Old 05-07-2008, 12:15 AM   #1 (permalink)
tite681's Avatar
Location: NorCal Most Of The Time / SoCal Some Of The Time
MAF Sensor Position. Does it matter?
I have a home made intake using a modified MAF. If you're looking from the front of the car, the MAF sensor is probably 30 degrees rotated to the right. Does it really matter how the MAF sensor is positioned? Or does it have to be positioned straight like stock? If it does indeed matter, what are the consequences? Thanks in advance.
tite681 is offline
Old 05-08-2008, 11:00 AM   #2 (permalink)
No one has done this on the Civic that I'm aware of, but I can tell you from the mustang world, change the position of the MAF would cause the car to lean our a little and cause rough idle and stall outs. It matters....
chicagomike is offline
Old 05-08-2008, 03:49 PM   #3 (permalink)
k20beast's Avatar
zack
i would leave it in the stock position if i was you. it will prob. through reading off if its moved any... bc i kno it will deff f**k it up if you put it in backwards. (ppl on here have done that not me)
k20beast is offline
Crankshaft Position Sensor CEL? mas3423 Mechanical Problems & Technical Chat 9 11-04-2007 01:13 PM
MAF sensor on CSXS or TypeR ? benmunger Civic SI 10 09-23-2007 01:29 AM
Fujita and MAF sensor install BiggJ12 Bolt-Ons And All-Motor 2 09-02-2007 01:38 PM
Throttle Position Sensor HELP PLEASE!!!!!! slostjoe Forced Induction And Nitrous 3 06-15-2007 12:48 PM
MAF Sensor and Aftermarket Intakes blueroadster Bolt-Ons And All-Motor 21 05-29-2007 12:27 AM
