Old 05-04-2008, 01:35 AM   #161 (permalink)
206si's Avatar
R. Pineda
^ I'd like to know that too.
If yes, can we pre-order?
206si is offline
Old 05-04-2008, 02:33 AM   #162 (permalink)
8thcivic Sponsor
AJR Joey's Avatar
Originally Posted by ortivt6 View Post
^when would it be available and how much???
It should be avaiable by the end of this month, just hoping that the shipping is not delayed from Japan.
Originally Posted by Xenin View Post
the end of the month.
price is TBA.
Yes, it should be by the end of the month, price is TBA. I hope we can get a price going on next week for everyone.
Originally Posted by BiGGiE View Post
Are you guys just making it for the FG2 now? or are you guys making it for the whole family at once?
We already made teh FG2 one, in our picture that we have supplied is the FG2, but once the intake is released it will be out for all the 8thgens.
Originally Posted by Firestrife View Post
water splashes?
dude go look at your bumper and fender area. see if water can splash in that region.
Do not worry about water/hydrolocking issues. The intake was also made to not have this issue, why would we make something with a duct that can cause hydrolock? We would'nt not have something like that! Do not worry, unless your driving through an Ocean/Lake, its over =X. I do not think any of use drive through anything that big. Splashes, you should not even worry about it.
Originally Posted by Excalibur View Post
Will you guys just off the bottom piece for people that don't want the carbon fiber?
Off the bottom piece as in the duct? If you are asking that no we are not. The intake comes with all the supplied hardware for installation and I do not think we will sell anything seperately.
Originally Posted by knh564 View Post
this looks like a real solid piece, good work ajr, will there be a group buy offered?
Thank you, we will dicuss something about Group Buy because we have been thinking about making a Group Buy on a product of ours for the 8thgen, but we will discuss.
Originally Posted by ImBiginKorea View Post
Just to ask; when you run the dyno and test it, can you post the afr for the dyno AND in motion? I'm curious how the maf/ecu..... will adjust to all the added air.
--Korea
When we dyno it we can ge the AFR for a stationary dyno, but it is impossible to get a in motion dyno. How can we get a dyno while the car is driving. It will not affect the AFR at much or at all if it is stationary or in motion.
Originally Posted by thisisdudewhoru View Post
Can we have a ball park price range? If its less than 350 I will cancel my deposit on my injen intake since they are still on backorder.
Sorry as for ball park it is really hard at the moment, the item we just tested was 2 days old. Were waiting to get the actual product soon then we can get the ACTUAL price. Hope that we get it in next week.
Originally Posted by NitrousG35 View Post
Quite simple really. Joey said that it could be hooked up to the foglight on an FG2 or one could use the lower bumper intake and connect flex tubing to the scoop they are using.
This is a high pressure area. The air will be forced in do to the higher pressure created at the lower bumper area. Once this air enters the inlet, it will be rammed into the intake airbox.
If there is not a connection to the foglight as Joey mentioned, you still would get some air in there, although not as much as if the foglight area is ducted to the scoop.
I explained why it will make 8-10 hp in a previous post. For every 10 degree drop in intake temperature, there is a corresponding 2 hp gain. Bearing in mind the ambient air temperature inside a hot engine bay, it is not unrealistic for air temps to be 40-60 degrees cooler due to the rammed air, which is denser, and the enclosed airbox.
I for one am quite pleased with the overall look of the airbox. My only concern as I stated previously is the MAF sensor position. I still contend it would be better to run a sectioned MAF housing and connect to the airbox, rather than installing the MAF sensor in the cover.
The other issue that is pressing is price. I would assume that wil the carbon fiber cover and scoop/duct, the price will be close to $500 or more. If you look at King Motorsports Type R airbox for the Si, it is $700 w/o cf. If you look at the Gruppe M, which is almost $1200, then, it is a bargain.
BTW, water should not be a problem unless you drive through water one to two feet deep. The T1R seems to be quite similar to the factory setup for drawing air in.
Thank You Nitrousg35 for your comment, everything you have stated is in fact true. People should not worry about the splashes at all, you should only worry if you run over a super galore of water that is really deep. As for the MAF sensor it is most likely will be there, if we decide to change the MAF sensor it shouldnt be a hassle.
Originally Posted by drfters13 View Post
sweet... im really thinking about getting this. its just that carbon fiber top i kinda want it to look stock just in case i get pulled over. would this fit even if you had the tb spacers?
