Blue Print Stage Two Cams - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor > Cams & Internals
Old 02-17-2012, 11:02 PM   #1 (permalink)
VTECKILLER-FA5's Avatar
jonathan
I have the blueprint stage 2 cams and was wondering what others are putting down. I just got retuned and made 241hp @ 168. Just trying to see where i stand. Thanks.
VTECKILLER-FA5 is offline
Old 02-17-2012, 11:04 PM   #2 (permalink)
sicivic09's Avatar
Bradley
What are your supporting mods? What dyno you get tuned on?
Sent from my DROID RAZR using AutoGuide.com App
sicivic09 is offline   Reply With Quote
Old 02-18-2012, 11:46 AM   #3 (permalink)
sicivic09's Avatar
Bradley
I been thinking on my next build of going with blueprint for everything since my buddy Rob has the hook up with Rob at blueprint. Did you do the cam tower oil mod as well?
Old 02-18-2012, 07:10 PM   #4 (permalink)
reid1980's Avatar
hytech does that as well
reid1980 is offline   Reply With Quote
Old 02-18-2012, 08:58 PM   #5 (permalink)
jonathan
I have blueprint ported rbc with p2r gaskets, mdx tb, tb spacer, sk2 mega power header, go power 3" header back, a hp reducing t1r intake, e85 with 775cc injectors, go power valve train, a good tune with flashpro. I used a dyno jet dyno. And no cam tower mod.
VTECKILLER-FA5 is offline   Reply With Quote
Old 02-18-2012, 09:02 PM   #6 (permalink)
jonathan
It took awhile to get the rbc back from them, but after comparing it to others it was worth it.
Old 02-18-2012, 10:04 PM   #7 (permalink)
sicivic09's Avatar
Bradley
I think your numbers are legit. Dynopack?
Old 02-18-2012, 10:14 PM   #8 (permalink)
jonathan
No dyno jet. thanks i know i can pick up some more hp with a new intake.
Old 02-19-2012, 12:03 AM   #9 (permalink)
sicivic09's Avatar
Bradley
Rick spec intake style will definitely get 250. Maybe lightweight flywheel. Rsx pump net pullies. Regardless what you do. You have a great build as it is. I bet those cams would love higher compression. So I been told.
Old 02-19-2012, 03:31 AM   #10 (permalink)
jonathan
Ya I work with a guy that used them in a 24 setup and is all over me about bumping up the compression. But thanks for the feed back.
Sent from my Autoguide iPhone app
Old 02-19-2012, 09:00 AM   #11 (permalink)
Originally Posted by VTECKILLER-FA5 View Post
I have blueprint ported rbc with p2r gaskets, mdx tb, tb spacer, sk2 mega power header, go power 3" header back, a hd reducing t1r intake, e85 with 775cc injectors, go power valve train, a good tune with flashpro. I used a dyno jet dyno. And no cam tower mod.
are you in the borward area?? You called me up asking to run it remember?? lets do this!!!!
Zib331 is offline   Reply With Quote
Old 02-19-2012, 01:10 PM   #12 (permalink)
jonathan
black fa5 right?
no prob any time
Old 03-01-2012, 08:51 AM   #13 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
"Stance"...The new jockstrap
OP: Our cars are quite similar as far as mod lists go (and exteriors for that matter ). You definitely need a bigger intake, as well as a ported throttle body. I admit to not knowing a lot about the Rick Spec intake other than the fact that it's nearly identical to the Go Power intake I'm using. I suggest getting the Go Power unit only because it has a stabilizing bracket built into it. It's my understanding that the Rick Spec moves around, vibrates, and knocks against things. Like I said, I don't know a lot about the Rick intake so if I'm mistaken about these issues, somebody feel free to correct me.
Originally Posted by the Buldge View Post
if are sei=eking inpiraton Above sourcs Higher Source,,, first amham needs in bibler says ,,,''love selfd n frends n framilty,,'' from lord,, n afetr loves self can snd then love Woman,, tell here PIIHB" THEN n only than can seeks high,er Ass -the Buldge-
Old 03-01-2012, 04:32 PM   #14 (permalink)
reid1980's Avatar
It slightly rattles when taking off. Something padded on the intake would stop it. I never hear it other than at that point.
Old 03-02-2012, 08:13 PM   #15 (permalink)
jonathan
Thanks for the feed back.
Old 03-03-2012, 08:19 PM   #16 (permalink)
K20Z3Addict's Avatar
The airbox system does work very well, which is why a lot of track cars run them.
If you were to dyno your car using a filterless 3" intake pipe you would only see about +4 to +5 whp over the T1R system on a DynaPack...or about +3 whp on a Mustang/AWD dyno. See April 2011 issue Honda Tuning Mag for test on 08 SI w/Stage 2 style cams.
A J37 TB and a 3-Angle valve job (from Blueprint) would put you around 255 whp. Add 12.5:1 pistons to that and you would see around 270 whp on E85 which you already run. Great car!
K20Z3Addict is online now   Reply With Quote
Old 03-04-2012, 09:52 AM   #17 (permalink)
has anybody tried the Buddy Club DIC??
Juicyjoint316 is offline   Reply With Quote
Blue Print Stage 2 Help! Civic_FD2_PR Cams & Internals 15 12-05-2010 03:05 PM
greddy EASY cams vs Skunk2 stage 1 cams artyfartsyFA5 Cams & Internals 12 06-19-2009 01:48 PM
Pros and cons: Stage 2 Supercharger VS Stage 1 Supercahrger w/ hotter cams Ranzo Supercharging 7 10-09-2008 01:34 PM
