Old 04-05-2008, 05:07 PM   #1 (permalink)
Moonkei's Avatar
Aye.
Weird Muffler Sound
Any ever had this problem? Latly, I've noticed when reving a bit high in 1st and 2nd that when I gas it a little hard, it sounds like something is vibrating in the muffler area.
I got under to check, even took out the Chrome cover, did a rev test and it still sounds like something is vibrating in that muffler area. I don't know if it's excatly a vibrating issues, but it just dosen't sound right when I rev the car.
Any ideas as to what is causing this?
Moonkei is offline
Old 04-05-2008, 05:14 PM   #2 (permalink)
Slowroll90's Avatar
Aaron
could be anything from the heatshield resonationg
to something broken with in the muffler
Slowroll90 is offline
Old 04-05-2008, 05:19 PM   #3 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
Do you have a race header?
Excalibur is offline
Old 04-05-2008, 06:36 PM   #4 (permalink)
Moonkei's Avatar
Aye.
Yes I have a DCRH, but never had this problem till about 2 weeks ago.
Looks like I might have to get it replaced soon.
Moonkei is offline
Old 04-05-2008, 06:51 PM   #5 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
It's your muffler. It happens with race headers after time. The internals go bad and you lose the good sound that you began with when you first put on the race header.
Old 04-05-2008, 06:54 PM   #6 (permalink)
Moonkei's Avatar
Aye.
Damn, any input as to what I should do? Replace with a new one or go aftermarket?
I don't want to install a new one and have to replace it 4 months later, which is how long I've had the header in.
It's Stock btw if anyone is wondering.
Moonkei is offline
Old 04-05-2008, 07:01 PM   #7 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
The muffler will just go bad again. I would go get an aftermarket setup. I would look into the ws2, sp2, or tanabe for something quiet that matches the size of the dcrh you're running.
Old 04-19-2008, 02:07 PM   #8 (permalink)
jello67890's Avatar
Joel
mine did it in lower rpm... i found the solution to mine, it was one of the rubber exhaust mounts, the one right before the axle back. try cutting some of it so it doesnt rub and check in with this again... it did it for me
*it sounded metal almost but it wasn't* weird
jello67890 is offline
Old 04-19-2008, 08:10 PM   #9 (permalink)
EuphoricRhythm's Avatar
sounds like your muffler bearings are going out
EuphoricRhythm is offline
Old 04-19-2008, 09:42 PM   #10 (permalink)
ricetastic's Avatar
Faisal
Yeah check your VTEC manifold.
ricetastic is offline
Weird sound when my car accelerates Wierdochild89 Mechanical Problems & Technical Chat 8 10-31-2007 09:30 AM
Creaking/weird sunroof sound soysauce1523 Mechanical Problems & Technical Chat 1 10-06-2007 07:10 PM
Weird Sound From Under My Car Young Money (K20) Mechanical Problems & Technical Chat 4 08-04-2007 01:44 PM
weird sound?!?! falkon57 Mechanical Problems & Technical Chat 6 04-08-2007 03:01 AM
Does the horn sound weird to you?? MattM1124 Civic Coupe And Sedan 23 08-18-2006 06:59 PM
