able to reach you goal without it?
k20fg is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 08:25 PM   #6 (permalink)
ಠ_ಠ
snizzletoff
The srt cage is amazing its really high quality, I just don't want to have to run two fuel pumps! If I ran e85 maybe I would but I want to use 93 and get to 550 ish hp. I think I can make it with my dw300lph and 1k injectors.
Sent from my PG86100 using Tapatalk 2
ಠ_ಠ
Old 08-14-2012, 08:31 PM   #7 (permalink)
soxfan143's Avatar
I would just recommend a basic old fuel return system for your power goals bro. I've had it with the returnless system. Don't spend any crazy money on cages or duel pumps and stuff. Just do an external FPR with fuel return line and you will be good for your power goals.
Full-Race with GT3076R 467whp and 327tq(edyno)
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
soxfan143 is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 08:35 PM   #8 (permalink)
ಠ_ಠ
snizzletoff
That's why I said I don't want to use it, I don't need it. It was included in a very fair deal I got on the cage, 2 pumps,all the stainless lines to the fuel rail, all fittings and adapters, an srt fuel rail, and fuel pressure regulator for 500. I planned on selling the srt cage if I can with the walbros to make back some money
ಠ_ಠ
Old 08-14-2012, 08:46 PM   #9 (permalink)
ThpoonThports
LouGraySI's Avatar
Louith
Looks sexy bro!!
a synonym for massive headache.
LouGraySI is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 08:52 PM   #10 (permalink)
ಠ_ಠ
snizzletoff
Originally Posted by LouGraySI View Post
Looks sexy bro!!
Thanks I hope everything works out!
ಠ_ಠ
Old 08-14-2012, 09:05 PM   #11 (permalink)
Full Race Andrew's Avatar
Andrew Moore
Gonna need some tranny upgrades...
Full Race Andrew is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 09:07 PM   #12 (permalink)
ಠ_ಠ
snizzletoff
I'm looking into this not sure the exact thing I want to do. Any tips other than just going full albines?
ಠ_ಠ
Old 08-14-2012, 09:13 PM   #13 (permalink)
garage queen
asdf's Avatar
rich
Awesome
Sent from my SGH-T769
asdf is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 09:16 PM   #14 (permalink)
soxfan143's Avatar
Yea man you don't need twin pumps with a fuel return for 500hp. An HP pump with a rising rate FPR and ID 1ks and you're golden. A fuel return is my next mission. I've had it with the long warm starts and running 99% duty cycle at only 15psi. lol...
Old 08-14-2012, 09:17 PM   #15 (permalink)
ಠ_ಠ
snizzletoff
I just couldn't beat the price especially if i can sell some of it to make back a bit of money!
Old 08-14-2012, 09:21 PM   #16 (permalink)
soxfan143's Avatar
Yea man $500 for an entire fuel return system WITH the SRT dual hanger cage is a sick deal.
Old 08-14-2012, 09:33 PM   #17 (permalink)
realxlai's Avatar
M. Bison
aw yeah build thread yah
realxlai is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 09:39 PM   #18 (permalink)
Andrew Moore
PPG 1-4 tsx 5th and our 6th with a 4.3fd
Old 08-14-2012, 10:02 PM   #19 (permalink)
ಠ_ಠ
snizzletoff
aren't ppg's more than albines? I know shipping on albines sucks because they are from Australia but i still think it ends up to be a bit less.
Old 08-14-2012, 11:53 PM   #20 (permalink)
Guest
andrew, how often did u have to replace gears?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Who Needz Sandy when we hAz Lou's Build thread. MID ATL chat thread V1.6 Safe 4 Ocho' bulliedog Mid-Atlantic 10003 11-16-2012 01:49 PM