I have been looking about the TB spacer you guys are talking about, it should fit with no problem. I have look at the TB spacer with the stock hose to the intake and after looking over with ours, there should be no problem at all. I do not see why it would not fit. Shouldnt worry about it too much because it should fit with no issue. As for the CF top, im sorry it only comes in CF. I know there are people worried about when you get pulled over, the thing I love about the intake that is coming out is that it looks like stock and you will not have a big gap like all the other CAI out there.
A&J Racing International
TEL: (604)279-0329
URL: http://www.aj-racing.com
AJR Joey is offline
Old 05-04-2008, 09:48 AM   #163 (permalink)
ortivt6's Avatar
Ant
Any info on how much horsepower gains???
ortivt6 is online now
Old 05-04-2008, 09:53 AM   #164 (permalink)
F-1 Si's Avatar
Peter
Looks real nice in for results
F-1 Si is offline
Old 05-04-2008, 09:57 AM   #165 (permalink)
Sexy6Speed's Avatar
Alyssa
wow, looks like a nice setup. in for details
Sexy6Speed is online now
Old 05-04-2008, 12:57 PM   #166 (permalink)
skandal57's Avatar
Im ready to buy if the price is fair.
So can we see pics of ALL the parts included?
skandal57 is offline
Old 05-04-2008, 01:04 PM   #167 (permalink)
BiGGiE's Avatar
Chris
^^ i think its just the lower air duct, the top airbox cover and a filter
BiGGiE is offline
Old 05-04-2008, 01:14 PM   #168 (permalink)
ImBiginKorea's Avatar
Hopefully Its around the 400 dollar mark like this T1R intake for the fit. If so then it is a strong possibility.
--Korea
ImBiginKorea is offline
Old 05-04-2008, 01:21 PM   #169 (permalink)
Gr3y Goose's Avatar
John/Goose
yeah nitrous is right, if the fit one is 400, then this one is an easy 500+
Gr3y Goose is offline
Old 05-04-2008, 03:29 PM   #170 (permalink)
Xenin's Avatar
if you just want the lower intake duct, search this thread:
Japanese Websites FD2 Civic Type R Parts
now stop asking if AJR will sell the lower intake duct by itself.
Xenin is offline
Old 05-04-2008, 03:56 PM   #171 (permalink)
Gr3y Goose's Avatar
John/Goose
you mentioned the wrong company
Old 05-04-2008, 04:39 PM   #172 (permalink)
Louder than 4 F404-GE-400
Paul
Are you effing serious? Have you not read any of the last 3+ pages?
Waking up dead inside of my head will never never do, there is no med, no medicine to take.
I've had a chance to be insane, asylum from the falling rain. I’ve had a chance to break.
Sirbelch is offline
Old 05-04-2008, 05:58 PM   #173 (permalink)
Sexy6Speed's Avatar
Alyssa
lol at above
Old 05-04-2008, 09:28 PM   #174 (permalink)
8thcivic Sponsor
AJR Joey's Avatar
No, it comes with everything. Lower air duct, top/lower, filter, arms, everything.
TEL: (604)279-0329
AJR Joey is offline
Old 05-04-2008, 10:09 PM   #175 (permalink)
PR_S14's Avatar
Freddy
I'm very interest in dyno results and AFR's myself.
The MAF placement blows my mind. I'd be very surprised if it continues to function anywhere near like stock.
PR_S14 is offline
Old 05-04-2008, 10:24 PM   #176 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
oiled filter?
is Missy a squirter?
Zeuceone is offline
Old 05-05-2008, 01:26 AM   #177 (permalink)
fg2!kid's Avatar
Eric
looks like a K&N filter
fg2!kid is offline
Old 05-05-2008, 01:48 AM   #178 (permalink)
Image Hosted by ImageShack.us
Toys For TotsMember
interesting looking intake... in for results and price
bizzybearfigiblue is offline
Old 05-05-2008, 02:04 AM   #179 (permalink)
saiaba's Avatar
Ryan
meh 6 pages of the same questions.
Looks hawt.. still not down with paying 350+ for 9hp.
saiaba is offline
Old 05-05-2008, 02:55 AM   #180 (permalink)
Xenin's Avatar
what? T1R? this is an AJR thread about them selling the T1R intake. not T1R selling the T1R intake.
Xenin is offline
