Diego
Valve Clearance Spec & Seals
Hi, I'm finishing my Civic Si K20Z3 with : Go-Power KSi Cams & Valvetrain Upgrade.
The question is what are the values of valve clearance for these cams? Another question, is good or keep the original sparkplugs or i need to put one point more cold sparks plugs? Thanks! Last edited by orangeclockwork; 01-29-2010 at 11:38 AM. |
8thcivic Sponsor
![]() Join Date: Jan 2010
Jeff / Armen
The valve adjustment would be .007" intake and .008" exhaust cold. For slightly more torque you can adjust the exhaust at .010" The factory spark plugs are fine.
www.facebook.com/gopowermotorsports - "like" it! Check Out Our Hondata Flashpro Group Buy! - http://www.8thcivic.com/forums/go-po...l#post11142038 |
Diego
I found the service manual for Civic Si 06 + and the values are slightly different.
Intake: 0.009 - 0.23mm Exhaust: 0.010 - 0.27mm ![]() The values are different when running cams? Jeff what are the values in mm for comparison? Last edited by orangeclockwork; 01-27-2010 at 09:47 AM. |
E-Tunez FTT!!!
![]() Join Date: Nov 2008
Rulo
Diego,
I thought you asked this question via PM a while back, or was it Marcin? I forget there's so many people getting KSi's now .I'm using this on my setup: .008 = 0.2032 millimeters .010 = 0.254 millimeters |
#11 (permalink) |
Diego
I add another question.
I received my order, retainers, dual valve springs and 16 Exhaust Valve Seals in blue color. But not received the intake valve seals, exhaust valve seals can be used for the intake? Are they the same? Thanks |
#12 (permalink) |
8thcivic Sponsor
Jeff / Armen
We use the same seals for the intake and exhaust. The exhaust seals are made to take a little more heat and we use those on both.
| First service: gearbox oil change and valve clearance adjustment | Jeroen1000 | Mechanical Problems & Technical Chat | 4 | 08-26-2008 11:03 AM |
| valve clearance | slvrSI2.0 | Cams & Internals | 0 | 04-23-2008 11:00 AM |
| 2006 TSX Valve Clearance | nbilyue | Cams & Internals | 2 | 11-14-2007 04:15 PM |
| R 18 valve clearance | yohanes | Mechanical Problems & Technical Chat | 3 | 10-06-2007 09:19 PM |
