Old 05-18-2008, 01:31 PM   #1 (permalink)
James
Vibrant Help Needed Asap
So a friend and I are putting on my vibrant exhaust, we got all the stock piping out and the first part of the vibrant piping that attaches to the end of the cat won't fit...are we supposed to take the stock bolts out? If so, how? Or what else is there to do....? Thanks
06kronsi is offline
Old 05-18-2008, 01:38 PM   #2 (permalink)
James
bump...the flange won't fit on the stock bolts from the cat...
06kronsi is offline
Old 05-18-2008, 01:43 PM   #3 (permalink)
HTX
HTX's Avatar
the stock cat has fixed bolts attached to it correct? How will it not fit? Got any pix?
HTX is offline
Old 05-18-2008, 01:43 PM   #4 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
you cant use the stock cat with the vibrant. you need seperate bolts and a flange to bolt it up to the exhaust.
is Missy a squirter?
http://killyourself1.myminicity.com/env build my city.
Zeuceone is offline
Old 05-18-2008, 01:46 PM   #5 (permalink)
James
where do you get the bolts/flange?
and how do you get the stock bolts out?
06kronsi is offline
Old 05-18-2008, 01:50 PM   #6 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
who ever you bought the header from should have the bolts and flange. you cant take the bolts out.
Zeuceone is offline
Old 05-18-2008, 01:53 PM   #7 (permalink)
James
I'm talking about the catback exhaust, no headers...
06kronsi is offline
Old 05-18-2008, 01:56 PM   #8 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
damm. i didnt read that correctly.
Zeuceone is offline
Old 05-18-2008, 01:57 PM   #9 (permalink)
James
ha, no problem...so should it fit?
06kronsi is offline
Old 05-18-2008, 02:07 PM   #10 (permalink)
Tw4DoorSi's Avatar
Luis
your prolly installing it wrong...took like 15 minutes to install the exhaust with out a lift
Tw4DoorSi is offline
Old 05-18-2008, 02:11 PM   #11 (permalink)
emile's Avatar
Emile
stock cat's bolts come right off. try using some wd40 on that sucker. heres a pic i managed to snap during the install for my vibrant last friday. its not great but i think you can see that we used the stock bolts to test fit the exhaust.
emile is offline
Old 05-18-2008, 02:35 PM   #12 (permalink)
Kronos_32's Avatar
I had this problem but mines was used and already welded. it wouldnt bolt up right so i had to take it into my shop and have him round out the edges inside the vibrant fitting to make it bolt up. i think thats what you may have to do. it took 100 bones to do it but i got it done right
Kronos_32 is offline
Old 05-18-2008, 03:01 PM   #13 (permalink)
Mr. Cowl Induction
NitrousG35's Avatar
Wild VTEC'n Bill
When I had my Vibrant cat-back installed, we just reused the stock bolts and nuts. Since my car was fairly new and had zero corrosion on it, the nuts came off easily. Remember that the factory uses studs on the end of the cat.
Make sure to use a stainless steel gasket between the cat and the Vibrant cat-back. I had a slight leak because I didn't use one. A Vibrant stainless steel gasket bought from SCTuned took care of that.
NitrousG35 is offline
Old 05-18-2008, 03:21 PM   #14 (permalink)
James
I ended up having to file down the inside of the flange connection to the cat and then it slid on there...I didn't put a gasket in between the cat and piping though...anybody else do that?
06kronsi is offline
Old 05-18-2008, 03:26 PM   #15 (permalink)
Kronos_32's Avatar
Almost the whole vibrant team on here used some sort of gasket bro. Mines is a composite foam one which expands.
Old 05-18-2008, 03:52 PM   #16 (permalink)
James
SCTuned the best place to get one?
06kronsi is offline
Old 05-18-2008, 03:53 PM   #17 (permalink)
Kronos_32's Avatar
Yeah they sell like 2 for three dollars or something like that.
Old 05-18-2008, 04:08 PM   #18 (permalink)
James
so do I want the 2.5' 3 hole?
06kronsi is offline
Old 05-18-2008, 10:11 PM   #19 (permalink)
James
is that right ^^^?
the gasket is $2.90, and the cheapest shipping option is $11
06kronsi is offline
Old 05-18-2008, 10:30 PM   #20 (permalink)
HTX
HTX's Avatar
go buy one at an auto parts store. those arent even worth paying shipping on.
HTX is offline
Would I throw CELs with Vibrant RH w/ HC & Vibrant Catback Exhaust? Vinc84 Bolt-Ons And All-Motor 17 02-20-2008 05:09 PM
Help Needed ASAP...Pic of Volk valve stems installed.... 06Fg2 Wheel And Tire Upgrades 3 02-08-2007 12:27 AM
Civic Coupe EX and SI owners Help Needed!! connectors needed!! PugManTerror I.C.E., Electrical, Security, & Navigation 10 12-10-2006 08:44 PM
Assistance Needed ASAP Kakashi Lighting, H.I.D.'s, & Neon 3 10-08-2006 07:46 AM
