Old 06-04-2008, 11:53 PM   #1 (permalink)
p2r TBS port not quite drilled?
so i received my tbs this evening and it appears that the port that you would normally plug up is only half drilled through. anyone elses like that? also i did not receive a plug... is this safe to install?
khronox is offline   Reply With Quote
Old 06-04-2008, 11:55 PM   #2 (permalink)
KSE
KSE's Avatar
Albert
you NEED that plug
and it's not supposed to screw all the way in..
KSE is offline   Reply With Quote
Old 06-04-2008, 11:58 PM   #3 (permalink)
tite681's Avatar
ButchMX!
Mine doesn't look drilled all the way and I didn't use the plug. Runs fine.
tite681 is offline   Reply With Quote
Old 06-05-2008, 12:04 AM   #4 (permalink)
oHsevenGG_Si's Avatar
mine came that way as well however i received the plug BUT, ive been informaed that its supposed to be that way until you actually run NOS through it or something then you drill the hole out urself. the plug isnt needed until you finish the drill job and dont have anything in the hole.
oHsevenGG_Si is offline   Reply With Quote
Old 06-05-2008, 12:53 AM   #5 (permalink)
i had the same question about my tbs, so i emailed the guys at p2r and they said..
"You actually do not need to install the plug on your spacer if you just got it. We are no longer drilling all the way through on the spacers. We only start the hole now."
However, on my install the guy forgot to take out the old stock gasket....could this create any problems?
sabre15 is offline   Reply With Quote
Old 06-05-2008, 03:56 AM   #6 (permalink)
iomatic's Avatar
Doubt it. You could follow my install and get it off it really bugs you.
P2R spacer and gaskets install
iomatic is offline   Reply With Quote
Old 06-05-2008, 09:49 AM   #7 (permalink)
KSE
KSE's Avatar
Albert
o0o0o0o0h I thought your hole was drilled half way but went all the way thru. I think you should still plug it though
TBS- Helix VS P2R Question miketat594 Bolt-Ons And All-Motor 3 05-09-2008 04:02 PM
P2r Tbs Vs Cai redvtech07 Bolt-Ons And All-Motor 8 05-04-2008 11:59 PM
K&N v2 w/P2R TBS FG2MN Bolt-Ons And All-Motor 16 04-15-2008 12:43 PM
P2r Tbs c130turboprop Bolt-Ons And All-Motor 15 12-25-2007 01:54 AM
Fujita SRI and P2R TBS BiggJ12 Bolt-Ons And All-Motor 12 09-02-2007 10:43 PM
