Go Back   8th Generation Honda Civic Forum > Regional Civic Owners - U.S. > California > California South
Old 11-10-2006, 06:53 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
StyleZ's Avatar
hid installation help.
is anyone in so cal willing to help me install my hids?
StyleZ is offline
Old 11-10-2006, 06:59 PM   #2 (permalink)
2006civiccoupe's Avatar
its pretty straight forward, its real easy !! did they bring instructions?
2006civiccoupe is offline
Old 11-10-2006, 07:33 PM   #3 (permalink)
SiRyan's Avatar
If it is plug n play, its pretty much self explanitory.
SiRyan is offline
Old 11-10-2006, 07:36 PM   #4 (permalink)
StyleZ's Avatar
i dont know where i can mount the ballasts and did you guys use the black thing to hold it or did you guys just use double sided tape?
StyleZ is offline
Old 11-10-2006, 07:49 PM   #5 (permalink)
blaznhot_23's Avatar
MS Motorsports kicks ass!!!
it depends on what ballast you have ??? if its slimline denso you mount underneath the headlight itself or on the body behind the headlight pocket. caveman74 / izzy is who mounted it this way. if you have hella gen 3 you might be able to mount in the same fashion or underneath the headlight on the body/frame support rails...sickyute is who mounted it this way. if you have matushita gen 2 they should be able mount like denso slimline...do a search for either of the members and you'll see some pics...I'm doing a retro on my headlights and am i going to mount them on the body somehow prolly like caveman's way...now i have to get to the task of making my custom wiring harness first though:) hopes this helps you out a little...
blaznhot_23 is offline
Old 11-10-2006, 08:31 PM   #6 (permalink)
mmm...what a tasty burger
Nomar06's Avatar
You can mount the ballast right above where the air bag sensor is behind the headlights. The is a small perch with a whole already there. I placed mine there with the ballast holders that came with my kit.
Nomar06 is offline
Old 11-10-2006, 08:36 PM   #7 (permalink)
M U K E Y
Mikey6p's Avatar
Mukey
Take the bumper off to make it 1297349234 times easier.
If you really need help, I can help you out.
Mikey6p is offline
Old 11-19-2006, 03:36 AM   #8 (permalink)
trixnrice's Avatar
I just used double sided tape, and then adhesive foam tape to reduce vibration to the ballasts. I mounted the passenger side ballast right under/behind the high beam socket, theres a flat metal part of the chassis. the driverside ballast i mounted vertically right in front of the battery, to the right of the coolant resevoir. laTEs.
trixnrice is offline
Old 11-20-2006, 09:14 AM   #9 (permalink)
cappykd's Avatar
Kirk
Any of you guys have pictures of your cutoff? I want better lights than stock but I don't wanna get flashed all the time..
cappykd is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/california-south/19640-hid-installation-help.html
My Civics HID DIY Installation - Page 14 - 8th Generation Honda Civic Forum This thread Refback 02-24-2008 04:48 PM
My Civics HID DIY Installation - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 06:54 PM
HID Xenon Headlight Conversion Kits CorSport CorSport 74 07-16-2008 02:24 PM
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-05-2007 11:36 PM
Question about HID Installation Tri3Dent Lighting, H.I.D.'s, & Neon 6 11-19-2006 04:06 AM
New Black EX SED. HID TIME.. or. do it right? jehu4u Lighting, H.I.D.'s, & Neon 6 03-29-2006 12:14 AM
