Coolant problem/queston
Hey guys,
So while installing my Fujita Sri i disconnected the coolant tube and hella coolant came out. i checked the reserved and it was empty hhaha. I looked in the manual and it said that i need to get honda's coolant, but i put in Peak 50/50 coolant. should i be ok? or do i need to bring the car in to get flushed and replaced with honda's coolant? thnxs pplz |
It should be fine. When i was installing the IMG the same thing happened to me. And i used the same coolant. I dont think that should be fine. But the next time i do that has to deal with coolant i will buy some of the Honda one, that way i can keep everything with Honda fluids.
Man!, I always read people spilling the coolant out when they install intakes,...why?. Is there a way to prevent this from happening so you don't have to worry about the mess or refilling?.
To the OP, yes you should be fine. As long as it was 50/50. If you're really worried, just try to flush it out yourself and put the HONDA type 2 coolant in. Last edited by Johnold; 04-20-2008 at 03:47 PM. |
i spilled fluid cuz in the Fujita sri manual i shows the coolant being replaced, but u really dont have to change the coolant tube so... haha yup the manual sucked.. well thnxs for the help guys.. i just dont want to kill my motor because im not using hondas coolant
I do look like a monkey
The reason why coolant is lost is because in the installation manual for the intakes, it tells you to remove 2 hardpipes that are joined together. You replace those hardpipes with hoses that place it that come with the intake kit. You can avoid the whole coolant situation by just leaving the metal pipe in there. Alot of people prefer not to do that because of the way it looks, all disconnected and not belonging there. It's on you on what you want to do. I left mine there because I've yet to do a throttle body bypass. When I stop being lazy and do the bypass, I'll remove the hard pipes.
My Mods: Home made CAI, BCRH, QTP Electric Cutout, P2R TB spacer and thermal gaskets, Hondata IMG |
| JDM emblems(quick queston) | Micah | Inside and Out | 7 | 03-06-2008 11:40 PM |
| Coolant Problem | SacrificeTheory | Bolt-Ons And All-Motor | 25 | 09-04-2007 07:56 PM |
| Coolant Res. | HondaFREAK | Mechanical Problems & Technical Chat | 4 | 03-17-2007 09:36 AM |
| What coolant should i use... | lou10788 | Mechanical Problems & Technical Chat | 7 | 11-07-2006 03:37 PM |
| Tint options: Queston... | GlennS | Inside and Out | 4 | 07-06-2006 07:24 PM |
