Old 05-15-2008, 04:14 AM   #1 (permalink)
07_FG_4Dr_S.i.'s Avatar
Jason
Exclamation Skunk 2 camshafts make ya wana go vtac!!!! sk2 ftw ?
i looked them up on skunk2 site and the search results showed me k20a2 results are these rsx type s motor cams ? and do i need exhaust cam gear and intake cam gear or just exhaust ?
would these cams be alright with nitrous ? anyone i should call should i give a call to skunk2 and ask them ?oe hondata or some1 ?
I am runing injen cai ,Buddy Club RH, LSD Power 4 Exhaust, P2r throttle spacer, Zex 75 shot Nox ,
I am really intrested in these Skunk 2 stage 1 cams but am not sure if they are nitrous applicable and which are the cams i need like part number or for what motor couldnt find them on corsport for our cars and cam gears also
I`m trying to get as much info as possible before i make my motor go boooom and end up going built k24block with type r head and then result in being broke lol
07_FG_4Dr_S.i. is offline
Old 05-15-2008, 03:06 PM   #2 (permalink)
k20beast's Avatar
zack
if your running nitrous i would go with F/I cams of your choice... and if you get cams you will need a good tuning source such as k pro which isnt avalible now. For the cams gears idk if you even need aftermarket? they may can run with stock but idk for sure on that one
k20beast is offline
Old 05-15-2008, 03:10 PM   #3 (permalink)
xrs54's Avatar
Originally Posted by Grizam303 View Post
My roommate got a hybrid civic, but I don't regret the si one bit. He gets more MPG, but I get more FPG (fun per gallon). That's kinda why I bought the car.
xrs54 is offline
Old 05-15-2008, 03:30 PM   #4 (permalink)
hawjdude's Avatar
you'll be fine w/ the skunk2 stage 1 cams w/ your nitrous setup. A gain of 10whp would be typical. The cams for the rsx type-s (k20a2 or k20z1) are the ones you wanna get for your car. You might also still need to get the exhaust cam gear w/ the skunk cams. not sure on this anymore. i'd check first w/ skunk before purchasing.
hawjdude is offline
Old 05-15-2008, 04:36 PM   #5 (permalink)
i have a similar question to this seeing as i am looking at the same cam set up for my car, but i cant seem to find the skunk 2 exhaust cam gear anywhere on skunk 2's website
LL36d is offline
Old 05-15-2008, 06:02 PM   #6 (permalink)
Jason
ive tryed calling skunk2 alllllllllllllll dayyyyyyyy finally got through like 5 min ago they told me these stage 1 cams n/a are perfectly fine and should work great with my setup including nitrous shot he just suggested i have a/f tuned but theres no tuning for our cars and i would def not wanna go lean ....obviously so i probably wont end up getting these cams just because i need tuning i thought i would be able to slap these babies on and have atleast a good 10whp gain without any issues but im not gonna put these on if theres a risk runing lean
Old 05-15-2008, 06:03 PM   #7 (permalink)
Jason
i also asked whats up with every1 saying sk2 cams fukkkkk up our chain tensioner he said its only an issue when people hand turn the crank and you see chain slack but once the motor is on and being ran theres about 20punds pressure of oil so there is no slack on chain tensioner
Old 05-15-2008, 10:19 PM   #8 (permalink)
Jason
Any opinions about runing these cams with nox, and can arm fic tune afr?
Old 05-15-2008, 10:30 PM   #9 (permalink)
ImAuthenticFTW's Avatar
Mike Wagner
just a heads up on those who want cam gears......only run the exhaust cam gear, if you put an aftermarket intake cam gear you will lose your vtec
ImAuthenticFTW is offline
Old 05-16-2008, 03:11 AM   #10 (permalink)
Jason
^^^^ doesn't our intake cam gear have like a port for the oil pressure for vtec or somewhizznit like that ? Anywho any1 on this site run nitrous with aftermarket or tsx cams?
I don't wana fix my car. Mr Big Mechanical Problems & Technical Chat 5 04-22-2008 05:54 PM
Camshafts sb12007 Bolt-Ons And All-Motor 5 03-13-2008 08:24 PM
