IPS k2 MkII camshafts:Knowledge needed - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor > Cams & Internals
Old 11-21-2010, 02:18 PM   #1 (permalink)
jsb03f's Avatar
Josh
So these are the cams I have decided to run and after many graphs and say from people runing these cams, I must have.
I am aware that for reliability and because of necessity that new:
Dual Valve springs
Titanium retainers
Keepers
Dual Valve spring seats
Valve stem seals
"Hybrid Racing" chain tensioner
and have read over and over again that I can run either Supertech dual valve springs SPR-H1022D with 80 lbs of seat pressure or Eibach 20411 springs with82lbs of seat presure.
My questions are from who should I aquire the last pieces of the puzzle? Should I finish up with Supertech Keepers. Seats, Retainers or Eibach Retainers, Keepers, and Seats?
Those who are running IPS K2 MkII please chime in
Thanks 8thcivic
jsb03f is offline
Old 11-22-2010, 03:59 AM   #2 (permalink)
Teegs's Avatar
Matt
Supertech will do just fine. My recommendation is don't think about it too much, both choices will be just fine.
You will love your cams though
Teegs is offline   Reply With Quote
Old 11-22-2010, 08:29 AM   #3 (permalink)
spdandpwr's Avatar
where are you ordering your supertech valvetrain from? I can't find it online.
btw, to answer your questions..nitrousg35 researched this topic heavily and sent me this note:
Thiis is what Nikos recommended getting:
springs part # SPR-H1021D
Retainers part# RET-K20A2/T3
Valve Lock part # KPR-5.5/7A
Seats Locator part# SEAT-H1020DS
spdandpwr is offline   Reply With Quote
Old 11-22-2010, 09:40 AM   #4 (permalink)
sivtecboi80's Avatar
Nick
Eibach is a nice spring but they dont make a matching retainer or valvetrain so you need to use eibach with stock retainers which i rather go with a full supertech setup on my ips.
sivtecboi80 is offline   Reply With Quote
Old 11-24-2010, 12:35 AM   #5 (permalink)
jsb03f's Avatar
Josh
thanks spdanpwr for the info so in addition to the cams and chain tensioner that is all that i need?
jsb03f is offline   Reply With Quote
Old 11-24-2010, 12:35 AM   #6 (permalink)
jsb03f's Avatar
Josh
you can find the springs on ebay
Old 11-24-2010, 12:58 AM   #7 (permalink)
Mark
Where are you acquiring these cams from?
blacksnow is offline   Reply With Quote
Old 11-24-2010, 09:23 AM   #8 (permalink)
b.r.i.a.n.'s Avatar
i had the iron cores on my last setup on my old civic. i never got around to tuning them on the dyno but it felt just as fast if not faster as when i had the skunk2 stage 2's in there. i had them for roughly a month before parting out the car.
as far as the spring/retainer combo, i was running the 92 psi supertech dual valvesprings and the titanium retainers. you're somewhat local so if you have any questions or need help with the installation/tune let me know.
b.r.i.a.n. is offline   Reply With Quote
Old 11-24-2010, 10:27 AM   #9 (permalink)
spdandpwr's Avatar
yea, nitrous doesn't even run a tensioner...but, lol, you may as well get it to be on the safe side.
oh, and you'll def need bigger injectors...if you wanna go cheap, get the rdx ones...if you got more loot, get the gopower 525cc (its 5 hundred something). If you plan on modding more in the future get the fic 775s or the id 725s (don't get 1000 or above, too big for non-fi dd).
Old 11-24-2010, 10:29 AM   #10 (permalink)
spdandpwr's Avatar
slow motion motorsports has the 8620s for $1600 bnib -- 3 week lead time.
there were iron core ones for sale here 2 weeks ago
Old 11-25-2010, 01:24 AM   #11 (permalink)
jsb03f's Avatar
Josh
I've heard Nitrous talking about a guy named Nikko over at K2oa.org and he could get you a set for $1300!! Cause, c'mon man, $1600 is nuts for just a set of cams
Old 11-25-2010, 01:27 AM   #12 (permalink)
Mark
His name is "Nikos" on k20a
Old 11-30-2010, 09:03 PM   #13 (permalink)
I Vtec, do you?'s Avatar
Jeremy
If you want the best, you'll pay the price. And it's $1600 from him as well I believe.
I Vtec, do you? is online now   Reply With Quote
Old 12-01-2010, 08:15 AM   #14 (permalink)
redwing497's Avatar
Speaking of Nitrous, where has he been? I haven't seem him in weeks now that I think about it. Did I miss something? If anyone can chime in with IPS knowledge it would be him.
redwing497 is offline   Reply With Quote
Old 12-01-2010, 09:12 AM   #15 (permalink)
spdandpwr's Avatar
lol, i started a thread about him two weeks ago and apparently he's around...but not on these threads.
Old 12-01-2010, 10:13 AM   #16 (permalink)
svmcams's Avatar
The guy who posted is correct. There is no standard matching retainer for the eibach.. Even though it looks like it will fit, it is not a perfect fit and will cause your retainers to break. A custom retainer has to be made for the eibach.
The supertech combo should work fine.
try to see if you can find these parts
svmcams is offline   Reply With Quote
Old 12-01-2010, 11:35 AM   #17 (permalink)
spdandpwr's Avatar
I tried to look for all of those parts...i can find the springs (second hand) but everyone has the T2 retainers and not the T3s.
Old 12-01-2010, 01:32 PM   #18 (permalink)
svmcams's Avatar
Yes, T2 will do for a stock head. I gave you the t3 because I usually get parts for built motors so when using a ported head, sometimes the geometry of the seats and valves change. But for a stock head t2 is the way to go. Good luck
Old 12-01-2010, 01:36 PM   #19 (permalink)
jsb03f's Avatar
Josh
cool everyone, thanks for all the info I am starting to get the necessary pieces together Also, is a chain tensioner really necessary from the get go or could I pass on it for a while untill more funds come in?
Old 12-01-2010, 01:57 PM   #20 (permalink)
jsb03f's Avatar
Josh
also regarding the spring rates springs part # SPR-H1021D are 95 "seat" and 253 "open" while i found the SPR-H1020D for a real good price and are at 100 "seat" and 268 "open" is that a big difference keeping everything else the same? I know that this will cause a little more stress on the cams and valvetrain but is it ok?
Water In Engine Knowledge Needed..only... itsmillz Mechanical Problems & Technical Chat 40 06-05-2010 06:11 PM
Rosion...Noble M12 MKII!!! Capt Canuck Garage 8 07-12-2007 10:05 PM
JBL W12GTi MKII Videos are out mike11202 I.C.E., Electrical, Security, & Navigation 4 03-30-2007 06:06 PM
JBL GTi 12” W12GTi MkII Check this out.. mike11202 I.C.E., Electrical, Security, & Navigation 11 01-09-2007 04:30 AM
