Throttle Response Question
is there any easy way or simple way to get better throttle repsonse like to when u rev..it revs up faster ...like someone told me to tighten the throttle cable but i dunno if that would be a smart move or what... anyone have any ideas or know something i can get?... any help would be appreciated... thanks!
first off, we dont even have a throttle cable, we have drive by wire (dbw) which means its all electrical. the only way to get better response is to get an intake really, other than that, your pretty much stuck with what u have... i did see, on a euro website, for their Si's over there, they have a dbw booster that supposably made the response faster, but i have yet to see it here in the U.S
#3 (permalink) | |
Kill Your Self Krew
get the proper intake.
#14 (permalink) |
the hardest part is taking off the crank bolt. but once i got the balls to try it. i got a socket and secured it on a part of the inner fender and barely cranked the key, not enough for it to fully turn on, and it popped the bolt right off. it took maybe like 2-3 hours
#15 (permalink) | |
Do this. It will make everything soooo much easier. Go to some shop, perferably a small local one that works with honda's (As they are known to tighten the crank pulley bolt really tight), and have them knock loose the crank pulley bolt for you. This will make everything so much easier. Oh, and Im not sure if you've done this before but it was my first time to do it and caused me a lot of trouble, but to remove the belt get a serpentine belt tool and slowly push towards the car to release pressure on the auto-tensioner. |
#17 (permalink) | |
If you opt to get real technical, Go find a older version of your motor and retro fit a cable system in, with money anything is possible, A time attack car may get better use out of a cable set up, a daily driver will be far better on TBW system in the long run feel never changes, unlike the cables of the past. As far as response go's it's not the fault of the TBW system it's part to do with the motor's they are put on, Honda started making small high revving engine's not giant power plant's. These car's want to be revved hard therfore the bottom end is not the best power, the best power come's up top. high in the powerband. Think of it like a dirtbike rev it up and drop the clutch, no rev you stall. Now back to Honda motor's they are oversized dirtbike high rev motors, so give it a bit a gas first then it'll pull harder out the box. The fun part of these car's is that they rev alot longer than other car's making them pull farthar and harder on the top. You may not fire off the line like an AWD Evo or Sti, but you rev higher down the track where most car's bump out, so as for response just use what you have in a diff manner and you will enjoy it more. For the record I drive an Si, so I'm not knockin the Honda motor. I'm just sayin they have been like this forever, I started on a 93 hatch with a b16 swap then went to a Teggy Type R to a RSX type S to the Si ,each and everyone wanted to be revved. |
#19 (permalink) | |
I think the guy was referring to the delay in revs, we all agree that the honda likes to be revved but the delay is what bothers him. |
#20 (permalink) |
I don't feel a delay in the rev, I have a SRI, Catback, Hondata reflash,Helix TBS, CFR UD pullys. If your referring to the delay that you get on an Si, That is caused by the VSA, Turn it off and you loose the delay, for instance if you go to a track and wanna spin the tire's, if the VSA is on it bumps the brakes on stopping the effect, turn it off spin all you want. It's an electronic LSD not a Mechanical, All this electric crap get's linked together for safty due to the fact, that not everyone who buy's today's car's can drive them correctly, if you drive with the VSA off it's a different car, You have more feel with it off. It does however serve a positive purpose when you come into a turn to hot or oversteer a little it correct's with braking, And some people still need this.
If he feels somthing more than he may have bigger problems, if it is only a matter of keeping the motor in the Vtec then it's driver error, meening that without holding it up there between shift's the cam return's and you loose the power band, as for that Reflash the car and the Vtec hit's faster or just power shift the car and keep it high in the RPM's. You can alway's go and find a friend that has that CX civic of yesteryear and then you really get to feel unsafe you know 0 - 60 in half hour ![]() |
| throttle response | 06Halo | Bolt-Ons And All-Motor | 22 | 05-27-2008 12:08 AM |
| Throttle Response | No.11 | Civic SI | 23 | 04-29-2008 02:43 AM |
| Poor throttle response/hesitation | RRSI | Mechanical Problems & Technical Chat | 5 | 08-22-2007 02:45 PM |
| Throttle response when rolling? | Bricks | Civic SI | 14 | 04-23-2007 04:43 PM |
| Terrible throttle response | articsilber323 | Civic SI | 23 | 12-09-2006 11:04 AM |
