Old 05-01-2008, 05:09 PM   #1 (permalink)
Fujita SRI Install Question
I didn't see anything about this anywhere, so I was just curious if anyone else with this intake (or I assume any other SRI) has dealt with this. I can't seem to find any way to angle the intake so that the coupler attached to the throttle body ISN'T resting on the upper radiator hose. I know that the factory intake had a rubber spacer and "clamp" that went around that hose, but it just seems like with enough vibration, heat, etc that this could pose a problem, but maybe I'm just being paranoid. Is this just standard for how this thing is installed?
abulmash is offline   Reply With Quote
Old 05-01-2008, 05:15 PM   #2 (permalink)
Master of Magnetism
E. Honduh's Avatar
Edmond Honda
Did you drink the NOS Energy Drink before the install??
But seriously I just got my Fujita and was wondering the same exact thing.
E. Honduh is offline   Reply With Quote
Old 05-01-2008, 05:18 PM   #3 (permalink)
c130turboprop's Avatar
take the factory stock tubing out from underneath the radiator hose, it just twists off and u should be good. it will touch maybe a little bit then, but not much. i have a sri with throttlebody spacer and mine doesnt touch.
c130turboprop is offline   Reply With Quote
Old 05-01-2008, 05:23 PM   #4 (permalink)
I'm not sure I follow. I don't think there is any factory tubing that is pushing the radiator hose up. It's barely touching, but it's not really something I want rubbing.
Old 05-01-2008, 05:33 PM   #5 (permalink)
MIC.
i just installed my sri yesterday and i was wondering the same thing as well. i just left it alone, its rubbing but not too much. should i be concerned though?
M1C. MON5T3R is offline   Reply With Quote
Old 05-01-2008, 07:18 PM   #6 (permalink)
shatchi's Avatar
Joe
No I wouldn't be worried, it wont tear open the hose or anything. Just heat up the intake tube a lil when the motor is off. I've had mine for about 10K and its running strong still. Hope this helps!
shatchi is offline   Reply With Quote
Old 05-01-2008, 07:22 PM   #7 (permalink)
ricetastic's Avatar
Faisal
question -- did you order a fujita? and it came recently?
ricetastic is offline   Reply With Quote
Old 05-01-2008, 07:37 PM   #8 (permalink)
Thanks. I was mainly looking to see if this was common. I mean, it's not the metal pipe on there, it's silicone on rubber, but generally you don't want water hoses touching anything else that could rub through or cause damage by scoring. I'll keep an eye on it, and maybe play with the angle or put some kind of foam spacer in there.
Fujita SRI install Q SiConvert887 Mechanical Problems & Technical Chat 2 04-19-2008 02:57 PM
Fujita SRI install question Noyty Bolt-Ons And All-Motor 10 04-18-2008 03:19 AM
Fujita SR install question bigsean4u Bolt-Ons And All-Motor 8 03-31-2008 09:07 PM
fujita sri install --love it hunting69 Bolt-Ons And All-Motor 34 03-12-2008 03:23 PM
* Merged * help with fujita SRI install GG's Anatomy Bolt-Ons And All-Motor 20 05-13-2007 01:15 AM
