K20/K24 Frank Build: Cams Left - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor > Cams & Internals
Old 02-24-2013, 12:18 AM   #1 (permalink)
What I have put together so far:
12:5:1 Compression
CP Pistons
Carillo Rods
87.5mm Bore
Go Power Valve train
First gen HR Tensioner
70mm RBC
I need advice on what cams I should run on my setup, Some ideas:
Skunk 2 Stage 3 (most likely)
Kelford Stage 3
Crower Stage 3
Cartel Stage 3.2
Last Thing on the menu is what size TB. Note this swap is on my RSX so no drive by wire TBs
turbinator1990 is online now
Old 02-24-2013, 12:49 AM   #2 (permalink)
F-BOM's Avatar
Cartel 2.2 or 3.2 or even 4
Prayoonto 2
F-BOM is offline   Reply With Quote
Old 02-24-2013, 06:29 AM   #3 (permalink)
_Mozz_'s Avatar
Cartel 3.2, Prayoonto 3 or a tag more agressive... Team4Piston Road Race cam.
_Mozz_ is offline   Reply With Quote
Old 02-24-2013, 08:46 AM   #4 (permalink)
E-Tunez FTT!!!
ruloSI's Avatar
Rulo
12:5:1 Compression
CP Pistons
Carillo Rods
87.5mm Bore
70mm RBC
Kelford Stage 3
Crower Stage 3
Cartel Stage 3.2
I have the same going in my DC5 as well. Except I have Wiseco pistons. I'm a big Toda fan boy, hence I will be running Toda Spec E. That being said, I've had success with Cartel's 4, 4.5, 2.2, Hytech I/II. For your setup, I would go with the Drag Cartel 4 or Hytech II. Jeremy @ Drag Cartel and John @ Hytech are very helpful.
On the throttle body front, I recommend the Hybrid Racing 70mm (that's the one I have) works very well.
Best regards,
Dr. Rulo
Rulo|K20/K24 Maven|B-F-H-K-R Tuning Specialist
www.e-tunez.com www.flashprotuning.com
www.rpmnyc.com | passion. dedication. TUNATION.
ruloSI is online now   Reply With Quote
Old 02-24-2013, 11:18 AM   #5 (permalink)
Aaron
There is someone on k20.org selling ips kme cams I've heard those are great too for ur build.
07civic909 is offline   Reply With Quote
Old 02-24-2013, 09:30 PM   #6 (permalink)
mattk's Avatar
Spoon or jays racing TB my boy actually may have one for sale has kinsler itbs now
Sent from AutoGuide.com Free App
mattk is offline   Reply With Quote
Old 02-24-2013, 09:31 PM   #7 (permalink)
mattk's Avatar
And for the cams prayoonto stage 3s
Old 02-25-2013, 05:03 PM   #8 (permalink)
ATL Si's Avatar
Alex
Go ahead and scratch the Skunk2 stage 3 cams off your list. Plenty of horror stories because of the way those cams are designed. Kelford stage 3s are too big for your build. Cartel 3.2s would be nice, but you'll make better power with the cartel 4s I'd be willing to bet. Prayoonto 3s will give you good results from what I hear as well. Get the largest TB you can port match to your IM
ATL Si is offline   Reply With Quote
Old 02-25-2013, 06:05 PM   #9 (permalink)
Cap-One's Avatar
Al Capone
I'm running the Skunk2's made really good power. I've been seeing alot if people talk about the new cartel 3.2's but not a lot of Dyno's unfortunately. Regardless I'm sure they make power.
Cap-One is offline   Reply With Quote
Old 02-25-2013, 07:59 PM   #10 (permalink)
ATL Si's Avatar
Alex
^ I haven't seen a dyno. I trust in Jeremy to not release a crap cam though.
Tapatalk 2 Sucka!
Old 02-25-2013, 09:49 PM   #11 (permalink)
licea1204's Avatar
Wu-Tang Saga
DC 3.2 would be an awesome cam for a k24 build.... Great service from Jeremy, He always answers ur questions...... DC FTW....
licea1204 is offline   Reply With Quote
Old 02-25-2013, 10:07 PM   #12 (permalink)
fishermoe14's Avatar
R18 FTMFW
so you bought the motor...
anyway... curious to see what you go with as my build is almost identical... haven't seen any dynos of the 3.2 but seems promising.
fishermoe14 is offline   Reply With Quote
Old 02-25-2013, 11:17 PM   #13 (permalink)
ATL Si's Avatar
Alex
Yeah they seem like a nice mild K24 cam. But with the 12.5:1 comp I would think he could take advantage of some 4's....
Old 02-26-2013, 02:29 AM   #14 (permalink)
Cap-One's Avatar
Al Capone
Tapatalk 2 Sucka!
I trust him too, just need to make sure your specs match the cam profile to optimize the cam.
Old 02-26-2013, 02:30 AM   #15 (permalink)
Cap-One's Avatar
Al Capone
4's would be good but I'd love to see the power band on 3.2's.
Old 03-02-2013, 12:16 AM   #16 (permalink)
Blueprint Racing Stage 2 billet cams
Tearial311 is offline   Reply With Quote
Old 03-02-2013, 12:19 AM   #17 (permalink)
stage 4 is usually built for drag racing where the engine is usually ran above 5000rpm
Old 03-02-2013, 12:55 AM   #18 (permalink)
ATL Si's Avatar
Alex
All stages aren't the same. The Cartel 4s work great on the street.
Tapatalk 2 Sucka!
Old 03-02-2013, 02:01 AM   #19 (permalink)
Cap-One's Avatar
Al Capone
Probably be a little small, with stage 2's.
Old 03-02-2013, 04:47 AM   #20 (permalink)
I am honestly leaning towards Prayoonto Stage 3 cams
turbinator1990 is online now   Reply With Quote
Best Cams for k20/k24 Frank Thumper Cams & Internals 77 04-12-2012 02:59 AM
Frank Build K20/K24 - Civic Type R FN2 Dawid S Engine Swaps, Mounts, Pulleys 68 12-19-2011 02:14 PM
Frank Build ! K20z3_Si Cams & Internals 151 06-06-2011 07:16 AM
frank with TSX cams Nick3r Cams & Internals 2 04-05-2010 02:38 PM
What Cams for my N/A build!?!? Zib331 Cams & Internals 34 11-13-2009 03:40 PM
