#62 (permalink) |
Mr. Cowl Induction
![]() Join Date: May 2007
Wild VTEC'n Bill
OP, can you give us a shot of the wiper cowl up close from side to side? I am not seeing the little holes that the USDM wiper cowl has. How does the new wiper cowl get intake air for the ventilation?
#66 (permalink) | |
Doh! I meant Gruppe M.
![]() Quote:
#68 (permalink) |
True, but that intake is just sex. IF it were a a car show, it would take best engine bay over any intake on the market currently for us now anyday.
![]() ![]() ![]() ![]() ![]() BUILD MY CITY!:http://whocares05050.myminicity.com/sec http://whocares05050.myminicity.com/ind
#71 (permalink) |
Mr. Cowl Induction
Wild VTEC'n Bill
You have to look at this in terms of a total package. If you have a race header, cat-back, cams and Hondata, then yes, this will certainly make more power. A motor with better breathing and cam lift/duration will need cooler, denser and more air. This intake does all that.
#75 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
This is such a good point. You can't dyno a car with ram air. Ram air operates on air velocity and pressure. Thus, the faster you go, the greater the ram effect. In a sense, it is a simple form of supercharging sans the blower. As you so well noted, a wind tunnel would be needed to measure the air pressure via transducers at the wiper cowl area. In the thread I did on cowl induction, the Miata group that did the cowl induction install used acceleration and passing tests as the real evaluation of using air from this high pressure zone. They found 0-60 times dropped .5 seconds, which is really quite substantial.
#76 (permalink) |
Kill Your Self Krew
you wont get a cel from this.
#79 (permalink) | |
Q. What if you would dyno the car with one of those super blower, big ass metal fans right in front of the car to more or less simulating the effect of the air rushing in? |
#80 (permalink) |
I was thinking of dynoing the car with the hole plugged off... and doing it open...
but even then... the car isn't even moving so its hard to judge how much power it gives u. But i know from how the car feels driving.. its seems like it works well. I also installed the Spoon Venturi Throttle Body and the Hondata manifold gasket. Very good combo. I cant wait to put the rest of the Mods!! |
