need help - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor > Cams & Internals
Old 01-28-2013, 03:05 PM   #1 (permalink)
Willy191 just put it into 1st gear on 8thcivic
need help
just recently started to get interested in making my si faster after 2 years i know a long time lol just got in dynoed at 209 whp with a borla exhuast vibrant headers and k&N sri with flashpro and i want to make it faster now my goal is around 225+ how would you guys suggest i get to this i know cams but dont know almost nothing about that i heard tsx cams are good replacement any help or advice would be apperiated thanks
Willy191 is offline
Old 01-28-2013, 03:06 PM   #2 (permalink)
Chase's Avatar
Chase
Chase has an enormous 8thcivic turboChase has an enormous 8thcivic turboChase has an enormous 8thcivic turboChase has an enormous 8thcivic turboChase has an enormous 8thcivic turboChase has an enormous 8thcivic turboChase has an enormous 8thcivic turboChase has an enormous 8thcivic turboChase has an enormous 8thcivic turboChase has an enormous 8thcivic turboChase has an enormous 8thcivic turbo
Send a message via AIM to Chase Send a message via Yahoo to Chase
K24a2....
Chase is offline   Reply With Quote Quick reply to this message
Old 01-28-2013, 03:10 PM   #3 (permalink)
2007GhostSI's Avatar
Chapa
2007GhostSI just put it into 1st gear on 8thcivic
need help
Theres alot you can do. Look around the site, check out the build threads, the thread about ppl over 250hp and get ideas.
But i'll give u a few things. U want a good set of cams go with SVM, get a 3.5inch intake (hybrid racing, skunk2, rick spec'd) port your RBC or go with an RRC with a J35 TB.
2007GhostSI is offline   Reply With Quote Quick reply to this message
Old 01-28-2013, 03:15 PM   #4 (permalink)
its a 2007 honda si 4dr and its kinda hard understanding the threads of cams
Willy191 is offline   Reply With Quote Quick reply to this message
Old 01-28-2013, 03:22 PM   #5 (permalink)
Chapa
need help
Doesn't matter if its a coupe or sedan its the same engine. Just supercharge man quick power. Once u get to 250hp u are going to want more might as well go for more at the beginning
Old 01-28-2013, 03:29 PM   #6 (permalink)
its also my DD and i want it to be my dd just wondering what kind of cams and other stuff i need to buy i dont want to blow my engine or anything just something simple to come 225 whp so i can be happy
Old 01-28-2013, 05:14 PM   #7 (permalink)
licea1204's Avatar
Wu-Tang Saga
licea1204 just put it into 1st gear on 8thcivic
you want to make power, i did 222hp on just I/H/E and RRC and J35tb. You need 3.5 CAI,Skunk2 alpha header/Full-Race 3" exhaust and get tuned by a reputable tuner.... If you want cams then go with SVM 212 cams and Supertech valvetrain that should make you happy for a while..... I run my SVM 212 cams on my car and havent dynoed yet but should be close to 240+hp.... I daily drive my car and beat on it like no tommorrow....
licea1204 is offline   Reply With Quote Quick reply to this message
Old 01-28-2013, 05:46 PM   #8 (permalink)
Chapa
need help
You e-tuned bro?
Old 01-29-2013, 02:28 PM   #9 (permalink)
No just regular tuned in look more into the rcc and j35tb see if that helps
Old 01-29-2013, 10:11 PM   #10 (permalink)
Civak's Avatar
Civak just put it into 1st gear on 8thcivic
Am I the only one whose mind flashes to F&F3 every time I read Borla Exhaust?
Anyways, before thinking about cams you need to do big research into the issues you may experience with them. To my knowledge, the Timing Chain Tensioner becomes something of a regular maintenance item. Though that shouldn't apply to the TSX cam(s) (I think we just replace the exhaust side? Never really considered doing it)
If you don't want to touch the head, the RRC/J35 is a decent combo, but I'd actually stick with the RBC and get it bored out, with those couple ugly ports blocked. A local shop should do it at a decent price, much much less than the $400 asking for an RRC. Also, I wouldn't go J35, it's just.. kinda small and not worth it. ZDX is cheap and much, much bigger
But if you're really serious about making it faster, you likely won't be happy with the couple NA mods you have left. Go for boost.
Also, ditch your SRI for a real CAI, and cat-back for an XLR8, Full Race, GoPwr, Q300 (sorry if I missed a decent exhaust) if you're looking for more power. ETunez are also your friends.
Civak is offline   Reply With Quote Quick reply to this message
Old 01-29-2013, 10:59 PM   #11 (permalink)
tiZZle2.0's Avatar
tiZZle2.0 just put it into 1st gear on 8thcivic
If you just replace your parts now with better parts you would be able to get very close to 225 w/o cams or a ported IM/RRC if that is all the power you are looking for
I dynoed in at 222 with IDPS 3.5 CAI, S2 megapower header, FR 3" exhaust and FP on a base map.
And if you do get the RRC IM or port your RBC IM stick with the j35 TB, that will be more than enough for a small all motor build. You would just be wasting your money on the ZDX unless you plan on going all out with big lift cams and what not.
tiZZle2.0 is offline   Reply With Quote Quick reply to this message
Old 01-30-2013, 09:48 AM   #12 (permalink)
glxygreysi08's Avatar
glxygreysi08 just put it into 1st gear on 8thcivic
While I understand that mentality, it does not always ring true. I have my Toda A3's and I even switched from a Full Race to a HyTech twin loop (to retain my sanity and not go deaf/make my future newborn daughter go deaf lol), and I am more than happy with the power and balance of the car. I know I'm not the fastest out there, and that's fine with me. But I look forward to driving the car every day and it's been wonderfully reliable.
As long as the car puts a smile on your face when you drive it, that's what counts. It doesn't matter if it's stock, mild N/A, or crazy HP boost monster. It all depends on the OPs priorities/expectations.
OP, I also wouldn't really bother with TSX cams or DICs unless you plan on doing the install yourself. If not, save a couple hundred more and buy a nicer "stage 2-like" cam with valve train. That's what I ended up doing and am much happier.
glxygreysi08 is offline   Reply With Quote Quick reply to this message
Old 02-13-2013, 05:58 PM   #13 (permalink)
hmm i see anyone have info about the buddy club spec 1 cams had someone offer me some and im interested in them
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
